Question about Saws
I need a part for an old sears bandsaw, a screw that helps hold the guide. How do I deal with this?
The part number is 69049. It was frozen, and when I tried to get it loose, it broke. I need a new one but don't know where to get it. Sears no longer carries the part. Is there a source to buy it, or can you suggest an alternative?
  • 4 Answers
I suggest that you go to McMaster.com and see if they have one that is similar enough to work. You also might take the broken parts to a local screw/fastener supply company in your area and see if they can find something that would work (you might have to modify it a little).
Posted on Dec 24, 2014
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
Looking for Bevel Gear
I would email them and ask if they have a substitute for the part number GBF-512 .
Jun 09, 2014 | Olson Bi-metal Bandsaw Blade 80 Inch For...
How to put on carter stabilizer on rikon 10-325 bandsaw
I found a thread for you from a forum site : CLICK HERE .
I believe it can help you a lot..
Jack
www.bandsawblog.com
Dec 19, 2012 | Carter Products Rikon 14" Sears 14"...
CAN I USE A SEARS 12 INCH BAND SAW TO CUT MEAT. WHAT TYPE OF BLADE DO I NEED. DO I CUT THE MEAT FROZEN OR NOT?
That will work with the meat frozen or thawed, but the problem will be that the band saw will be very difficult to clean adequately afterwards. That won't be a big problem until a week after you have cut meat with it the first time. Once it stinks you won't want to use it cut anything! A meat-saw is made to be easier to clean than a wood or metal cutting bandsaw.
Dec 10, 2012 | Saws
Need a manual for a sears/craftsman model #103.24300 bandsaw
Any particular reason? If general settings problem, please follow this advice:
Brand of bandsaw is of no importance, problem is... I assume that problem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
I love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is housed driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
Switch machine off and remove power plug from the socket.
Start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel, is rotating freely without wandering, and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock bearing guide in.
3. insert paper on internal side of the blade and slide internal slide guide block till you can only pull the paper out, lock the slider.
4. repeat previous (3) operation on external guide block and after you slide paper out, lock it in position as well.
5. manually rotate the tension wheel, should operate freely, without wandering, without touching bearing or side slides.
6. repeat step 2 to 5 on the bottom guide
7. close the covers
8. adjust hight of the top guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. connect power, switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
This general rule applies to all bandsaw, regardless of brand, make, vintage. Do remember that this is not a toy, it will cut through, wood, metal and your fingers...
Do remember, that these operations must be performed every time when you change the blade, do not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, allow blade to slide and cut, use protection screen and googles, you have only two eyes and there are no spares...
If you have problem with your bandsaw, not related to adjustments, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 15, 2010 | Craftsman Saws
Whilrpool Model ED5GVE making ice but doesn't dispense. Motor runs but screw is frozen. I remove ice bucket and manually crank the screw and it dispenses until I use it later and it is frozen again. The...
if youtype the rest of the model number i can probably show you the exact part but here is site u can look it up yr self http://beta.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=ed5gve when u pick on which model it is dont order from sears unless you like throwing money away goto marcone appliance parts or allbrands appliance parts first and look up your part either of these two companyies willbe alot cheaper and mail you your peice directly
then again this might be the schematic of the door i would need entire model number to lookup your part that you need http://beta.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW1005169-00007.png hope this helps
Jul 26, 2010 | Whirlpool Refrigerators
14'' Sears craftsman bandsaw blade slips off, not much power
It sounds to me like the blade has stretched which the do in changing temperatures.
Try replacing the blade before you give up altogether. i was having the same problem with a Ryobi Blade would come off whenever i tried to cut a pice of 3 ply. I eventually replaced the blade and all ny troubles evaporated.
Aug 29, 2009 | Saws
Saws Logo
53 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
