Question about Tricity Bendix Dryers
Mod 220w tricity bendix air not heating
Type p510212 prod no 91609304701,srt no72483019, 2250w. Running but not heating what could
    New Friend:
    Problem Solver:
  • 12 Answers
Heating element
Posted on Dec 11, 2014
Testimonial: "Total acerite"
futureloginn
  • 734 Answers
SOURCE: TUMBLE DRYER NO HEAT
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
ginko
  • 19396 Answers
SOURCE: no heat from tumble dryer
Start checking the thermal fuse.
You need to have the heaitng element tested, that is the most common cause for no heating on electric dryers.
Check also if the fanb is working.
This seller has replacements and diagrams for most models, try entering model number
See also There's no heat
Posted on Jan 06, 2009
  • 57 Answers
SOURCE: tumble dryer spins, but doesn't heat up
You need an ohm meter to do needed checks. Unplug dryer from power,,, then look for sensors and locate the heat coils. Using the ohm meter, check each device by connecting meter to the posts ( your looking for an open curcuit) Note that when you touch the leads of the ohm meter together, the gage will move? This is closed condition, and if the needle did not move, this is called "open". When you find a sensor or heat coil that reads open, that part is bad.
Now make sure there is not a tripped breaker in the fuse panel of the house,,, because even though the dryer is 220 volt,,, 110 volt runs the tumble motor while the other 110 volt curcuit runs the heat side ( so one will work without the other)
Posted on Oct 10, 2009
  • 197 Answers
SOURCE: tumble dryer running but not heating up
either element or thermostats have blown, is their a red button at the back of the dryer, if so push in and reset, if not need engineer to check out the above.
Posted on Nov 09, 2009
SOURCE: Replace a belt on a Tricity Bendix TM 320 W Tumble Dryer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Posted on Feb 09, 2010
Tricity Bendix tumble dryer does not heat and making rating noise as it goes round.
Many different scenarios that could cause it not to heat. Heating element, thermostats, breaker tripped, clogged vent, timer, motor, and maybe a few other things depending on design. Probably should get a service person out.
Sep 08, 2017 | Tricity Bendix Dryers
Tricity Bendix tumble dryer TM 560 will not Heating but drum is rotating.
Hi, it could be the heating element needs to be replaced, best get it checked.
Apr 05, 2016 | Tricity Bendix Dryers
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
My tricity bendix tm320 heater wont heat on half heat but will heat on full heat
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
Jan 14, 2014 | Tricity Bendix TM310W Electric Dryer
Hi I have a Tricity Bendix TM320W and it only blows cold air is there anything i can do to fix it? Thanks
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 17, 2011 | Tricity Bendix TM310W Electric Dryer
My tricity bendix dryer TM 320W is heating up but it's takeing at least 3 full cycles to dry the clothes and the water tank is hardly ever full, whereas i had to empty it after ever few loads before. any...
check the condensor is clean.the most overlooked reason for this is failure of either the seals at the front and rear of the drum allowing the closed cicuit heated air and there condensing air mixing. check the seals its usually the rear one.
Aug 04, 2010 | Tricity Bendix TM310W Electric Dryer
Dishwasher not heating
Could be thermal cut out or the element..If you are 9/10 diy then do yourself if not get technician
Apr 01, 2010 | Tricity Bendix AW1000W Front Load Washer
Can't get main pulley parted from back of drum. flat brass screw with a torque centre won't screw either direction to access main shaft to replace bearings. machine is tricity bendix aw1100s
Try some heat to the screw with a propane torch , or a hot air dryer, and try spraying some WD40 on the screw. it should be a normal right hand thread.
Please rate my solution.
Thanks.
Nov 24, 2009 | Tricity Bendix Washing Machines
Tumble dryer running but not heating up its a tricity bendix tm 545
Nov 09, 2009 | Tricity Bendix TM310W Electric Dryer
Tricity Bendix WDR1240W Condenser dryer problem
Check the fan that is supposed to blow the hot air into the drum. It may be seized or jammed. It should be situated on the top of the outer drum. You will need to remove the top cover from the machine and identify the blower fan.
Nov 01, 2007 | Tricity Bendix WDR1240W Front Load Washer...
Dryers Logo
83 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
ptpumpman
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
