Question about Huawei Ascend Y530 Y530-U051 Unlocked GSM Android Cell Phone - Black
How to unlock hauwei asend y530 from fastboot&rescuemode phone locked?
Ulocking huawei y530 rom network
I suggest you can approach Theunlockarena.com and specify the country,locked network of Huawei Y530 .Based on the availability you can get the permanent unlock service along with free instructions.
Jul 23, 2017 | Huawei Cell Phones
How to unlock the Hauwei mobile wifi E5372
ask "youtube" they will show you how to do it.
Jul 22, 2016 | Hauwei Cell Phones
Water damage solution?
Unlocked cell phones will not work with CDMA Carriers like Sprint, Verizon, Boost or Virgin.
Feb 28, 2016 | Huawei Ascend Y530 Y530-U051 Unlocked GSM...
Unlock sim blocked
if you have tried to unlock you phone by inserting the wrong pin ( personal identification number) number more than 3 times , the service provider automatically blocks the phone by removing the PUK code ( personal user key)
if that is the case contact your service provider on another phone , provide proof that you own the account for the phone and they will give it to you once that is done you can enter a new PIN number and it should work
Write the number down where you will not forget it
Nov 20, 2015 | Huawei Ascend Y530 Y530-U051 Unlocked GSM...
HOW DO I UNLOCK HUAWEI ASCEND
What's your Huawei phone model?
you can get the unlock code for your Huawei phone from Unlocking4U.com and unlock your phone from Network lock easily.
Feb 19, 2015 | Huawei Cell Phones
How do i unlock my phone from 3 network
Here's a Step by Step on how to unlock bootloaders on your Xperia Arc(Your phone), Play, Neo & Pro.
  1. Download Unlock Xperia Arc Bootloaders.zip file.
  2. Extract the file you downloaded above on your PC. You'll get the following three files:
    1- drivers.zip
    2- fastboot_with_Android_USB_file.zip
    3- unlockbootloader.sonyericsson.com
  3. Click/DoubleClick on the internet shortcut file you got in Step 2.3 "unlockbootloader.sonyericsson.com".
    1- This will open a web page in your default browser. Scroll to the bottom of the Instructions on the page and you'll see a link like "Continue", click on it.
    2- In the pop-up window click "Yes, I'm sure" and then in the next window click on both the checkboxes, and then click "I accept".
  4. Now insert the details as per the instructions:
    1- First 14 digits of your IMEI No. Do NOT enter the last digit (15th) in the box. To know your IMEI No. dial *#06# on your Xperia Arc.
    2- Your name.
    3- Your Email address.
    4- Then click on "Submit"
  5. You'll get a KEY to unlock boot loader. Write it down somewhere you can remember, it will be used later.
  6. Switch off your phone.
  7. Now extract the "fastboot_with_Android_USB_file.zip" file you got in Step 2.2.
  8. Pick up your phone (it must be switched off) and hold the "Menu" button (the key at the bottom right of your phone), now while holding the "Menu" button connect your phone to your PC with an USB cable.
  9. Once connected - the LED light near the phone's USB plug will turn blue. If it doesn't - repeat the Step 8.
  10. Now to install the drivers do the following:
    1-Extract the "drivers.zip" file you got in Step 2.1
    2- Open "Device Manager" on your PC and look for "S1Boot Fastboot" under the head "Other devices"
    3- Right-click on "S1Boot Fastboot" and select "Update Driver Software..."
    4- Now select "Browse my computer for driver software" and select the folder where you've extracted all the three files you got in Step 2. Once done - click Ok.
    5- Now click Next (Make sure you've ticked the "Include subfolders" checkbox).
    6- If you see any Windows security warning box, don't worry . Just select "Install this driver software anyway"
    7- Wait for "Windows has successfully updated your driver software" message to appear on your screen. Now click Close.
  11. Open the "fastboot" folder from the file we extracted in Step 7.
  12. Now hold Shift and press mouse right click (Shift + Mouse Right Click) anywhere on the empty white space inside the "fastboot" folder. And then select "Open command window here" from the context menu.
  13. Now in the command prompt window type/paste the following:
    fastboot.exe -i 0x0fce getvar version
  14. It should return a value like "0.3". This ensures that your device is correctly connected.
  15. Now type/paste the following line in the command prompt window:
    fastboot.exe -i 0x0fce oem unlock 0xKEY
    IMPORTANT! Replace the word "KEY" from the above line with the KEY that you received in Step 5. Then hit Enter.
  16. Now wait for the process to complete. Command prompt will show a "Finished" message when it will be completed.
  17. Once it's done, disconnect the USB cable from your phone and switch it ON.
  18. Your phone's boot loader should now be unlocked.
By : NOurDeSiGner
Jun 17, 2011 | Sony Ericsson arc Smartphone
Huawei Ascend Y530 Y530-U051 Unlocked GSM Android Cell Phone - Black Logo
74 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
john h
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
