How do I turn off my Iwave4000mah power bank?
The buttons on the side I don't know what else to do
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 139 Answers
Unplug
Posted on Dec 12, 2014
Nexxtech power bank, how do I charge it
On the side where it says IN, is a micro USB connector. Put in the connector from the cable that came with the power bank, and put the other end of the USB cable in an external charger, or a PC USB socket of which you are sure it delivers 5V. You should see the bleu lights on the IN side flicker, and one by one they start burning continuously. When all 4 burn continuous, th bank is full. Discharge goes on the other side and you have to press the button, to start the charge cycle.
Perhaps you also should see what is on Youtube about the power bank :
Nexxtech USB Power Bank Quick Look
Nov 02, 2014 | Televison & Video
Which side is bank 1
Follow the #1 spark plug wire down to the spark plug. That is bank 1.
Jan 10, 2014 | Cars & Trucks
Blade MQX QUAD-COPTER
It's difficult to determine witch trim buttons effect the props. The only way to do this is durring flight. At low power, since you are working with 4 axis, each set of 2 buttons will effect the rotational speed of 1 motor. Typicaly in this set up, the left stick will control power and yaw(up and rotation left and right), while the right stick controls direction and pitch.(forward/reverse and bank left or right) Here is what I think you need. The left side bottom butons, control horizontal control. If you take off and notice the helo going to the left(banking, not turning) click the right button to attain horizontal stability. If you notice it is going slightly forward click the bottom button on the right side of the left stick. The same can be said with the axis control on the right stick. I hope to see this aircraft on youtube, as there is a shortage of these flying stabile anywere. good luck.
Apr 22, 2013 | Toys
I have three charges of vendosupport.com on my bank statement. I don't even know what it is & I did not subscribe to this. Whats going on?
Call 877-777-3758 Vendo Support Cust Svc and talk to them
THEN call your bank and report abuse of your banking account and that you did not authorize payment. Be sure your children did not do it behind your back. Your bank SHOULD investigate and refund your money. I've had to report lots of irrefutable scams and spam to my bank. I've a system analyst and my bank clerk is used to my calls now.
Don't take NO for an answer either from Cust Support or your Bank
GOOD LUCK
Sep 19, 2011 | Computers & Internet
Check Engine light problem. P0431 code problem. It's already being determined it's the oxygen sensor. But which one? Is it Bank 2 or Bank 1. If it's one of the Banks is it before or after the...
O2 Sensor codes are usually in the P0130- P016x range.
P0431 is Warm up catalyst efficiency bellow threshold Bank 2
Don't know what you're working with so just figure bank 1 comes off the bank with the number 1 cylinder.
Aug 30, 2011 | Mitsubishi Montero Cars & Trucks
I have a 2003 Mountaineer v-8 AWD with "check
Left side,Drivers side
Either in the converter inlet or just ahead if it
Bank (1) Pass Side
Bank (2) Drivers Side
Sensor (1) closest to engine
Sensor (2) monitor sensor in outlet of converter
An O2 Code does not mean it is bad or needs to be replaced.
Could be any number of other causes that set a MIL Lamp
on dash
Aug 18, 2011 | 2003 Mercury Mountaineer
Where is O2 sensor bank (sensor 3) located on the engine? Maube a picture? dave g
Bank 1 is the side that has Cylinder # 1 (drivers side on your engine) Sensor 1 is the one BEFORE the cat. Sensor #2 is AFTER the cat. Bank 2 is the side that has Cylinder #2 (passsenger side on your engine) and again sensor #1 is BEFORE and sensor #2 is AFTER. I have seen dodge use a 5th one on the V10 after the two exhaust pipes are joined together. that's the only place a #3 sensor could be that I know of. I don't know if they did this on the 5.2 V8.
Jun 24, 2011 | 1998 Dodge Dakota
I've an up stream o2 sensor for my truck but i don't know where on the front of engine it is located. Can you help me out with some kind of picture so i can change it out?
This actually depneds on which one you need to change. Each side of the engine will have considered the number one sensor but you will also need to know whether you need bank 1 or 2. Bank one has the number one cylinder/spark plug. Let me know if you need anything else.
Jun 07, 2011 | 2001 Chevrolet Silverado
Canon error p08 Problem
Follow the instructions step by step
1. Turn off printer, cable power still plug in,
2. Press Stop/Reset button don't release
3. Press Power Button don't release and than release Stop/Reset button
4. Press Stop/Reset button 2X , wait until service mode to " 0 "
5. Turn off printer, cable power still plug in
6. Press Stop/Reset button don't release
7. Press Power Button don't release and than release Stop/Reset button
8. Press Stop/Reset button 4X , wait until service mode to " 1 "
9. Turn off printer, and loose cable power, wait one minute.
10. Connect cable power, turn on printer again, now this printer ready to use.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 10, 2011 | Computers & Internet
A bank of blinking leds??
The blinking LEDs means it need to have it's ID reprogrammed. Press the Program button and then the station number (Station 1 or 2 or 3 etc) to store the setting.
Nov 14, 2007 | Panasonic KX T3281W Corded Phone...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
