Question about GPS
A small part of porcelan around top part of the spark plug fell into the spark plug hole . The SUV is A SUSKI XL
NOTHING YET
    Scholar:
  • 161 Answers
Probably not a good idea to leave it in there. I have gotten things out of combustion chambers with a very small computer keyboard vacuum. The vacuum has a stiff 6 inch tube as its pickup. I usually attach a small hose (like fuel hose) to the pickup and carefully fish it into the spark plug hole. Make sure the reservoir of the vacuum cleaner is completely clean so you can check it periodically to see if you got the piece out. If you don't have a keyboard vacuum, you might be able to attach a small hose to a regular canister style vacuum. (again, make sure you use a new bag, so you can check it to see if you retrieved the small part).
Posted on Dec 07, 2014
I was checking the spark plug in cylinder seven I had the spark out and one of the fuel rail o rings fell into the spark plug cylinder and I can't see it can I still run my car? What's going to happen
The o-ring could get under a valve and possibly cause damage. Try disabling the spark so the car or truck will not start and have someone bump the key to get the piston up close to the top. Get a hanger wire and and bend it over at the end. Attach a small piece of double sided tape or something sticky and see if you can get the o-ring to stick to it to bring it out of the hole
Sep 03, 2016 | Cars & Trucks
If part of the spark plug fall in to the spark plug hole,how to get it out?
This is nearly impossible! The plug is too big to fit in the hole. There are cases where the FORD company has had problems with spark plugs breaking in half when they are being changed but that is not what you are saying. If something fell into a cylinder, you can try to fish it out with a magnet pick up tool. You can use a video inspection camera to see in the cylinder but if you can get it out with a pick up tool, you will have to remove the head from the engine block. Note: You need to bring the piston up to near the top of the cylinder to get to the item. YOU CANNOT use the starter to do this as it will over crank and part that fell in will not allow the piston to come all the way up. You have to rotate the engine by hand with a socket on the crank shaft nut.
Dec 07, 2014 | GPS
Suski bandit leaking oil around the plugs
sounds like the plug tunnel seals are leaking or badly fitted...these are the seals found inside the rocker cover (top cover) of the engine that stop top end oil from leaking into the spark plug tunnels.
Jan 13, 2014 | 1999 Suzuki GSF 600 S Bandit
One small broken piece of ceramic from spark plug fell into engine fron spark plug hole,how I pull it out?
Use an electronics vecuum cleaner with a hose atatchment long enough to reach in and vacuum out cylinder.
Sep 09, 2013 | 2006 Chevrolet Trailblazer
When I was changing the spark plugs, one broke inside and debri from the spark plugs fell inside. Once I was done, I turned the truck on and it started making a noise as if it didn't have motor oil. What...
take the spark plug back out of that hole and start the car. it may blow the debri out, otherwise get a small magnet and fish around with it maybe you will get lucky and it will come out.if not you will have to pull the head.
Jan 30, 2011 | 2004 Chevrolet TrailBlazer
How do i adjust the valves on my83 xl 185s ?
adjusting the valves simple to do pull the spark plug and the 2 inspection covers top of the head.remove the 2 inspection plugs lower left side engine cover small round one and the larger one. Use a i believe a 14 mm deep socket with a 3/8 breaker bar and rotate the crankshaft counter clockwise watch the rear rocker arm go down as it starts to come up look in the small inspection hole if you have a flashlight rotate it slowly until you see a line with the t mark before it in the small hole stop it there that is top dead center then you can set your valve settings.
May 03, 2010 | 1983 Honda XL 125 R
2005 GMC envoy XL won't start
check to see if there is spark by removing a spark plug wire and attaching a spark tester that you can buy from a local parts store for a dollar or two
Jun 30, 2009 | 2005 GMC Envoy Xl
383 SMALL BLOCK CHEVY
383 is a modified engine...since it's not stock, you need to learn to "read" spark plugs. In reality the # used in any engine is a starting point for experimentation. Begin with factory plug, If too white or too black change heat range 'till you find a # that gives mostly white porcelan with light tan tinge. That will be a good plug to run.
Mar 25, 2009 | Chevrolet Nova Cars & Trucks
GPS Logo
42 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
