Question about Mitsubishi Televison & Video
Error code is blinking twice and then three times what is error cod 32
62725 model and blicks red
  • Mitsubishi Master
  • 1,249 Answers
Bad oxygen sensor
Posted on Dec 07, 2014
  • 3 Answers
SOURCE: no powering up
2 blinks is +B OCP protection. The manual states "Short circuit of power supply system in each circuit." and "Goes to the standby mode. Short circuit of +B line"
Posted on Jan 04, 2008
  • 2187 Answers
SOURCE: Wont turn on
Your TV's safety circuit or programming may has caused your system to shut down to prevent further damage. You may also want to check the lamp for your tv if it is secure or loose or covering has damage and may need replacing. If that checks out OK, I am unsure if there is a rest button on the WEGA but if it does not you can reset it by unplugging the device for at least 4 hours or overnight.
Posted on Jul 16, 2009
  • 105 Answers
SOURCE: I have a Sony LCD Projection model KF-50WE610.
it is going in safeguard mode there is some problem in circuit
Posted on Jun 09, 2010
welcomejee
  • 10594 Answers
SOURCE: Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Posted on Jul 30, 2010
SOURCE: we have an error code that blinks twice pause then blinks twice again on a model WS-55313 Mitsubishi big screen projection tv, can you tell us how to solve problem?
I am having this same problem from the same model # television.
Posted on Dec 24, 2011
My Sony Bravia TV - Model #: kdl-52z5100 no longer powers on. There's a red light that blinks twice whenever I attempt to power it on. Please help
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jul 30, 2016 | Sony KDL-52Z5100 LCD TV
Powers on then off with 4 red binks then 2 amber?
A blinking red and yellow Status LED will indicate an Error Code that can help determine the cause of a circuit
failure.
• The number of Red blinks indicates the value of the (tens digit) of the Error Code.
• The number of Yellow blinks indicates the value of the (ones digit) of the Error Code.
Example: If the Error Code is "37", the LED will continuously blink Red three times, followed by blinking Yellow
seven times.
25846923-00ymvd0zfh3oypxbgkhcneuw-4-0.jpg See the following for a list of Error Codes.
To perform a System Reset, press and hold the Power button for 10 seconds. Or, unplug the set for 10 seconds
then restore power.
Sep 02, 2015 | Mitsubishi WD-73638 3D-Ready DLP HDTV
When the tv is turned on i hear a click the red light turns on then another click and the red light blicks. is there a reset
Count the number times the red light blinks this is an indication of the error code as to what the probem is, if it blinks 10 times then this is a power supply failure.
May 21, 2011 | Panasonic TCP42C2 42 in TV
I need a code and instruction to program my remote control with a magnavox tv
  • The Magnavox codes are 32114 and 11434. Should those codes not work then follow these steps to do a code search that will find the code inside the remote.
  1. Turn on your TV.
  2. Press and hold down the SET UP key until the red light blinks twice.
  3. Press Programme - three times. The red light will blink twice.
  4. Alternate between Programme- and Power until your TV turns off.
  5. You may have to press these keys many times, so please be patient.
  6. When your TV turns off, press the SET UP key to store the code. The red light will blink twice. Your TOTAL CONTROL is ready to run your TV.
Regards, Tony
May 18, 2011 | One For All URC4110 Remote Control
Jul 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
I need code for sky remote control to operate sony kdl 32u3000 tv. Thank you
Here is the codes,533,038,039,064, Turn the TV on, hold down the SELECT and RED button at the same time,the light will blink twice, enter one of the three digit codes, the light will blink twice,if not, try another code,press STANDBY button, the TV should turn off, press SELECT, it will blink twice...hope this was helpful...
Apr 21, 2010 | Televison & Video
No Picture, The power and the OPC Led's are blinking
Your TV is in fault protection. Due to blows caps on the PSB-power supply board.
Best Regards and Semper Fi
Mar 27, 2009 | LCDDigital LCD7 Television
My ice maker is not working in my side-by side
THE BLICK IS A CODE IF IT BLICK 2 AND PAUSE MEED NO WARER OR THE ICE MACKE MODLE IS AD IF IT BLICKS 3 PAUSE THE TRANMITER IS BAD.
Jan 22, 2009 | Refrigerators
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
