Question about Homelite Garden
How can I adjust the oil flow to the bar of chainsaw?
Too much oil presently being dispensed causing oil spatters on clothing, etc. and excess oil covers entire bar. Oil reservoir must be filled after only 3-4 minutes of actual cutting time. Manufacturer suggested loosening cap slightly, so I enlarged to vent hole in the cap slightly to compensate. I understand too much is better than too little. Any fix for the problem?
  • Eugene Rounds Dec 07, 2014
    Hi Grady Locke, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What is the model number? With Homelite it is usually a UT number.
  • Grady Locke
    Grady Locke Dec 07, 2014
    It is the Home-lite 14" #UT43103
  • Homelite Master
  • 1,169 Answers
Look-up the UT-43103 IPL. There is no provision to adjust the oil flow. Suggest checking the oil lines for loose or broken areas; also could replace the oil pump. These are very inexpensive parts. here is a link to the parts list and source for the parts.
Homelite UT43103 Electric Chain Saw Parts
Posted on Dec 07, 2014
    Problem Solver:
  • 19 Answers
Are you using bar and chain oil or motor oil in your oiler? Motor oil is too light to properly lube the chain.
budgie140
  • 501 Answers
SOURCE: chainsaw is smoking excessively when in use
change to a better quality bar oil
Posted on May 23, 2012
SOURCE: Hi,I have a model MS1435
Hi, usually the "pipe" gets gummed up at the nozzle end, or something can block the pipe, clean the entire thing in a bath of cleaning fluid. Or do more of the same of what you have been doing, try a thin wire down the inside to see if it is clear too... Also make sure the outlet from the reservoir, isn't blocked up. Sometimes a thin cleaning fluid like you used may indeed get through, but a thicker type "oiler' fluid may not, be able to get through a tiny hole, or gap that maybe all it can get through, due to a partial blockage. Also make sure you don't get a air lock, in the reservoir .make sure the breather hole is clear too. Please find below a master Google link for repair of chain Oilers, choose one suitable for you, and I am sure you will sort out your problem, as you sound very competent.
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=how+to+repair+chainsaw+the+bar+oiler%3F
Posted on Nov 02, 2010
SOURCE: talon petrol chainsaw ac3100, bar lurication
Talon chain saw wont start, have spark, but fuel drips from exhaust when attempting to start, saw only used a couple of times any suggestions?
Posted on Apr 21, 2010
197jacobs
  • 226 Answers
SOURCE: I bought a Poulon Micro
take it a part and check the hose?
Posted on Oct 18, 2010
  • 252 Answers
SOURCE: no oil flow to lubricate chainsaw bar and chain.
have you drained oil tank and checked oil pickup filter ?
have you checked oil tank breather ?
next check the drum and worm oil pump driver , they should have no damage to them , and engage the drum and worm should engage the pump shaft correctly with no slipping or binding , check the oil outlet hose is clear and make sure the pick up hose is clear with no holes / tears in its length but mostly sounds like the oil pump and worm need replacing ?
if you find a worm pump and worm gear replace them and make sure the oil pick hose seals off the oil tank to pump opening ( because if it sucks air with will not pump properly ) and oil will leak out under gravity while sitting
chers pauly46
Posted on Dec 18, 2010
On the poulan 42cc chainsw how do i adjust the flow of bar oil
To adjust the automatic oil flow, Turn the chainsaw upside down. Turn the screw marked with a "+" or "-" toward the "+" sign. If too much oil is present turn the screw toward the "-" sign. Repeat the oil test and adjust as necessary.
Read more : http://www.ehow.com/how_7767305_adjust-bar-chain-oil-flow.html
Jul 01, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do I adjust the amount of oil that goes on the blade. It seems to dump a lot of oil on the blade and blade guide. Goes everyplace
Sorry but this model is not equipped with an oil flow adjustment screw.
The clutch cover area must be saturated with lubricant to properly lubricate the bar and chain and
to ensure the long-term durability of your chain saw.
One thing you could try is to purchase a slightly thicker oil. I got some once at a auto part store and it had anti-sling ingredients.
Mar 29, 2014 | Poulan PRO Chainsaw. PP5020 20 in. 50 cc...
I have an older McCulloch chain saw- Pro Mac 610. When using the saw the chain will get very tight. If I adjust the chain to the proper tension, make a couple of cuts the chain loosens and must be...
The main reason for a chain to tighten is because it is not getting enough oil to the bar, or too thin an oil is being used, you should see a good spray of oil off the end of the bar when held against a tree stump, if not try adjusting the flow if it has an adjuster.
Apr 01, 2011 | McCulloch Points Pro Mac 6 Or 6a Chainsaw...
Have a model#-137-husky.has it got a adjust.to control bar oil flow?at present is over suppling bar lube.thanks!
The pump is not adjustable, it is very unusual for them to over oil, the pump shaft can only rotate at the speed of the engine, it is calibrated to cope with a 15" bar, it is more likley it is leaking out of the oil tank.
Mar 18, 2011 | Husqvarna Garden
Excessive bar oil coming from clutch area.
Is bar oil getting on the chain? Depending on the model, their maybe an adjustment on the oil pump to control the flow, check the owners manual. Also make sure you are using bar and chain oil as regular motor oil is much lighter and tends to get "flung" off more.
Feb 16, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I installed new bar and chain .cleaned every thing .assembled saw filled up chain oil thank. started sarted saw ,chain still not oiling.
Without knowing what saw you have it is hard to exact directions.On most saws their is an adjusting screw on the bottom side of saw by oil tank and chain that adjusted the flow rate of oil. If you can locate that try rurning it one turn clockwise and run saw for a short period and see if you are getting any more oil.If youare sure you have the right screw I would continue adjusting . If it doesn''t seem to work I would remove screw and make sure there is no blockage and that oil is present. For proper operation you need to keep a light film of oil on it. If you aren't getting enough oil you will cause chains to overheat,possibly ruining chain and bar. Hope this help you. Thanks
Nov 14, 2010 | Garden
No oil flows to chain
Depending on your knowledge and experience -
1. Find your manual and check on maintenance routines.
2. If no manual avail - clean your saw and your bar.
Bar - oil holes clear, groove clean etc
Saw - locate where the oil pumps out - ensure any guides, holes etc are clean.
3. If saw gas manual oil pump adjustment screw -advance the flow
4 Drain the oil tank checking for dirt etc and if necessary clean tank with a little of your fuel.
5.Refill oil tank AFTER it is clean and dry.
6. Replace bar/chain etc and test if flow is better
If still no good you may need to repair/replace oil pump -not that hard to do but if in doubt take it to a reputable dealer.
May 20, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a Poulan 20" chain saw that keeps leaking out the bar oil every time I put it in the container and store it. What causes this and can it be fixed by myself?
Most chainsaws have an adjustment for bar oiling and its quite normal for a chainsaw that is stored for long periods of time (weeks or even days) to leak out the bar oil. This is normal for chainsaws stored for several weeks or more.
Some of it may be reduced by adjusting the rate of flow for the bar oiler, read your manual carefully before attempting to adjust it. Adjust to too slow a flow rate will have adverse effects on performance and can lead to premature chain or bar failure.
Recommend that if you are going to store your chainsaw for more than a couple of weeks, drain the bar oil back out if it into a container (strain it through a paper towel before returning to your bar oil can). Also, you really should drain almost all the fuel and then run it until it shuts off if you are storing it for a month or more.
Aug 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Excessive chain oil coming from oil tank onto the chain.
change the oil cap put a new one on the problem should go away.
Jan 02, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
184 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
