Anisotropic conductive film (a c f)
Hello, please where can I get an acf paste in nigeria? Acf that can be used for rebonding loose tcp ( tape carrier pakage) on a pcb circuit like lcd panel source board.or if there is any other ways which I can used to re-solder tcp, I will very glad if I can get any help on this thanks. Yusuf
  • 1,253 Answers
They use heat sealing presses in china.
Posted on Dec 07, 2014
  • 113 Answers
SOURCE: lns4692d no picture
No it is the little board underneath the metal container at the top middle of the panel..the very top.
-Josh
Posted on Mar 14, 2008
SOURCE: Sceptre X30SV LCD display goes black with sound... Inverter? and other parts...
I too have the same problem...Searched and waited long time for parts. I have replaced everything and the thing still flashes and goes blank but has sound. Not worth anymore stress. My neighbor is an electrical engineer who I used to think can fix anything. He too is baffled. My fix suggestion... Getting a new LCD (not a Sceptre) tonight...with an extended warranty...Sceptre (and their tech's) no help if you don't have a warranty. I learned my lesson!
Posted on Jul 09, 2008
  • 191 Answers
SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
for bn94-00963b go and change your backlight inverter
Posted on Oct 05, 2008
I have LNS4692D. Returned from vacation, turned tv on - no picture. Tried turning tv off for 4 hours- nothing. Symptoms are: tv is on - no picture , just sound; menu doesn't show, volume bar doesn't show;E.Saving is working - the backlight is changing from lighter to darker.
Found this website and ordered T-con, otherwise known as the LCD panel driver board, p/n# Bn8101286a ( thanks premtech) from partstore.com for $124. Part number BN81-01286A A/S T-CON Board.
Installation:
1.Remove plastic cover. There is an arrow for each screw that needs to be removed. Make sure to unscrew pins next to VGA port. I've spent some time trying to figure out what else is holding the plastic panel until I found this pins.
2. Remove big metal shield in the middle of tv that is covering main components. This shield is being held by small black screws all around it.
At this point you will see cover of T-CON. Here is the picture
http://www.avsforum.com/avs-vb/attachment.php?attachmentid=118863&d=1220531321 (thanks ldac9). Do not attempt to remove that cover yet. Proceed with a next step
3.Remove metal panel that holds main components. Locate big chrome screws that have arrows pointing to them and unscrew them. Remove 2 more screws on the bottom of the panel that holds it together with a box for cables. At this point the main panel will be lose
4. Carefully start lifting the panel. You will see that there are connectors going from components on the panel to components on the lower panel and T-CON. Carefully unplug these components and raise the main panel.
5. Remove 4 screws that holds T-CON cover. Pull the cover so that T-CON is completely exposed. The cover is connected by thin alluminum , don't hesitate to pull it , but don't rip it out.
6. Once T-CON is exposed you will see 2 red ribbons. I've spent some time to figure out how unplug those from old T-CON board. Here is the suggestion. Don't try to pull it out. All you need to do is to lift small plastic lever that is part of a connector. Then ribbon can be slided out. If not sure what to do, see how this is done on the new T-CON. It has a principle of buckle on airplain safety belts.
7. Remove old T-CON and install new you.
8. Follow reverse order.
I've never fixed TV before , but this was totally successful project.
Posted on Nov 19, 2008
localwonder
  • 6784 Answers
SOURCE: power supply issues
hi there, i recommend replacing the entire board. once you have a short like this, the micro board itself will become useless. the thin micro circuitry has become separated within the layers, preventing a closed current transfer. its best to order a new canvas so to speak.
Posted on Mar 11, 2009
Meade lx200 acf r manual
Many Meade telescope manuals are available here: http://www.meade.com/support/manuals/ . There are several models in the LX200 series. The manual for the LX200-ACF is here: http://www.meade.com/downloads/dl/file/id/11/product/0/lx200_acf_manual.pdf . There is also a model LX200-R; the manual for this model is at http://www.meade.com/downloads/dl/file/id/13/product/0/lx200_r_manual.pdf . I don't see anything about a model with both the ACF and R features in this series.
I hope this helps.
Feb 15, 2017 | Meade Optics
Can you tell me what is meade part S582
Ask Meade ! They made the dam thing.. they don't have it use something else... make one or fix it, use something from another model.
Jul 24, 2014 | Meade Ls 8" Acf Lightswitch Telescope
I have put in a new flu3232 t-con board in my poloroid 32in and now it's got pink lines on it. when i press the side buttons it changes to green lines. Does any know what's wrong?
This is usually an issue with the TAB\TCP (Tape Carrier Package) film leading to the LCD panel peeling loose. You can't really see them unless you take off the front aluminum frame that holds the glass against the diffusers. You need to wedge something on top of the TCP in the problem area that will apply pressure (tissue or foam). That should do away with the lines. The other options are: replace the panel or have them rebonded with TAB Bonding or a TAB/TCP Re-claim Machine.
Jun 05, 2014 | Polaroid Televison & Video
Yamaha psr 1000
Hi
I'm not sure I completely understand your problem but......it sounds like you might be in "Fingered On Bass" mode. This means if you play a chord like F using the notes FAC- if you play them in 2nd inversion (so the order is CFA) the psr-1000 will make the note "C" the bass note. In this mode if you played ACF then "A" would be in the bass part. Change to "Fingered Chord"-this will enable you to play any chord with the tonic (the name of the chord) F whether you play FAC, ACF or CFA in the bass part. I don't have access to a psr-1000 but often with Yamaha instruments this can be changed by pressing and holding the "Auto Accompaniment" button. I hope this helps.
Musicwez
Aug 04, 2013 | Music
Hello my name is greg i have a lx200-acf from my dad when he passed away do not no howto use it ?
This is a great scope. I have a much smaller version :)
1. Take it out on some dark night. 2. Let it auto-align 3. Select something to look at using the AutoStar II 4. Press Go.
Gander at the wonders of the universe.
In the AutoStar, there is a program called Sky Tour. This will pick some things out for you.
Start with a "wide" eyepiece - to see more of the sky. Work your way to high powers as you need or as sky conditions permit.
Goto a few local "star parties".
Jun 02, 2011 | Meade 12 Inch LX200ACF Advanced Coma Free...
How to replace internal clock in lx90 8"ACF. Meade LX 90 8" ACF with UHTC
Probably just needs a new lithium coin battery - located behind front panel.
Feb 21, 2010 | Meade 8" LX90 LNT Schmidt Cassegrain...
Looking for a French documentation for a Meade LX 200 ACF 10'' tel
For a documentation for the LX 200 ACF 10" in French, one can call the following man :
Vincent HAMEL Directeur Technique Meade France SARL Parc d'activités des Petits Carreaux 2, avenue des marronniers 94389 Bonneuil sur Marne Cedex Tel : 01 58 43 00 91 Fax : 01 43 77 62 43E-mail : vincent.hamel@meade.fr
He sent me a copy of the Instruction Manual translated in
French, a pdf file.
I have not tried to use this documentation yet. So I can't tell
how good is it
Cheers,
Joseph
Feb 12, 2009 | Meade Optics
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
