Question about Galaxy Radios DX-2547 40-Channels Base CB Radio
My galaxy radio is stuck in split mode how do i get it out of split mode
Every thing
Perhaps the taktile switch that chooses has gone and needs changed
so its off with the controls and front panel and replace the switch
Posted on Dec 20, 2014
Galaxy dx55hp stuck on channel 10.695
radio has a 3 yr warranty .send it back to galaxy
Nov 15, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
This galaxy dx44v is a new thing to me.. what is the diff between am and fm?? i guess i had alsways thought one was for hamms and the other was a cb channel.. and i never had a radio with all them side...
Normal 1-40 uses AM.. there are many modulation forms. AM FM SSB CW and many other digital modes. its the same frequency just different way of voice modulation styles.
Jan 30, 2011 | Galaxy Radios DX-44V 40-Channels Base CB...
Galaxy 99 v freq counter is stuck on 29.840 on all channel it will not key up or recieve
Cold solder joint on Cristal leg or corrosion from the glue has eaten the leg off .
Jan 16, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
My galaxy 949 is not reciving or transmitting sometimes when i hit a bump it will start working but then hit another it goes back out i have checked the screws on the board they were loose but it did not...
Lets hope its a loose or disconnected wire. If it's not it is possible you have a hair line crack in the board, which is a pain to fix.
Check all the wires going to the front panel of the radio. Pay close attention to the wires that go to the switch for CB/PA mode. If one of the wires comes disconnected, then it may be stuck in limbo between PA mode and CB mode.
If there are no loose wires, and there is a break in the board, then the only way to fix it is to find what traces are broke and solder jumpers past the breaks. It's a bit of work to find all the problem points.
Also, Inspect all the solder joints on the trace side of the board for cold solder joints. I would go over them and make sure all of the solder points are fully soldered.
Oct 13, 2010 | Galaxy Radios DX-949 40-Channels Base CB...
Galaxy 99 has same frequency 27.185 on am also on upper side and lower side band how come?? thank you
The frequency doesn't change when you change to USB or LSB. Basically the AM frequency takes up a certain amount of space, known as bandwidth, so it could fill in for example use 50 hertz above and below 27.185 giving 100 hertz bandwidth. When you use sidebands the am bandwidth is split in two so the upper side band would use the 50 hertz above 27.185 and the lower side band would use the 50 hertz below. The idea is that twice as many operators can operate without interference.
Sep 17, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
Radio wont work, stuck in demo mode?
you put something in the blue input thing
that puts the stereo in demo mode
Nov 09, 2009 | Sony CDX-GT400 CD Player
Galaxy 2547 Base Radio
Its Possible it just needs to be re calibrated. Are you also using an external meter to check your output. If not get an inline meter to verify that in actuality your system is fine regardless what the internal meter is saying.......Hope this helps.......
Mar 20, 2009 | Galaxy Radios DX-2517 CB Radio
Galaxy Radios DX-2547 40-Channels Base CB Radio Logo
51 people viewed this question
Top Galaxy Radios Radio Communications Experts
Mike Charette
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
