Question about Woods Hardware & Accessories
How to reprogram Woods RF1112T
How to program the controller for the Woods RF1112T ?
Need help programing lllwoods model 50000 indoor 24 hour mechanicl timer 2-c
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
http://waterheatertimer.org/Woods-timers-and-manuals.html#50006
If you have the digital timer, generally you can toggle DST back-and-forth 1 hour by pushing two buttons simultaneously for 3 seconds. And then reverse the setting again by pressing and holding both buttons again.
Open link. Download manual. Look for 'daylight savings time' in manual. Read instructions.
You can unplug timer to make programming changes, since the timer has a carryover feature against power outage.
To restore functionality of a timer that no longer works, press reset button and then reprogram.
The Woods 50000 series are new line of timer introduced just before Christmas 2012.
Woods timers are warranted by Coleman/ Carol Cable/ Canadian tire, and I suspect the timer itself is made by Intermatic.
All these timers have standard 1 year limited warranty against workmanship defects.
I have not seen any complaints about this line of timers here at fixya.
Add comment if you need more help.
Apr 18, 2013 | Woods 2C 24 Hour Indoor Mechanical Timer...
I need to reprogram my woods model Re1112 R
1) Copy following link to help identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) Add comment and include photo of your timer, and describe what you know about it.
Dec 02, 2012 | Hardware & Accessories
WOODS 59018 TIMER WIREING CORRECT INSTALLED WITH POWER OFF NETURAL GROUND UP TO CODE LOAD /LINE PROPER.NEW OUT OF BOX WON'T RESET. STEP 1 LAMPS LOAD SIDE GOOD. RETIRED CONSTRUCTION ELECTRICIAN
I don't have answer for defective timer. Buy another timer if everything below checks out:
59018 7-day timer has limited 1 year warranty, and appears to be made by Tork
Timer is for 120Volt single-pole only.
Rated for 1000 watt tungsten, 8A ballast, 1/4 HP
Push reset button with toothpick > not necessary to press-and-hold other button to accomplish reset.
After reset, 12:00 am Monday should display.
Programs are deleted. Reprogram timer.
To check, change and delete specific programming, press PROG key until selected program displays, and then set new programming >>> or press-and-hold MODE button and press PROG button again to delete selected program.
Timer has non-replaceable 30-day carryover battery and does not lose programming after power outage, and will retain programs until battery is depleted.
Review wiring:
Hot to timer black.
Neutral to timer white.
Load to timer red.
Ground to timer green.
Lights will blink if timer red and timer white are connected to load together.
Timer will not function if timer black and red wires are reversed. Display will not show.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Aug 07, 2011 | Woods InWall 7 Day Digital Programmable...
Sunset sunrise doesn't seem to work anymore
Timer is not identified.
If digital timer does not function as before, try resetting timer and then re-program.
If timer has battery, then change battery and reset timer.
If reset does not restore functionality, then timer has gone bad. Most in-wall timers have 1 year limited warranty.
Below are common 7-day timers, but there are many different brands:
You posted under Woods 7-day timer: except Woods timer does not astronomic dawn dusk function. Woods 7-day is same as Tork 7-day and GE 7-day, and they do not have astronomic function.
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
Reset button is small round button.
Push in reset with toothpick or paper clip.
Then reprogram timer.
If you have Intermatic ST01C or EJ500 battery operated timer: Replace battery, then to reset timer: push-and-hold ON_OFF button, and then push reset button. Keep holding on-off button until display changes. Release on-off button and display will flash 12:00. Then reprogram timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If you have Utilitec astronomic timer, then press reset button and reprogram:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Aug 05, 2011 | Woods InWall 7 Day Digital Programmable...
How to reprogram my Woods N1506 Timer
Manual and image for Woods/Noma N1506 outdoor timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
SETTING NOMA N1506 TIMER
Plug in timer - The letter C will Flash
TO SET CURRENT TIME:
Press Time Button - It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
Timer is only set to nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button - Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again - the letter E now flashes.
Press time button repeatedly until required ending time appears in the window. (Note: a dot at the bottom right corner of the display indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be turned on. The device will turn on and off automatically every day at the times you have just selected.
TO REVIEW THE PROGRAM
Press time button - Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10 seconds, plug it in again and proceed to set current time. Then continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged into the timer. The display will indicate the letter O. The devices will remain on until the ending time of the daily program. To return the timer to the automatic mode prior to that hour, press the Mode button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
Dec 13, 2010 | Woods Outdoor Lighting Timer
How to reset the programming on timex lamp timer TX12694TA
For some Timex timers, press PROG and MODE at same time to reset timer.
Open following link for random Timex manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Jul 14, 2010 | Hardware & Accessories
Uninstall
Use the uninstall program that just about every piece of software comes with. It'll be in the same location within your start menu that the game is located within the EA sports folder (or however it's organized). If it's not there, then go to your control panel and find add and remove software. From there, you should be able to locate Tiger Woods and double click it. It'll take you through the whole process.
Jun 05, 2010 | EA Sports Tiger Woods PGA Tour 2008 for...
Unable to uninstall tiger woods '03
Push uninstall programs under the control panel. If this doesnt work, then push my computer, go to you main hard drive, go to program files and delete the folder that is named Tiger Woods. Hint- It might also be hidden in a file called EA or EA Sports.
Mar 20, 2009 | EA - Electronic Arts Tiger Woods PGA Tour...
Setting woods 1600 timer
you can get your instructions here and print them off.
http://www.woods.com/canada-timer-instructions.asp
There is a complete list just choose the one that you have. Please don't forget to rate me on this.
Thank you
Feb 02, 2009 | Woods Industries 59377 Indoor Digital...
Hardware & Accessories Logo
256 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
jdthefixer
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
