Question about Samsung Dryers
I changed the belt on my samsung dv219aew/xaa dryer. Put the dryer back together tested once and worked fine. I put a load of laundry in and pressed start and then the power cut off. No lights to control panel. Any suggestions? Thank you
If the belt snapped there is usually a reason
some jam up
check that and also there is a capacitor a round white tube
with two connections to it usually bolted too the motor
replace this part
you may find the heating system has a reset feature or thermal fuses
also you may need to replace the mains fuse in the plug or etc mains supply
i think as you put a load in and it cut out
then the start cap is prob short and has blown the fuse
Posted on Dec 09, 2014
SOURCE: Dryer suddenly stopped - F&P ED56 Autosensing Dryer
I have a Frigidaire Gallery model GLER341AS2.It was working fine this morning and I tried to use it tonight and it will not do anything.The light inside does come on but when I push the start button there is nothing,no sound,nothing at all.Please help.Thanks.
Posted on Apr 07, 2008
  • 686 Answers
SOURCE: Dryer was working fine then quit heating
go to www.repairclinic.com enter your model number and your parts will come up for you to see. And to see what they look like good luck
Posted on Mar 12, 2009
SOURCE: Kenmore Elite Electric Dryer, Model # 110.8586400,
No power and it keeps triping the breaker.
Posted on Dec 13, 2009
ginko
  • 19396 Answers
SOURCE: Whirpool GGw9250Pw3 no power on Control Panel Inside light works
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
Posted on Feb 22, 2010
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin ยท Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
Samsung dryer dv219aew/xaa will not start , has
-Mostly starter is burn out . replace new one.
-Att! Disconnect power before work on!!
Good Luck
Mai
Sep 18, 2014 | Dryers
Dv337aer/xaa samsung dryer it had a t0 code i replaced the thermister. now i start it and all i hear is clicking, no spinning to heat? what should i do helppppp
You may have not put the belt on properly. These have a belt switch on the pully. So if it's installed wrong it'll pop off the drum causing the unit to be idle.
Nov 07, 2013 | Samsung DV419AGW Dryer
My heating element needs to be replaced where can i get the part n what part is it my dryer model is dv219aew/xaa
If you will type "sears parts" into your computer, you will find a space for you to type in your model number.
Yours is a Samsung dryer, and there is a picture of the heating element for you.
Once you get that number off that picture, you can shop for your part at many other places, including "e-bay".
Be blessed.
Feb 07, 2013 | Whirlpool Dryers
Samsung DV210AGW/XAA Dryer, drum wont turn nor heat up
hi all, thanks for your comments. to note, it's my dryer not my washer so the suggested solutions wont work. Also, forgot to note, the unit is only 14 months old and just out of warranty. What I've done so far:
- vacuumed the filter
- striped the dryer, meaning removed top. front and small exhaust panel in the back
- vacuumed everything
- checked the belt, tight, not loose, broken or off the roles
- child safty not enguaged, toggled it anyway to be safe
- the checked micro switch next to belt by motor, not engaged
put it all back, turned on with nothing, tried every setting in auto and manual tied high to low temps and times, the time is noted, such as 40 min, but does not time down, over time, the unit sound the I'm done tone, if left as is, continues to chime then end like it did something. all along, the drum never rotated nor did it heat up.
Does one impact the other, such as if the drum does not roll then the heater wont start or vise-a-versa. Could the control panel have taken a hit or are there sensors that might have shut down to prevent the unit from starting are there fuse's that I didn't see that might have been tripped.
Jan 04, 2013 | Samsung Washing Machines
I need to replace the belt on my dv209aew dryer, I need to take my dryer apart and put it back together
Hi lisavawter...
Your best bet is to buy a service manual, so it will tell you everything you need to know about servicing your dryer...
You can get one at this webpage...
Please take time to rate me
http://www.samsungpart.com/Products/Parts_and_Accessories/DV209AEW/XAA/Default.aspx
Aug 12, 2011 | Dryers
I have a DV219AEW/XAA dryer and it does not heat up its electric , has power but does not heat thanks john
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Mar 21, 2011 | Samsung DV219AE Dryer
Jan 13, 2009 | Whirlpool GEW9250 Electric Dryer
I need a belt for my samsung dv 4006 dryer
Yes!
Global electronic supplies Inc
5600 Timberlea BLVD
Mississauga ON
L4W 4M6
1-800-668-8776
Feb 15, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Dryers Logo
100 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
