Question about Toys
I have a bobcat b250 backhoe and I can't figure out how to put a block heater heater on it. Help please
  • 16,621 Answers
What kind of block heater is it? There are a couple of types. One goes in the freeze plug hole and the other fits inline on a coolant hose.
Posted on Dec 07, 2014
Testimonial: "Well there is no heater hose because there's no cab so it doesn't have that option. I took out a frost plug and there's not enough room to fit a block heater in there, so that won't work. Called bobcat and they said you can put a block heater in a threaded hole that has a plug in it. But that threaded hole isn't a plug there"
  • Marc Boutin
    Marc Boutin Dec 08, 2014
    But that threaded hole doesn't have a plug, it has a fitting on it with a small 5/16 hose going to the oil filter adapter( probably an oil cooler) so can just block it off
  • Brad Brown Dec 08, 2014
    The coolant type block heaters can have a large hose connection. That would be for a radiator type hose size. The fre3ze plug type are usually bent at a 90 degree angle and fit up into the water jacket. IT can be a tight fit. A small hose like you are describing is probably not a coolant hose.http://www.tractorpartscatalog.info/trac...
My Bobcat 3023 trencher backhoe has no forward or reverse although all the hydraulics work on the implements. This happened with 10 minutes of the unit being fully operational. Any answers for this?
cant find a free repair manual on line
if the gearbox selection is mechanical check cables and linkages
if hydraulic valve stuck or bypassing
Jan 16, 2017 | Bobcat Garden
I have a 943 Bobcat skid steer. Where do I get a block heater for it & how do I install it?
You can order it from any auto parts store, it goes in the engine block, you must remove one of the core cleanout plugs AKA freeze plugs.
Nov 21, 2016 | Toys
Where do i add water in a melroe m600
check that you can open the rear of the unit, pins on one side and hinges on the other . This reveals the radiator and allows certain access to the motor.
Jan 25, 2015 | HTW Skidhoe Boom Skid Steer Bobcat Loader...
I have a cat 416 backhoe that keeps burning up starters. Can't figure out why. Any Thoughts?
eather a bad ground wire or the flywheel is bent witch will put to mucth of a load on starter
Jan 05, 2012 | Caterpillar Backhoe Tractor
Radiator water in oil of my John Deere 310A backhoe. What steps do I take to repair.
You have either a blown head gasket, cracked block or craacked head. Major work ahead. Hopefully, the water didn't mess up your main bearings.
Sep 01, 2009 | John Deere Kids Tractor Loader & Backhoe...
Toys Logo
97 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
