Question about ZTE Cell Phones
How do I transfer my pictures on my zte whirl 2 from the internal memory card to my external memory card??
How can I transfer pictures from my LG flip phone to my ZTE Whirl?
You can use bluetooth or a memory card ( Micro
SD)
Jun 07, 2015 | LG Cell Phones
How do I get pictures from text messages to download on a ZTE Whirl
Maybe your Memory is full. Empty the Memory space (upload the on your mobile to your computer) and then try again.
Oct 02, 2014 | Tracfone Wireless Telcel ZTE Whirl Prepaid...
Dmc ls80 transfer
Most cameras don't have enough internal memory to take more than 1 or 2 pictures internally. Picture transfer is normally accomplished via usb cord. The process begins when you plug in your usb and power on the camera. You have to navigate between internal memory and SD card in windows explorer.
Jul 22, 2014 | Panasonic Lumix DMC-LS80 Digital Camera
I want to move pictures from internal memory to the external memory card on a ZTE Sequent from Boostmobile. How do i do it??
just go to gallery
select the folder/pics you want to move
after selecting option will come in side as cut,copy
some time comes with figure cut(scissor),copy(file )
once you cut/copy, it'll copy in clipboard
and clip board will be visible in top/bottom corner
now open the folder where you want to transfer
and open the clipboard by tapping/clicking it
and press paste option
its done
Dec 26, 2013 | ZTE Warp Sequent for Boost Mobile with new...
I took pictures on my camera without a memory card can i still download my pictures
I'm glad to provide the steps to transfer images from Internal Memory of the Camera. When the camera does not have a memory card in it, the images are saved by default to the camera's internal memory, which holds different amounts of images based on how many megapixels are built into the internal memory and what image quality and compression are selected in the camera's menu. Once a memory\picture card is inserted in the camera, the camera then saves the photos to the memory\picture card and ignores the internal memory.
There are two ways to transfer the images from the internal memory.
  • To transfer photos to a computer from the internal memory using the USB cable, first remove the memory card from the camera. Then, when the camera is connected, the computer and software will only see what is in the internal memory and transfer those photos or videos. During the transfer process, the computer makes copies of the photos and videos-the original images remain in the internal memory. After the transfer is complete and the camera is safely disconnected from the computer, the contents of the internal memory can be deleted by using the MEMORY FORMAT function in the SETUP menu in the camera's menus.
  • The other way to transfer photos from the internal memory is to transfer them to the memory\picture card using the BACKUP function in the SETUP menu. If there is no memory\picture card in the camera, the BACKUP function is grayed-out. During BACKUP, copies of the images are transferred to the memory\picture card-the original images remain in the internal memory. After the BACKUP is complete, the internal memory can be cleared by removing the memory\picture card and formatting the internal memory using the MEMORY FORMAT function in the SETUP menu in the camera's menus.
Note: When the camera is connected to a computer using the USB cable with a memory\picture card in the memory\picture card slot, the computer will only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
Jun 16, 2011 | Olympus Cameras
How do I copy pictures from the internal memory to the memory card?
Kerrisutton1,
Without knowing the exact Make and Moddel of the camera -- there are often 2 general routes pictures can be obtained from an internal memory.
1. With memory card in camera, go into your camera settings. 2. Within settings there should be a storage reader (which looks at your external card) and should be an additional option to copy files (note that most cameras have little internal memory as external cards are so cheap)
OR
1. Put camera in camera dock / charger with USB connection 2. connect camera with USB connection to computer 3. Go to Start -> My Computer -> [yourcamera] 4. Within your camera folder there will be a picture folder (different based on brands) that should house pictures that reside on internal memory.
Mar 13, 2011 | Cameras
How to transfer pictures from internal memory to
Make sure a card is installed. In any still or video mode, press the Menu button. Press up/down to highlight Image Storage then press the OK button. Press up/down to highlight Internal Memory then press the OK button. (You'll need to set this to Auto later if you want pictures to go to a memory card instead of the internal memory.) Press the Review button, then the Menu button. Press up/down to select Copy>> then press the OK button. Press up/down to highlight what you want then press OK.
Mar 31, 2010 | Kodak EasyShare DX6490 Digital Camera
Transferring pictures
Go into the Setup menu and select Copy. This will copy all images in internal memory to the memory stick.
Jan 27, 2010 | Sony Cyber-shot DSC-W100 Digital Camera
How do i take pictures out of the internal memory of my camera to put them into my computer ?
Hello my friend,
Here two ways to transfer pictures from your internal memory into your computer:
1- If you have also an external memory in your camera, you can move the pictures from the internal memory into the external memory from the camera menu. then you take out the external memory and you insert it to your laptop if it has a memory slot, otherwise you will need to buy an all-in-one memory cards reader, it's very cheap and it's the easy way.
2- if you don't have an external memory and you have the USB cable, you can connect the camera directly to your computer. but you will need to have also the CD ans install the camera software in your computer and then you can browse your internal memory directly from the computer and then download them.
Best Regards,
Oct 31, 2009 | Kodak Easyshare C813 Digital Camera
Cell Phones Logo
80 people viewed this question
Top ZTE Cell Phones Experts
Audrey Messer
Audrey Messer
john smith
Nyte_Ryder
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
