Question about Miller Welding Tools
Do I need a battery hooked up to a miller 225dplus for it to generate or weld
The original motor went out now running on different motor
    New Friend:
    Problem Solver:
  • 6 Answers
No , as long as the engine is running it should be producing power .
Posted on Dec 09, 2014
Welder won't speed up to weld ?
What doesnt speed up to weld? the feeder? is the wire burning back? are you getting any wire? this is gmaw / wire right? sounds like it may be running slow
Jul 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Serial number miller AEAD 200LE JF 885778
Check this out:
http://www.ebay.com/itm/MILLER-AEAD-200LE-CONSTANT-CURRENT-AC-DC-ARC-WELDING-GENERATOR-GAS-POWERED-/310368057796?pt=BI_Welders&hash=item484360b9c4
Jan 13, 2012 | Miller Welding Tools
Why is my bobcat 225 not welding hot enough?
Not knowing the full story, i would suggest, as a start, to set the WFS to No5 then set the Volts to No4. try this setting, Test the welding if still to low increase the voltage to No 5, check if it makes a difference, make voltage to No6, by turning up the voltage, you should see weld becoming hotter. let me know how you get on please
Nov 28, 2011 | Bobcat Miller 225 Welder Generator 907209...
I have a miller wildcat welding/ generator and the problem is that when I start the generator, it runs for a few minutes and then automatically shuts off. Whats the problem?
Hi:
The most common problem is the oil pressure switch. First make sure your machine has the oil up to the level line. If oil level is ok, then order the oil pressure switch and change it. If neither of these two actions cure the problem then send it in to be inspected by an authorized service mechanic.
Good luck
Aug 06, 2011 | Howard Miller Miller Wildcat 200 Welder ...
I have a miller trailblazer 301g. It worked fine yesterday and now only the 120/240 volt outlets will work. No weld output and also the idle will not kick down. when I opened the unit the only visable...
Hi:
Probably your machines just overloaded; the engine will run and produce voltage but no weld output.
Check your fuses F1 and F2, if they are open replace them.
Both fuses are located at left hand side of machine, open it and you will find them on the bracket.
Good Luck.
If this was useful please vote, thanks.
Apr 28, 2011 | Miller Trailblazer 302 Welder Generator...
Lost welding
Is the battery good, the motor will crank and start but the generator wont produce current? If so, it may have to do with the pick-up. It is located on the flywheel cover, on the engine. It creates current so the generator will start to create current. It may need to be cleaned or replaced and the magnet on the flywheel may need so light sanding too. Thr rust alone can cause this failure.
May 15, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
I need parts for a miller bantum welder-generater
Go to millerwelds.com - click on service,and you should be able to locate a manual ,or find a service rep. !
Oct 12, 2009 | Miller Welding Tools
Welding Tools Logo
61 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
