Question about Toys
Would like to check on a order. Yes
I ordered two Thomas the trains, Electric, about 3weeks ago. Have not received them yet.
Thomas only runs on power track
PDF]EZ Command instructions.qxd - Bachmann Trains
www.bachmanntrains.com/.../EZ_Command_instru...
Bachmann IndustriesINPUT: 120 VAC 60Hz. OUTPUT: AC 16V 1000mA ... After the track connections are complete, plug the Wall Pack Power Supply into a standard 110 ... If your Control Center does not power up as shown here, disconnect it from the Wall Pack ...
[PDF]5 Amp Power Booster - Bachmann Trains
www.bachmanntrains.com/.../449105-AMPInstructi...
Bachmann IndustriesNOT RECOMMENDED FOR CHILDREN UNDER 14 YEARS OF AGE. ... The E-Z Command® 5 Amp Power Booster provides extra power to the track so ... locomotives on our N, HO, OO, S, O, On30, or Large Scale layout. ... Make sure the smaller plug end is connected to the DCC input jack marked DCC IN (figure 2) on the.
Jan 08, 2016 | Bachmann Ho Bachmann Thomas and Friends...
Orders not received
I still have not received my order as of today. Please check on this shipment! thank you,
Thomas S. Pyle
310 801 2416
Jan 06, 2014 | Crafts & Hobbies
Electric train set stop and goes when it goes over certain parts of the tracks do I need to clean the tracks or the wheels and what do I use to correct this issue?
1: make sure all track connections are tight.
2: clean the track using a Green 3M scratch pad
or a track eraser.
3: clean your wheels, some people use smoke fluid
on a cloth, I use alcohol prep pads,. A track eraser
can also be used. there are commercial wire brush
cleaners that connect to your power source.
Nov 05, 2011 | Bachmann Thomas the Tank Engine Train and...
I would like to get a printable copy of thomas and friends trackmaster zip&zoom instructions i cant find mine help!?
I can't take the credit, somebody else already posted this, but i'll repost it for your convenience:
http://service.mattel.com/us/product_detail.asp?id=R9634&Ntt=R9634&Pn=1&Brand=Fisher-Price+Friends&Cat=Thomas+The+Train+TrackMaster
The page has a link for a printable pdf copy of the instructions, and a link for ordering any parts which may get damaged/lost.
Hope it helps
Mar 23, 2011 | Samson Technology Thomas Trackmaster Zip...
I have the Thomas and Friends Trackmaster talking Thomas train. 2 days after I bought it he stopped working. I changed the batteries and now he only talks. He wont move on or off the track at all?
I brought one a few days ago and out of the box it talked but would not move. I returned it to the store for a replacement. I noticed that the back wheels under the on and off switch have weight on them before the train will move. If the train is not sitting on the track, it will not move, That is what makes thomas stop at the station
Nov 11, 2010 | Thomas and Friends Trackmaster Motorized...
Thomas train peg perego instructions
have to hold on the button that has arrow untill it moves
Apr 03, 2010 | Peg Perego Ride On Santa Fe Train
Thomas train charge battery has music and sound effects, but does not move?Does it need a new motor
It might need a new wire connection to the motor.
I would contact
http://www.shopjandl.com/
They help me with my ride on toys.
hope this helps
Jul 15, 2009 | Peg Perego IGED1084 Santa Fe Train
Peg Perego Thomas Train Track Rider
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Mar 12, 2009 | Toys
The red button on the right must be held down for anything to move. It turns the lights on, makes some train noises, then moves forward. If you don't hold the button down, nothing will happen. Note that when the train is underway, the left red button becomes a train whistle. Otherwise, when the train is not running, that left button produces music. Hope this helps.
Dec 16, 2008 | Peg Perego Vespa Scooter
Toys Logo
42 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
