The tv shuts off after two minutes
Cleaned board.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
I would make sure the sleep timer function is not set to shut it off
Posted on Dec 07, 2014
Samsung TV shutting off by itself and relays clicking
If you don't know what you're doing, don't open it up to fix it!
There are HAZARDOUS voltages on the power supply board EVEN WITH THE TV UNPLUGGED!!! The capacitors can hold a charge for several weeks!
Clicking noise can be coming from bad capacitors on the power supply board.
It's usually easier to just replace the power supply board.
Sep 09, 2016 | Samsung UN55B8500 TV
Mitusbishi dlp tv shut off
hi when you replace the lamps, the lamp counter needs to be reset,thanks
shaun
Jun 28, 2017 | Mitsubishi WD-73737 73 in. HD-Ready TV
We have the RCA HD52w59 projection tv. The tv shuts itself off at different intervals. It takes approximately 1 minute to be able to turn the power button back on, however, I have to do that many times...
A problem in the deflection board. Could be a Cap. Resoldering the deflection board may take care of the problem. You need to call a TV man to do this kind of work.
Best of luck
Nour Sabre
WWW.AAATVSERVICE.COM
Jul 28, 2011 | RCA HD52W59 HDTV Projection Television
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Screen freezes and then shuts off. This cycles every 1-2 minutes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
May 14, 2010 | Toshiba 32HLV66 32 in. LCD TV/DVD Combo
Try the main board with the cpu chip. The cpu chip should have a heatsink attached to it, may be an overheating problem. It has the LCD panel connector plugged into it. You may be able to find the board on ebay for less than a repair shop.
Mar 23, 2010 | Toshiba 32HLV66 32 in. LCD TV/DVD Combo
I had the 7 blinking lights problem after tv shut
7 blinking Defective Board (possibility)
SC, SU, SD, P board (SC,SU,SD>D,P).
Connect
the connectors SC2(*2),
and SC20 to the SC board. Remove the SU board. Turn the TV on. Does the TV power up
and stay on IF YES REPLACED SU BOARD IF ON
Install
the SU board and
Remove the SD board. Turn the TV on. Does
it power up
and stay on? IF YES REPLACED SD BOARD
Feb 03, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
WD 52525
This is a sign of a failing capacitor set on the power board. there may have been a small or minimal pulse that went threw the set during the power outage and when the power was restored. this could also be overheating as well due to dust forming on the power boards components. i would remove the back cover and clean as much dust off the power board as possible with some sort of canned air if possible. make sure the cooling system is working properly as well.
please rate and god bless.
Mar 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Where is the air filter on my Panasonic PT50LCX64 TV and how can I clean it?
I have the same problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 05, 2008 | Panasonic Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
