It claims "out of paper" when it isn't - Office Equipment & Supplies
  • 1,915 Answers
What kind of printer? Chances are you either have stuck or broken flag in the paper path.
Posted on Dec 07, 2014
My HP photosmart c4280 all in one printer is saying "out of paper" when it isn't out of paper.
Hello Jodi,
HP disagrees with your "NO rear door"... assessment...
For your reading pleasure I am attaching YOUR
OWNERS MANUAL... Page 15:
HP C4280 Photosmart All in One Color Inkjet Basic Manual Clear Paper Jams
Look at the picture.
Hope this helps.
Carnac the Magnificent
Aug 12, 2017 | HP Photosmart C4280 All-in-One InkJet...
Printer is in alarm mode stating a paper jam when there isn't one?????
Even though u cant see a jam there there is exactly a jam inside
U believe it or not thats why paper jam
Look for the paper detection sensor below the carriage
use ur common sense
I cant say exactly it is detect sensor it may be some other sensor related to gear wheel set
but most of the cases paper jam occurs due to malfunction of paper detect sensor
If u find it use a thin tool to see it is working properly
otherwise give it to someone know how to repair & pay a reasonable price
thx
Sep 17, 2012 | Canon PIXMA MP280 Photo Inkjet All-in-One...
Toshiba estudio 161 don't change paper tray
THERE ISN'T PAPER IN TRAYS OR SWITCH OFF ON PANEL
Apr 28, 2012 | Toshiba Office Equipment & Supplies
Shock
Does your plug have the 3rd ground plug on the cord? If yes, does the switch have the paper insulation wrapping around it? Something isn't being grounded correctly.
Jan 30, 2012 | Master Appliance 14 Amp 1680 Watt Heat Gun...
I have a paper jam in my OfficeMax paper shredder. How can I fix this problem?
Usually for a jam you just need to reverse it. If it is really jammed you may have a staple caught in there or too many sheets of paper. If you unplug it and then see if you can pull out the jam. If it is a staple you may need to use needle nose pliers to get enough of a grip to get it out. If this has seen heavy use and lots of multiple pages then you could have burned out the motor. These are not much more complicated that scissors so there isn't much to do to fix them. Most don't like staples or more than 2-3 pages max at a time (if that many) even if they claim more than that.
Sep 08, 2011 | OfficeMax Office Equipment & Supplies
The print is great but the printer is curving both ends of the paper up. It seems like its going through too many rollers ?
the problem could be in too much moisture on paper. Try to insert new fresh paper or flip upside down the existing paper in cassette.
Also if the paper isn't fixed in cassette by means of paper holders on each side, paper can go loose while pick up and cause corners and scratches.
Also this can happen if something is in paper path, for inspection you need to dismantle half of printer... call service if isn't problem in moisture of paper.
Aug 24, 2011 | Canon MF8350Cdn AllInOne Laser Printer
My goldstar R2403 doesn't seem to be pushing out as cold as I feel it should we just had the unit refirbished and they claim it was running ice cold sitting on the bench in repair shop, however we have...
The link below is for the Owners/Service Manual for your model Goldstar AC unit. It should be of tremendous help in troubleshooting and solving the problem. Either by you. or your maintenance man.
http://www.appliancefactoryparts.com/content/pdfs/118630.pdf
Hope this helps you.
Jul 20, 2011 | Goldstar R2403 Air Conditioner
I just recently spent over $700.00 at a shop to get my car fixed, now it won't even run it has no power when accelerating it knocks,sputters & dies. Would this happen if the timing was set on...
If timing is set on the exhaust stroke the engine will back-fire and not start unless the wires are moved in order to compensate for that. (that can be done but gets really confusing if anyone else works on it) On yours, I actually think you cant, 'cause there isn't a distributor? (depends on engine).
It's incomprehensible that a shop would let a job out the door without making it run right.
In fairness, I'd give them a chance to fix it, make sure you have proper documentation and have someone else do the repair if they can't. Then, your next stop is small claims court or in some states the DMV will investigate your claim first.
As for what actually is wrong, no one can tell you without a hands on diagnosis....just too many things there that all work together.
Hope it turns out well for you though!
Jul 11, 2011 | 1999 Pontiac Grand Am GT
The mobile switching off & the bettery isn't low
I think your battery is loosen that's why it turns off even your not turning it off..Try to put a small paper on the battery case cover so that it put a little pressure to the battery so it will not loosen and to avoid untimely shutting off of your cellphone..Hope it will help you.
Jul 11, 2011 | Samsung Star GT-S5233 Cell Phone
When trying to print getting error Paper Jam in Manual Feeder. There is no Jam...we tap the side of the machine and it prints....any Ideas on what causes this to happen?
There is likely a loose connection going to the manual feed paper sensor.
The printer thinks there's paper in the manual feed, but of course since there isn't any paper there, when it tries to feed the paper in from the manual feed, the next paper sensor is not tripped, so it assumes there is a jam in the manual feed.
Start testing at the manual feed sensor, and work your way back to the board it connects to.
It may be the sensor itself just needs to be cleaned - these sensors are usually optical, and spraying canned air at it will often fix it up.
Also, make sure the lever that trips the sensor isn't sticking after using the manual feed.
Apr 11, 2011 | Samsung SCX4623F Laser All-in-One Printer
23 people viewed this question
jasbo
jasbo
