Question about Holley 1985 Chevrolet Monte Carlo SS 5.0L Mechanical Fuel Pump
How do i fit 24s on my 1985 monte carlo ss - Holley 1985 Chevrolet Monte Carlo SS 5.0L Mechanical Fuel Pump
My 85 monte carlo ss does not go into drive until bout 3500 rpm why is that
If your automatic transmission fluid level is correct (check it first) ie.:with engine running, in park, engine at normal operating temprature, check dipstick. If OK: then it might be a dirty (clogged) transmission filter. Service the transmission, replace the filter and fluid.
Dec 20, 2014 | 1985 Chevrolet Monte Carlo
I recently replaced a rear brake line on my 85 ss monte carlo. I went to bleed the line and nothing came out. I attempted to bleed the other side and no fluid came out. When I replaced the line fluid did...
It should not be a mystery. Loosen one of the fittings on your new line to see if brake fluid is present. If so, the problem lies downstream from that point! Good luck!
Oct 23, 2014 | 1985 Chevrolet Monte Carlo
What all make and models steering columns will fit in a 1986 ss Monte Carlo
look it up at www.car-part.com they will show what they came from should be regals cutlass grand prix
May 16, 2012 | 1986 Chevrolet Monte Carlo
What is the firing order and distributer rotation for a 1985 Monte Carlo 4.3L V6.
1985 Chevrolet Monte Carlo 4.3 liter V-6 VIN "7"
and
1985 Chevrolet Monte Carlo 4.3 liter V-6 VIN "Z"
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Jose.
Oct 26, 2011 | 1985 Chevrolet Monte Carlo
Can you adjust the neutral safety switch in an 85 monte carlo ss
Yes...all you need to do is loosen the screws that hold it on and slide it. If you can't get it to adjust, it may be worn out though. Always check after moving the switch to make sure that it still will not start in gear and that the reverse lights are still working.
Nov 03, 2010 | 1985 Chevrolet Monte Carlo
Suspension
try the shocks first then see how it feels
Jun 07, 2009 | 1985 Chevrolet Monte Carlo
Why doesnt speedometer work on 87 chevy monte carlo ss?
AFTERA WHILE THOSE CABLES JUST WEAR OUT & SNAP.THATS THE MOST COMMON SPEEDOMETER REPAIR AT MY SHOP.WAS A DAMAGED CABLE ON THE OLDER CARS.
Dec 14, 2008 | 1985 Chevrolet Monte Carlo
Holley 1985 Chevrolet Monte Carlo SS 5.0L Mechanical Fuel Pump Logo
50 people viewed this question
Top Holley Plumbing Experts
bobalix
Gil Shultz
Jerry Kramer
Jerry Kramer
Are you a Holley Plumbing Expert? Answer questions, earn points and help others
