Washer is stuck with on light flashing, but it won't spin, rinse, anything. I've unplugged it completely for over 20 minutes. the electronics won't reset like it says in the manual. Nothing will cause
Unplugged entire unit for over 20 minutes three times. Turned washing knob to "off" setting. Opened and closed door repeatedly. removed all clothing. Turned back on and left it sitting for an hour. Nothing will turn it off (except unplugging) or reset it.
  • 3 more comments
  • Brad Brown Dec 07, 2014
    Hi Deidra Neal, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the make and model?
  • Deidra Neal
    Deidra Neal Dec 07, 2014
    http://www.homedepot.com/p/GE-Unitized-S...
  • Deidra Neal
    Hi Brad and thanks - the above is the make and model. I unplugged again, and this time when I plugged it back in, I held in the start button. It appears to have reset the machine, and now the machine will perform every function except for spin - it just won't spin at all.
  • Deidra Neal
    In fact, it's gone through a small wash cycle, and it's now on spin, and it's just sitting there not spinning. Not clicking, not draining, not spinning. Nothing. With the spin light on.
  • Deidra Neal
    I've tried to edit this question and cannot make changes.
  • Washing Mach... Master
  • 1,249 Answers
New sony guts
Posted on Dec 07, 2014
Cotton program stuck on wash cycle with 1 minute left
Control board needs to be replaced. Many times the control boards go bad because of a spike in the electrical grid cause by a brown out, lightening strike or even a surge in the power. After the control board is replaced... I suggest using a surge protector on all of your electronic devices including the washing machine.
Feb 06, 2014 | Hotpoint Ultima WF865 Front Load Washer
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
Front load washer stuck on final spin
What is the complete model number of your unit?
Dec 10, 2012 | Washing Machines
Hello, Re: frontloading washer Model C45172 Our washer has been operating withiout hitch since purchase about five years ago, We love it. Today I tried to program it to do an extra rinse after wash...
For the Elite (HE) machines:
Press 'STOP' twice, press 'POWER', choose a wash cycle (such as 'NORMAL'), select wash options (water temp), press 'START' to finish the reset sequence.
Other Kemore electronic washers:
Unplug the machine for a minute, plug it in. Press 'PAUSE/CANCEL' twice.
Good luck from Detroit, MI.
Jun 12, 2011 | Kenmore Washing Machines
When washer done rinse cycle lights flash and washer stops doesn't rinse and spin
Hello
Try reseting the machine.Unplug power for 60 seconds.
Plug back in,then turn knob to reset.Then try another load of wash or finish the one that is stuck before rince cycle.
It is possible the control timer is going bad.
Aug 29, 2010 | GE Washing Machines
LG tromm washer stuck in rinse cycle
  • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
Fisher paykel will not complete rinse spin cycle
will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
Dec 31, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Mother board scans
    possible issue with key or otherwise know as user interface..it is actually a conbination of keypads and electronic componets..pad could be stuck or actual interface computers scrambled
    Apr 26, 2008 | Kenmore Oasis HE 27082 Top Load Washer
    Washing Machines Logo
    55 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
