Question about LG Ultra Large Capacity White Top Load Washer - WT4970CW
Clothes don't seem to be so clean..water level seems to be low ?(I am used to the washer almost filling,putting detergent in letting it swish then adding clothes)also can't seem to turn off the child lock..thx!
Press and keep holding child lock for 5 to 10 sec
Posted on Dec 22, 2014
Testimonial: "when I press and hold childlock as suggested the CL code flashes continuously but it does not unlock,press and hold again it clears the code but it does not unlock"
SOURCE: TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Posted on Jan 28, 2008
SOURCE: Dispenser fills with water.
The reason there is still water in the dispenser, and this in normal by the way, is the unit uses the pre wash and main wash valve to activate the fabric softener. Basically when the two valves come on they force water into the fabric softener compartment. There can be some overflow and it ends up in the blue cup nothing to worry about. Now if you have detergent there, then that is a problem..
Sgt 48
Posted on Jun 15, 2008
SOURCE: LG 2277 Liquid Detergent Box & Insert
please put detergent into the main(left) side of the dispenser
Posted on Feb 18, 2009
SOURCE: Spots on clothes after washing
Put another filter on before the washer. Try to find out if it is in the hot water or the cold. If it is the cold try a filter. If it is the hot, replace your hot water tank.
Posted on Jun 06, 2009
SOURCE: Greasy looking spots on clothing after washing/drying.
Without seeing the spots, this is a bit speculative, but here goes,......
I'm guessing that the spots are only found on the front side, primarily of shirts, or blouses, etc. These are from grease splatters from cooking, which many times only show up after washing and drying.
The soap releases some dirt, which is attracted to the non-removed grease spot, allowing it to show up. Re-wash the clothing, pre-spotting those areas with a citrus pre-spotter.
Posted on Aug 31, 2009
Apr 08, 2015 | Whirlpool WTW6400SW Cabrio Washer
Dec 22, 2012 | Washing Machines
Mar 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Mar 04, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Sep 03, 2009 | LG WM-1832C Front Load Washer
May 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Jan 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Nov 13, 2008 | Washing Machines
Mar 04, 2008 | Frigidaire GLTF1670A Front Load Washer
Jan 31, 2008 | Zanussi ZWC1300W Front Load Washer
144 people viewed this question
