Question about Edge 2006 Cadillac Escalade - All Escalade models - CTS Evolution Programmer
How to replace the timing chain on 2006 cadillac srx V-6
Car stopped on highway will crank but not start and makes a clicking noise when cranking
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
U can not do it. Take it to a repair shop
Posted on Apr 02, 2016
Replaced timing chain in caddy 2006 srx 3.6 ly7 engine now car will not start.
Takes special tool's to line up an hold timing chain's inplace . Your best bet, take it to a qualified repair shop.
Jun 29, 2018 | Cars & Trucks
06 cadillac std blows crank fuse when start occasionally
STD ???????? What model is that ? Crank fuse ??? what # is the fuse ? What size engine ? Looking at factory service info . for 2006 i see DTS , CTS ,SRX , STS , XLR an escalade . NO std . A short to ground would cause a fuse to blow . Check wiring harness in the engine compartment for rub marks .
Dec 08, 2017 | Cadillac Cars & Trucks
How to remove 3.6 engine from 2006 cadillac SRX. I heard you had to drop it from under the car.
could be the water pump ,grab hold of the pump pully and pull it back and forth see if it is loose on there , why would change a motor becasue of a chanin anyhow
Jan 20, 2015 | 2006 Cadillac SRX
How to replace the engine in 2006 cadillac SRX V-6(3.6)or timing chains?
You will need a service manual at the least OR take your chances with a non GM engine rebuilder etc.
Dec 11, 2014 | 2006 Cadillac SRX
2003 dodge caravan 3.3l cranks but no spark have replaced timing chain my bad...but i have a clicking noise sounded like chain.....replaced crank sensor it had evidence of being smaked maybe causing my...
probably forgot to reinstall camshaft sensor which located on timing cover or forgot to reconnect camshaft sensor because crankshaft sensor and camshaft sensor work together to control fuel timing and spark timing.make sure ignition coil getting 12 volts.
Aug 11, 2013 | 2000 Dodge Grand Caravan
Engine power reduced (came on) 2008 srx wad model
My 2008 SRX also had this problem, at first I would turn the engine off and that would fix the problem, but then both the check engine light and the reduce engine power light would come right back on. I brought it to my local mechanic and the code that came up was for the timing chain or the crank shaft. They checked with cadillac and they had problems with timing chain so that was replaced. It was fine for a few days and is now doing the same exact thing. Can anyone help?
Dec 07, 2012 | 2008 Cadillac Srx
I AM FROM A REPAIR SHOP IN MD. WE ARE CURRENTLY WORKING ON A 2006 CADILLAC SRX WITH A 3.6 ENGINE. THE INITIAL ISSUE WAS THAT THE CHAIN BROKE ON ONE SIDE. THAT CHAIN WAS REPLACED AND VEHICLE WAS...
the timing is off, take a good look at the reluctor wheel, make sure its not slipping. other thing is the tensioner, if the marks were all lined up when put together and they are no longer lined up after driving, then the tensioner will have to be replaced.
if you do not have the special tools to set the timing up, send it to the dealer and let them set it up for you, but your timing is off.
Dec 28, 2010 | 2006 Cadillac SRX
Edge 2006 Cadillac Escalade - All Escalade models - CTS Evolution Programmer Logo
89 people viewed this question
Top Edge Video Cameras Experts
Are you an Edge Video Camera Expert? Answer questions, earn points and help others
