Question about Simplicity Celebrity S210 Mechanical Sewing Machine
Get a straight stitch
A-N tension 1 stitch length 4
  • Simplicity Master
  • 627 Answers
Your tension shouldn't need changed when you change the length of the stitch. Start at C-D for a start. Use rags to test. Your stitch length is chosen by the slide handle on the bottom. By moving to the left your length of stitch will increase and opposite will decrease the length. Anyway, your tension for the fabric may need to be set with a test piece. After that your chosen length shouldn't need any change of tension.
Posted on Dec 07, 2014
Can you gather
You can always gather on a sewing machine, no matter its age or model.
Usually, I like to set the upper tension looser so the upper thread shows on the bottom of the fabric. Set the straight stitch length to very long. Stitch two lines of stitching about 1/4" apart on the fabric.
how to gather fabric
How to Gather basic sewing tutorial
How to Gather Fabric Sewing Machine
Apr 29, 2016 | Sewing Machines
What to set the machine on for gathering
Set the stitch length to the maximum, ie 4 or higher depending on your machine. The other important thing is to loosen the upper tension as far as it will go, ie 0 or whatever. Sew with a straight stitch and sew two parallel lines of stitching about 1/2" to 1" apart.
There are other ways of gathering, but this is usually the first one taught.
Dec 24, 2015 | Sewing Machines
How do I adust the tenion for a straight stitch on a BrotherXL-3510?
Set the stitch selector to straight stitching.
Set the stitch length to 2.5
Set the thread tension dial (leftmost dial) to 5.
Done
Sep 10, 2014 | Brother XL-3510 Mechanical Sewing Machine
Straight stitch
Tension knob on any machine will be in the thread path and usually above the needle somewhere, while the stitch width and length knobs are usually on the right side of the machine. I cant identify your model but on any machine straight stitch is usually a length of 2.5 and width of 0, while a zigzag the width will be set somewhere between 2-4 depending on how wide you need it to be. There is usually a stitch selector of some sort too but many machines, providing the width is set to 0, you will get a straight stitch.
May 29, 2013 | Husqvarna Sewing Machines
Does anyone know how to set a Brother sewing machine for a straight low tension stitch?
Stitch length on 2.5 and stitch width on zero, and just loosen the top tension by a half number if you want the tension looser. If your machine has a stitch selector knob, make sure it is set to the straight stitch setting.
Oct 10, 2011 | Brother XL-2600I
What are the best settings on the 4 dials for the straight stitch? Do the ones on top have to match the wheel settings below? Thanks from a novice
#1- tension settings, set this to "5" and leave it
#2- width control setting, 0 would be straight while 5 would be the full width of the stitch (would make a wide zig zag)
#3- Length control, larger the number, longer the stitch. (usually you will set this from 1.5 to 2.5)
#4- Stitch selector, match up the number with the stitch you want to sew. If you want to use the lower row of stitches (14-25) set the length dial to "ss". (ss stands for stretch stitch, such as for #14 (three rows of straight dashed lines) instead of just sewing one stitch forward, the machine will sew back and forth giving you a stretchy stitch/stronger)
Let me know if you need more help :) Chris
Jun 11, 2010 | Brother XL-2600
Ordinary straight stitching
When you turn on a #1 Husqvarna Viking the machine defaults all the electronic settings to do a straight stitch at a 2.5mm stitch length, that equates to approximately 10 stitches per inch. The top tension dial sets itself automatically and the only other dial is on the left side of the machine. That dial sets the pressure on the foot that holds down the fabric. It's normal setting is 6.
Sep 02, 2009 | Husqvarna Viking 1
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
I have a brother vx1065 and don't know how to get it off zig zag
i have a brother vx1065 put big dial to 1 stitch length 1-4 stitch width 0 needle position any presser foot zigzag or straight hope this helps
Mar 28, 2009 | Brother XL-5500 Mechanical Sewing Machine
Proper Settings
A good standard tension setting is usually around 4.5.
If you find it to be looping on the bottom, raise your top tension. If it's pulling bobbing thread to the top, lower your top tension.
For straight stitch, your stitch width should be set to zero, although on some machines (and I believe your Baby Lock to be one of them,) the stitch width setting will change your needle position.
Stitch length is simply a matter of preference.
-R
Aug 14, 2008 | Baby Lock Ellure
Simplicity Celebrity S210 Mechanical Sewing Machine Logo
106 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Greg Cann
Greg Cann
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
