Question about Dryers
Can I replace the plug *only* on this range with a 3-prong plug? I believe I need a copper strap to ground from the neutral wire on the back of the range to the frame, but I want to know if it's OK to just do that and leave the green ground wire connected to nothing on both ends. And then, can I just buy a copper grounding strap at Lowe's and attach it to the neutral wire and frame anywhere?
  • Meriah Crawford
    Meriah Crawford Dec 07, 2014
    And the system decided it's a dryer.
  • 5 Answers
You should buy an actual range cord for about $15 because if it doesn't meet code and something happens it will void your warranty or worse your homeowners may not cover any fire damage. Good Luck.
Posted on Dec 07, 2014
Testimonial: "Thanks. (There's no warranty, though--it's used.) What about the ground on the back of the range? I can't just leave that as-is, can I?"
When you buy a new appliance that needs a cord, usually the screw that connects the neutral (white wire) is bridge with the cabinet or ground,with a piece of copper, that should be removed when you are going to install a 4 prong cord and the green from the cord goes to ground or chassis.
Neutral and ground have the same potential in normal condition.
Since 4 prong is safer than 3 prong, and is required to meet code,
I suggest replacing the female plug for a 4 prong instead.
Dec 07, 2014 | Dryers
Tip
3-prong to 4-prong Power Cord Conversion.
This advice is on how to correctly install an ELECTRIC DRYER or ELECTRIC RANGE 220-240VAC power cord (US Standards).
3-Prong or 4-Prong – The Difference:
3-prong color code:
BLACK (HOT – 110-120VAC) – May also be referred to as L1
RED (HOT – 110-120VAC) – May also be referred to as L2
WHITE (NEUTRAL – 0VAC) – Usually grounded to the equipment frame via a jumper wire or metal strap.
4-prong color code:
WHITE (NEUTRAL – 0VAC) – DO NOT ground to equipment frame.
GREEN (GROUND) – Attach to equipment frame.
Which One to Use: According to the National Electrical Code (NEC), Article 250, installations after the year 2000, require the use of a 4-prong plug which incorporates a separate ground and neutral wire. If you currently have a home that uses the 3-prong receptacle and cord, you can continue to use it. You will have to upgrade to a 4-prong configuration, however, if you plan on relocating your current receptacle, or if the internal wires of the receptacle become damaged in any way and require repair.
Converting from 3-prong to 4-prong: Make sure you UNPLUG the appliance prior to any repairs. CAUTION: Voltages dangerous to life are still present even with the appliance turned off and still plugged in. Notably in the area of the terminal block where the power cords are installed. You will need to remove the old cord by following these steps:
  1. With the appliance UNPLUGGED, remove the access panel on the back of the unit where the power cord enters.
  2. With the cover removed, you will see a terminal block where the power cord is attached. The terminal wires will be colored with the WHITE wire in the middle, and the BLACK and RED wires on either end. NOTE: There should be a green jumper wire or metal bonding strap attached to the NEUTRAL (white) terminal wire.
  3. Remove the terminal lugs holding the old power cord wires in place. CAUTION: Use care not to drop any nuts or screws inside the appliance.
  4. Remove the bonding strap or ground wire from the Neutral terminal lug. NOTE: If disconnecting a ground wire, make sure you re-attach it to the appliance frame.
  5. Loosen the screws on the strain relief connector that holds the power cord in place and remove old power cord. NOTE: If your appliance does not have a strain relief that clamps down and hold the power cord in place, it is highly recommended that you install one. This prevents chaffing of the power cord against the appliance casing, and prevents the terminal wires from being pulled and broken loose. This could pose a potential shock hazard or cause damage to the appliance.
  6. Install new power cord by threading it through the strain relief connector and tighten down the screws.
  7. Connect the new power cord to the corresponding colors at the terminal block (Black goes to Black, Red goes to Red, White goes to White). The difference is going to be a Green (ground) wire that will connect to the appliance frame. There’s usually a green grounding screw for this. NOTE: If you disconnected a green grounding strap in Step 4., you can connect these two wires at the same point.
  8. Re-install access cover. Turn off the service breaker to the appliance PRIOR to plugging it back in. With the breaker in the off position, plug the appliance in, and THEN turn the breaker on. In the event, something was wired incorrectly, it is far better to have your hands away from the receptacle and controlled from a distance. Safety first.
on Jul 16, 2008 | Whirlpool LER5636P Electric Dryer
Can I replace the plug *only* on a Whirlpool Super Capacity 465 range with a 3-prong plug?
there should be a short metal strap or the center lug itself connected to the body of the range from factory you only need a four wire cord if you are in a modular or mobile home then connect green wire to any screw on range body itself such as at large wire clamp where cord enters body of appliance
Dec 07, 2014 | Whirlpool Kitchen Ranges
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
How do I rewire my three prong plug to a four wire plug in a LE8860xwqo?
The following link explains step-by-step how to install a power cord to your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference in these two configurations is how the Ground wire (GREEN or BARE COPPER) and Neutral (WHITE) wires are terminated at the terminal block on the back of the dryer. In a 3-wire configuration Ground and Neutral are connected together via strapping option. In a 4-wire configuration these two wires are independent of each other and are not terminated together.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Dec 02, 2009 | Dryers
I have a three prong plug in connected to my dryer and need to connect a four prong one but dont know which wire is which.
Nov 30, 2009 | Dryers
Have ge dryer changing from 3 prong power cord to four prong need diagram
The main difference between a 3-wire and 4-wire configuration is how the Neutral and Ground wires are terminated at the temrinal block. The following link explains:
In a 3-wire configuration Neutral (WHITE) and Ground (GREEN or BARE COPPER) are terminated TOGETHER at the terminal block via a ground strap.
In a 4-wire configuration these two wires are independent of each other are NOT terminated together.
If you have questions, please let me know. I hope this helps you.
Nov 28, 2009 | GE DBXR463EBWW Electric Dryer
I need to go from a 4 prong to a 3 prong plug. do I go black to black, white to white, ground?
A 3 prong will be : left to red , center to white , and right to black . Doesn't matter which is left or right , as long as the center goes to white . There is no green on a 3 prong cord , only 4 .
Oct 31, 2009 | Kenmore Elite HE4 Electric Dryer
I have a new 4 prong plug to replace a old 3 prong on dryer
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
Dryers Logo
43 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
