Question about Janome Memory Craft 10000
My needle is hitting the metal part of the bobbin case. How can I fix it?
  • Janome Master
  • 627 Answers
Replace the needle first. If this doesn't stop the problem you will need to have the needle arm adjusted so it won't hit it. This will need to be done at your pro's shop.
Posted on Dec 07, 2014
Needle was hitting bobbin casing - reply was that the machine needs a hook timing adjustment - can I make this adjustment or do I need an expert?
Sounds like it's advanced.... but take it in and have it done professionally... have him lube and clean and check for cracked parts while you are at it.
Dec 29, 2012 | Singer Sewing Machines
I took out parts of bobbin to clean and when put them back the needle hits the metal of the bobbin case and i cant sew. it doesnt seem to be properly aligned.
Perhaps remove the bobbin case and check that you have put it back correctly. Check with the sewing machine manual to see how it is done correctly. Make sure that the top of the bobbin case is at the top of the bobbin case holder and make sure you change the needle as it will probably be dull or bent from hitting the metal of the bobbin case.
Aug 27, 2010 | Bernina Activa 130
Re-curring loose bobbin case
According to the manual, this is a drop-in bobbin.
If the bobbin case came loose, the needle would probably hit it and brake.
Take the bobbin out.
Turn of the power and remove the needle plate (under the presser foot).
Raise the needle to it's highest position and lift out and reset the bobbin case into the shuttle. This should be in the maintenance section of the manual. The bobbin case should fit snug.
Make sure the thread is feeding from the bobbin, counter-clockwise and through the guides on the bobbin case.
For a rotary bobbin with a metal bobbin case.
Remove the bobbin case. Make sure the thread is feeding clock-wise and through the guide on the side of the bobbin case.
Raise the needle to it's highest position - this puts the hook at the lower left. Left the tab on the back of the bobbin case and slip the bobbin case back into the shuttle with the "arm" straight up. You may have to move the bobbin case a bit to the left or right for it to snap into place.
If the problem persits, take the machine back to the dealer - there should not be a charge for fixing this as it is brand new - keep your receipt and warranty information at hand.
Apr 24, 2010 | Singer 7442 Mechanical Sewing Machine
New Problem...I have a Singer CG-550. When I try and sew anything, the needle hits something inside where the bobbin is. The little black casing holing the bobbin keeps moving all over the place, I slip...
On the right of the black bobbin case there are two screws, you can slacken those screws off and move the bobbin case nearer to the guard leaving enough room for the thread to pass through, if the needle is hitting the bottom you may need to retime the machine.
Mar 06, 2010 | Singer Sewing Machines
Needle hits the bobbin casing.
check to see the bobbin is in correctly first, is the needle in the centre?
Nov 23, 2009 | Sewing Machines
Bobbin Case Spins - in Huskystar C20
I had this problem when I first bought my machine. I took it in and they told me it was a recall problem. All the machines were having the same problem. They fixed it and I have not had the problem since. I bought mine at a Joanne fabrics. Hope this helps.
Mar 21, 2009 | Husqvarna Viking 1
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
Needle hitting metal casing .. Singer Futura CE 200
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
Feb 22, 2009 | Singer CE-200 Quantum Futura Computerized...
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
63 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
