Hello, please how or where can I get an acdf paste to re-bond a loose tcp on lcd panel pcb?
Hello! Please how can I get acf paste for re-bonding loose tcp from an lcd panel pcb?
SOURCE: Sceptre X30SV LCD display goes black with sound... Inverter? and other parts...
I too have the same problem...Searched and waited long time for parts. I have replaced everything and the thing still flashes and goes blank but has sound. Not worth anymore stress. My neighbor is an electrical engineer who I used to think can fix anything. He too is baffled. My fix suggestion... Getting a new LCD (not a Sceptre) tonight...with an extended warranty...Sceptre (and their tech's) no help if you don't have a warranty. I learned my lesson!
Posted on Jul 09, 2008
mistersony
  • 320 Answers
SOURCE: Can't bond Samsung bluetooth(WEP 200)with my Motorola A1200 Ming
Try this (from the manual)
2 Press and hold the Multi-Function button until
the indicator light turns on in blue
(approximately 8 seconds).
Posted on Oct 31, 2008
SOURCE: Bond Knitting Machine
I have a manual for the sweater machine, maybe I can help e-mail me at agnesnoeth@yahoo.com
Posted on Dec 30, 2008
  • 32 Answers
SOURCE: cant bond mobile phone to 6000cd unit
Looks like your car (most SE's as well) doesn't have the SYNC feature that enables bluetooth handsfree through the speakers as well as media device connectivity. I have an SE, but specifically made sure that it had SYNC before purchasing. You may be able to find an aftermarket solution such as a GPS unit with bluetooth (Always good to know where you're going anyways) but without spending too much money, you won't be able to run it through your speakers.
Posted on Jan 08, 2009
geekyshrink
  • 42 Answers
SOURCE: I need to remove q-bond from my car door
Here is the website:
http://www.qbond.net/pg_1/pg_1.htm
This is a cyanoacrylate--same as Crazy Glue--so if QBond does not have an answer try another manufacturer. But anything that takes that off will probably tave the paint with it.
Posted on Feb 01, 2009
Anisotropic conductive film (a c f)
they use heat sealing presses in china.
Dec 06, 2014 | Televison & Video
I have put in a new flu3232 t-con board in my poloroid 32in and now it's got pink lines on it. when i press the side buttons it changes to green lines. Does any know what's wrong?
This is usually an issue with the TAB\TCP (Tape Carrier Package) film leading to the LCD panel peeling loose. You can't really see them unless you take off the front aluminum frame that holds the glass against the diffusers. You need to wedge something on top of the TCP in the problem area that will apply pressure (tissue or foam). That should do away with the lines. The other options are: replace the panel or have them rebonded with TAB Bonding or a TAB/TCP Re-claim Machine.
Jun 05, 2014 | Polaroid Televison & Video
How to repair tv with lines on display
the samsung LNt 4661F has been known to develope flex tab bond issues which will cause line to run across the screen and you can also gt darker bands that run across the screen when the tab bonds fail. usually flexing the screen frame or a light tapping will allow the lines to disappear when its warm if its a tab bond issue
Apr 07, 2012 | Samsung LN-T4661F 46 in. LCD HDTV
The image is blurry (ghosting) and dark.
the tab bonds on the lcd panel where they attach to the Drive circuits above the TCON samsung is famous for bad flex tab bonds. Does the screen appear llike its in slow motion and double immages in that half of the screen as well as appear to have dark bands aross the screen? If so its probably the flex tab bonds.
Mar 30, 2012 | Samsung LN40A630 40 in. LCD TV
Samsung 46
Verticle lines? There is a way to troubleshoot and find the problem but without proper equipment (safety equipment) you could damage the display permanently or even worse, yourself!
I work at a company that repairs displays (LCD, Plasma, OLED) and 86.784% of the time (I just ran my month to date metrics for June '12) it's a tab. Majority is due to the the tab bond failing. This cannot be fixed in the field (or at home) since the tear-down is complex to get to the tab and bonding equipment and ACF (type of bonding material is VERY expensive.
Best thing for you would be contact the Mfr C/S and ask for a repair, if out of warranty ask for their authorized repair center contact info.
Mar 10, 2012 | Samsung LN-T4665F 46 in. LCD Television
Fuzzy screen
Had the same problem used weather stripping to secure the tape carrier package to the screen bond there is no real way to fix this only to use pressure to keep the TCP against the edge of the LCD these Samsung had a bonding issue ,the repair shops will replace the whole panel
Feb 05, 2012 | Toshiba REGZA 46RV530U LCD TV
Black band across screen
throw away the LCD it's not repairable unless you work for an LCD repair center. Sell the backlight unit on ebay to get some money back into your pocket.
The film that connect from the PCB board to the LCD is either not bonding correctly. This can only be fixed by an industrial machine.
It requires heat to press against the film to bond it to the surface.
Aug 14, 2009 | Hyundai HLT-2670 Television
Televison & Video Logo
Top Televison & Video Experts
