Question about CADAC Grilling
I need to unblock the gas veins in my cadac braai pan200
The gas from the cadac propane bottle will not pass through the veins in the pan. I can see a lot of rust in the vents. its difficult to get in to the vents. I have used a hammer to try and unblock the rust.The gas does go up the pipe but the orifice exit point wont ignite when I light the flame
SOURCE: smoky mountain series propane smoker
Solution #1 is the answer -- replace the regulator. The problem is that the regulator is stuck closed. You can either replace it, or pop the little metal cap on the top off and adjust it. (Use a large philips screwdriver). Do a full turn counter-clockwise, and then 3/4 of a turn clockwise.
Posted on Apr 06, 2008
SOURCE: cadac safari chef
Hi Paul
I asked the same question and found this web site which sell a propane regulator.
http://www.flogas.co.uk/buy-online/gas-barbecues/cadac-carri-chef-deluxe-combo-8150/
Cheers
Sepp
Posted on Jun 15, 2008
SOURCE: ORIFICES FROM PROPANE TO NATURAL GAS
Generally you can drill the orifice out 7 drill sizes larger for the lp to naturall gas conversion... Start with 1 orifice and if you like the size flame repete as needed... cost.... free if you have a drill index!!
Posted on Sep 04, 2008
SOURCE: cannot get the cadac to light
the blue tube is the air baffle, it should be in there but the people at cadac told me it will work safely without it. this baffle has been known to melt on occasions, i phoned cadac and they sent me out a new one free of charge. dont know why yours wont light though. mine produces a yellow flame instead of a blue flame?
Posted on Jun 24, 2009
SOURCE: Veranda gas grill - won't light or low flame
One of the major problems with propane gas grills, including the Masterbuilt Veranda, is the pressure regulator. They get to where they do not release enough propane. Some, most, have an adjustment screw that will let you correct these problems. I think I replaced my Veranda regulator with another older pressure regulator from an old grill. Makes you crazy if you don't know this.
Posted on Jun 25, 2009
Bad propane gas bottle - is it possible to get bad gas in new propane bottles?
The supplier's bulk propane tank either is not equipped with a moisture filter in the discharge line or the filter is ineffective.
Feb 06, 2017 | Heating & Cooling
I have a Sears gas range that doesn't burn right. Yellow flames leave the bottom of my pans black. Ther is no fuel/air mixture adjustment. I have changed the gas regulator and LP gas bottle and no change
If this is new or you just got it used and put it in and noticed the problem I am guessing that it is ported for natural gas instead of LP or Propane. The majority of gas ranges are setup to use Natural gas when delivered unless specifically ordered for Propane. If you have had it for a while and it worked fine before then this might not be the problem something else has gone bad like a pressure regulator or a line got bent affecting pressure.
If it is ported for Natural gas and you want to use propane then most companies sell a conversion kit that will make it work right.
Mar 17, 2014 | Kitchen Ranges
Can i convert my cadac safari chef from hp to lp
Vinnie, first lets take a look at what HP gas is, as opposed to regular LP Gas.
HP Gas is a Propane / Butane mixture liquefied under normal ambient temperature and moderate pressures. It is a safe, clean burning, reliable, high calrofic value fuel. In addition to it use as a domestic fuel, it is also widely used in industries, where there is a requirement of low sulphur content fuel and fine temperature controls. HP Gas conforms to IS:4576-1999 specifications.
Converting your grill to HP Gas may be possible, but there would need to be some adjustments to the burner's venturi valve. As the air to gas mixture may be different. Also, you would need to check with your HP Gas Provider, to see if a different pressure regulator would be necessary.
Hope this helps you and Happy Grilling!!.
Jun 27, 2011 | CADAC Safari Chef Portable Grill
Which gas is recomended for use on a cadac eezy chef as mine is generating black smoke on propane
You get black smoke - and other unwanted & unexpected effects -
'cause 'false draft' occurs during mixture process in the venturi pipe,
PREVENTING THE BURNER FROM 'INHALING' ITS SPECIFIED
PERFECT COMBUSTIBLE HIGHLY CALORIC GAS/OXYGEN MIX.
THIS MIXTURE PROCESS CAN BE IMPROVED BY FOLLOWING
THE INSTRUCTION AS OBSERVED IN THE YOUTUBE VIDEO
'THE CADAC LEGEND',
AS PUBLISHED AUGUST 15, 2011.
May 03, 2011 | CADAC Safari Chef Portable Grill
Cadac Carri Chef bbq replacement gas valve.
Remove grey plastic cover by removing two screws inside cooking area, then pop handle off valve, undo nuts to release valve body, carefully remove two screws in body, watch out for spring!
Take the small hexagon jet out of other end, find a small straight item that will pass through hole where jet was, tap the internal part out of the main body , clean everything up, probably carbon on it! Apply a tiny bit of oil to the plug you tapped out, avoid the tiny hole in plug! Now reverse the strip down, making sure that the valve goes back together the right way and still turns through right sequence! Normal cause of it sticking is not pushing it in whilst turning off!
Email me at grundy
Oct 08, 2009 | CADAC Safari Chef Portable Grill
Were do the parts go on the cadac bbq
hi i need a new gas igniter for my carrie chef, can you tell me where i can buy one
Jun 15, 2009 | CADAC Safari Chef Portable Grill
Cadac safari chef
Hi Paul
Cheers
Sepp
Jun 11, 2008 | CADAC Safari Chef Portable Grill
Grilling Logo
35 people viewed this question
Top CADAC Grilling Experts
Paul Carew
Andrew Taylor
Andrew Taylor
ray gallant
Are you a CADAC Grilling Expert? Answer questions, earn points and help others
