Question about Jacuzzi Home
I have a jacuzzi whirlpool tub in my home that has started to leak at the three button control panel. Flooded out the bathroom so I cut a hole in the tile surround and when the pump is running it leak
This is a 2003 model with six jets i don't have the model number
  • Jacuzzi Master
  • 717 Answers
First thing you need to do is remove some skirting so you can actually see where the water is coming from.
The 3 position control panel would only leak if the water was above it or covering it if it is located in the wall of the tub. That solution would only require the bather to NOT fill the tub quite so full.
IF however the water is coming from another location then that will be noticeable when you are checking for the water leak.
Posted on Feb 09, 2015
  • 14 Answers
SOURCE: Not all jets working on Hydrosystem Whirlpool Tub
I believe the below web site can help you with your problem. The jets are more then likely just turned off.
I hope this helps.
sanray
http://www.hydrosystem.com/hydro4/options/components/
Posted on Dec 27, 2008
  • 62 Answers
SOURCE: Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Posted on Jul 11, 2009
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
  • 80 Answers
SOURCE: jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Posted on Sep 28, 2009
slick fixer
  • 7 Answers
SOURCE: I have an aqualux whirlpool tub w/ cracked jet housing
yes i can do it call me 301 659 9968 rick
Posted on Oct 31, 2009
Where do you install a jacuzzi whirlpool tub indoors or out?
This unit has to go inside preferably a bathroom setting. The wall fixtures on the rear of the unit are proof enough of that. A plumber will need to install the unit as some bathroom plumbing will be required.
Apr 28, 2014 | Jacuzzi Home
Three button control panel for jacuzzi tub
Pull off all three knobs and then the plastic graphic rings and you will find 2 screws under each. After removing the screws the whole plate can pop off. If your problem is anything like mine, your air pump is full of water and needs to be replaced. After removing all the screws you can carefully pry it up with a thin tool, it is most likely caulked to the tub. You can find replacement parts and names for it here:
http://www.guillens.com/index.jsp?path=product&part=124772&ds=dept&process=search&text=JAC%20%20G107XXX
Hope that helps
Apr 28, 2012 | Jacuzzi Home
Our jacuzzi tub is 20 hrs old and possibly is leaking. About 6 mths ago we remodeled bathroom &replaced all tile around tub & shower. We do not want to tear out tile. What would be best way to pin...
if you have a water stain on the ceiling below your tub then you have a water leak. There is no easy solution for this. You must get to the underside of the tub in order to watch the jets when the tub is full of water to isolate the leak and then have it repaired by a plumber.
Aug 15, 2011 | Jacuzzi Home
How do i install an jacuzzi that has no faucet its a bathroom jacuzzi has no place for faucet it just has a hole for drain handle
either mount on wall or need to drill holes through jacuzzi 99 % of tubs dont come with faucets
Apr 24, 2010 | Jacuzzi Home
My jacuzzi bathtub plastics pipes underneath are leaking due to being chewed by rats. So if i fill up the tub to the jacuzzi line holes, water leakes through the chewed pipes on to the wood floor...
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
Feb 23, 2010 | Whirlpool 5"x36" White Bathroom Drop-in ...
I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
Feb 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My jets wont turn on
All the electric power source to all jacuzzi tubs all required to be protected by a "ground fault" device. Have you noticed special wall receptacles in your kitchen and bathroom that have 'test' and 'reset' buttons? There may be a receptacle (or something that looks like a receptacle but without any slots for plugs) near the tub. Push the reset button. If the pump for the tub has an access panel, the device may be behind the panel. And last, the circuit breaker in the main electrical panel may be a ground fault type and needs reset there. Good Luck
Jul 09, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Whirlpool tub not cutting off.
First I would remove the switch hose from the pump. Pinch the end of the hose over and hold it in place with a piece of tape. Depress the button and hold. If the button has little to no resistance then there is a hole in the air line which is causing enough air to leak that there is not enough force to activate the switch. If that is not the problem then just consider leaving the switch in the hole on the tub surface but adding a regular wall swich to the wall near the tub. This move the switch action from the tub to the wall. This a really cheap solution compared to getting a new switch mechanism which is what is broken for about $200.
May 23, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Home Logo
100 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
