The drum in my front loader washing machine appears to have come loose and is making a loud banging noise
Re-setting the machine turning it ona and off
  • Washing Mach... Master
  • 1,249 Answers
Call a repairman if you don't want to fix it yourself. It is gonna need a lot. Is it still under warranty? you could get a free repair. the drum in my front loader washing machine appear - 25310660-qjvctasbhmsa34yyzpjscfdr-2-0.jpg
Posted on Dec 07, 2014
SOURCE: Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Posted on Jul 15, 2008
  • 176 Answers
SOURCE: It appears that my front loader drum is loose and
Your shock absorbers are problably broken and need to be replaced. Take off the bottom inspection panel by removing the 2 screws on the bottom of the panel and pull the piece down and out. Then take a look inside the machine in the bottom middle on both sides. There should be a shock absorber on each side and these are plastic. Check to see if they are broken at either end and if they are, go to your local appliance repair shop and buy/order a new pair. The new ones are slightly upgraded by making the body out of metal and the rest out of plastic. Instalation instructions come in the package as well as a pair of new absorbers. Hope this helps.
Posted on Aug 13, 2009
  • 256 Answers
SOURCE: Very loud banging noise when front load washing machine spinnning
Ensure that the appliance is balanced/level on the floor. Contact an appliance service company.
Posted on Feb 22, 2010
djz83
  • 88 Answers
SOURCE: Whirlpool 9250 washing machine front loader makes
my first suggestion is to get your money together cuz either way it's gonna cost alot. Touch the drum in side the washer and check to see if it moves around. If it does then you probably need a new drum and bearing job which is usually pretty pricey to repair. It an overhaul of your washer.
Posted on Jul 02, 2010
TheMobilian
  • 8220 Answers
SOURCE: Drum inside washing machine seems
Might be a spring or the skate plate out of alignment.
Thin twin service manual is in this apartment series service manual:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZDgzODI5MjYtMWNmYS00MWZkLTk0ODEtNjM3MTIyYzVmZWVl&hl=en
Posted on Sep 20, 2011
Machine making loud noises w6863 front loader
could be that the wights are coming loose on the drum turn the drum by hand and see if you can feel any movement in the drum if yes get them looked at also try some oil on parts
Oct 12, 2014 | Washing Machines
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
The drum is moving front to back and making terrible noise
The retaining nut/bolt for the drum has come loose. Remove the back cover and check the drum axle and attachments.
Jan 21, 2011 | Frigidaire ATF6000ES Front Load Washer
Whirlpool 9250 washing machine front loader makes a loud banging sound everytime the drum is turning like something is loose in the back. Any suggestions?
Jul 02, 2010 | Washing Machines
My MAH9700 Front Loader washer is shaking a lot and making a loud banging noise when spinning.
unscrew the 4 screws inside the detergent dispenser and lift the top and see if the counterweight on the tub is loose,otherwise it may be the drum bearings going bad on the inner drum
Apr 01, 2010 | Maytag Neptune MAH9700 Front Load Washer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Loud banging when spinning
but a small load in . if happen then it sounds as if the bearings have gone at the back of the drum.
May 12, 2009 | Washing Machines
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
