Question about Hardware & Accessories
How to set a timer K175C Eveready
How do you set the K175C timer
How to fix the switch on eveready lantern flashlight
The switch in the lantern is a press fit switch so you will destroy it when you remove it. Remove the lense and retainer ring. Remove the battery. With a pair of pliers, preferably channel lock water pump pliers crush the switch into small piece and discard. Trail Tech makes the exact water resistant switch model 040-ls-b and you can get it at Amazon or on eBay . The switch runs around $6.25 + $4.00 shipping
Jul 11, 2014 | Energizer Eveready Utility Lantern Uses 6V...
Gardenmate tap timer
this kind of machine they need a traction battery
Nov 27, 2013 | Garden
Lens stuck
Forget standard batteries in this camera. I tried a "new" set an inexpensive Eveready 1215, don't do it. Get a set of Duracell Alkaline. When I did that it powered right up. Go figure.
Jul 20, 2013 | Nikon COOLPIX L810
Wheres the expiration date on a eveready D battery?
Printed on the side or embossed on the bottom of the cell.
Apr 25, 2012 | Energizer Eveready TUF4D1E 4D Cell Lantern
What kind of battery does my Canon AE-1 take?
The AE-1 uses one 6V battery, either a silver-oxide Eveready 544 (or equivalent) or an alkaline-manganese Eveready 537 (or equivalent).
If you need a manual, you can download one from
http://butkus.org/chinon/canon/canon_ae-1/canon_ae-1.htm
Jan 26, 2011 | Canon EOS-AE-1 35mm SLR Camera
How do I change the bulb of the 6V Eveready Lantern?
If it is the yellow floating lantern you have to remove the black plastic stub on the underside of the reflector using needlenose pliers to wiggle and slightly pull until it releases and the bulb will come out.
Jan 06, 2011 | Energizer Eveready Utility Lantern Uses 6V...
What type of battery does it use?
The XG-A uses two 1.5v alkaline-manganese (Eveready A-76 or equivalent) or 1.55v silver-oxide (Eveready EPX-76/S-76 or equivalent) batteries.
Do not use 1.35v mercury batteries (Eveready EPX-675 or equivalent), which have a similar shape.
Aug 22, 2010 | Minolta XG-A 35mm SLR Camera
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
