Question about Video Game Consoles & Games
How to hook your game system up to a mercury montaneer
  • 1,249 Answers
Buy an oem integration kit how to hook your game system up to a mercury - 25310692-qjvctasbhmsa34yyzpjscfdr-2-0.jpg
Posted on Dec 07, 2014
1996 mercury mystique anti theft device engaged but i only have one key and cannot get it to reset
There is no reset other than unlocking the door with the key, if the system is active then a fault exists in it like a defective door ajar switch or other problem, you need a scanner hooked up to diagnose what in the system is causing the fault and lockout.
Jan 07, 2017 | Mercury Cars & Trucks
How do I hook up the Retro Duo nes/snes system to an older tv that has no a/v connections. I do have a Direct tv cable box but when I hooked the a/v cables to it absolutely nothing happened
Do you have a VCR that can hook to the TV that has the proper hook ups for your game system? Be sure your TV is on proper channel for your VCR to work (test it with a VCR tape and see if it plays) then change your channel on your vcr until it shows your game you have in your system hope that helps good luck
Dec 11, 2014 | Retro-Bit Retro Duo NES/SNES System Mascot...
1997 mercury montaner fan clutch has noise after installed
Defective fan clutch Return for replacement.
Aug 26, 2014 | Cars & Trucks
Montan transport plug on the fule pump
What do you need to know? Its located on the gas tank; its got to be plugged in to work; Red is power; what specifically do you have a problem with?
May 10, 2014 | Vehicle Parts & Accessories
P0410 pontiac montan 2001
The fault has to do with your secondary air injection system. They most likely cause is a bad air pump
Mar 05, 2013 | 2001 Pontiac Montana
Replacing caliper on 1997 sable, how do I disconnect emergency brake line from caliper?
The cables usually use a groove and hook system where the Emergency brake cables slide into the hook of the fixture on the Caliper. The assembly must be turned almost 90 degrees to slip the fixture into and out of the channel.
Jun 07, 2012 | 1997 Mercury Sable
Locking for drivers Hannah Montan
you only need the driver disc for a windows 98 computer or maybe linux os
Nov 27, 2010 | Disney Hannah Montana MP3 Player
What cord do I need to attach tv to super nintendo game system
Here is a tutorial to hooking up a super nintendo
http://www.youtube.com/watch?v=9O4kjcXyZKI
Oct 09, 2009 | Video Game Consoles & Games
Multiple game systems through home theatre
what you need to do is hook all of your gaming systems into the "in ports" on your gameing switch, then hook the set of cables you want to use to the "out port" then the other end of those cables need to go to the "in port" on the home theatre system (you can pick which in port you would like to use, it should say which is which on the back by the ports) after doing this you need to find the out port on the home theatre system that corresponds with the cables you are using ie, rca component or hdmi. once you find that port you need to hook a cable to that into your 'in port" on your tv., lastly turn on all of your gaming systems, your tv and your home theatre system. and on your home theatre system select which ever port you hooked the gaming switch into, then turn your tv to the correct channel that you hooked the cables into the tv, lastly go through each swithc on your gaming switch to be sure that they all work, if not, you might want to use all the same cables for all connections, ie, all component all rca or all hdmi, i prefer component.
Mar 29, 2009 | Philips MX6050D System
Hello i just purchased a 1999 mercury cougar and in the glove box was a hook up for a child restraint...it gave me little directions on how to use and the hook up but i followed those instructions and i...
I guess the first question is, do you need this? Your car is probably too old to have the LATCH system or the locking seat belt. The adapter that is provided is to lock the seatbelt to keep constant tension on the seatbelt when extended over the child in a booster seat. Is this the adapter you are trying to use?
Oct 24, 2017 | 1999 Mercury Cougar
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
