Question about Hoover Optima 7 OPH716DF White 600 mm Washer Front Loading, 7kg, A Energy Rating
Drum is not working
Turn it on and off
  • Hoover Master
  • 1,249 Answers
Beat it
Posted on Dec 07, 2014
Baril ne tourne pas
What kind of dryer is this? I assume that this is a front-loading belt-driven drum dryer. What happens if you turn the drum by hand? If it turns freely, it could be that you have a broken belt. If there is some resistence to turning the drum, is it possible to turn the drum while trying to start the dryer (this may require pushing the interlock button and the start button at the same time you turn the drum)? If the dryer starts to work with a little push, the problem is most likely a capacitor on the motor. Otherwise your motor may be work out - worn brushes or bearings.
Apr 07, 2014 | Dryers
Dryer is jammed drum won't turn
May be the belt that turns the drum.
Dec 06, 2013 | Roper 29 Electric Dryer
I have a minalta cs pro ep 1085..when I tried to take copy the paper jumed and errore code apeared (c0010) ,, any help will be greatfull
Sir/Mam the Drum Motor is failing to turn the drum it self mite be jammed. Not allowing the motor to turn . Remove the drum cartridge. And see if you can turn the drum with your fingers DO NOT TOUCH The color part of the drum turn by both thumbs on the edge of the drum TURN CLOCKWISE if you turn Counter clockwise you will flip the cleaning blade that is not good. The cleaning blade removes the old toner before the new image is placed on the drum if it looks yellow then get a new one and replace it. IF you think the drum is stuck to the cleaning blade then for about a half inch push the drum counter clockwise the then clockwise. Also might remove he drum to see if its jammed. Also the motor might be bad or the circuit board that replaces it. Hope this works for you
Hope this works for youH
Nov 23, 2013 | Minolta Office Equipment & Supplies
I went to turn on my xbox wireless drum kit and the light just came on for a second and then went out so i replaced the batteries, several times but it still wont come on
Well you can try this solution to get it too work. The thing with the XBOX 360 is that it has a hard time syncing with other controllers made by different companies. So try these steps first and see if they work if not you might have got a set of bad drums.
Step 1. Turn on XBOX 360 Step 2. Turn on drums (hold xbox button on drums). Step 3. Press sync button on 360 (XBOX ligh on console should start circling Step 4. Press sync button on drums [under D pad] (xbox light on drums should start circling)
If this doesn't work then you should RMA the drums to http://rockbandservice.ea.com to replace the bad ones.
Apr 23, 2011 | Activision Xbox 360 Guitar Hero II
Dryer works but drum will not go round also the belt is perfect so it is not that
is the belt a good tight fit on the drum??? is the motor turning? can you turn the drum by hand? if you cant turn the drum by hand its likley to be drum bearings stuck up or sezed up motor?
Aug 08, 2010 | Hotpoint Dryers
When dryer is turned on , it hums but the drum doesnt turn. It smells like heating element is working, belt is on correctly but drum will not turn. Any suggestions? Thank uou
sounds like the bearing the drum rides on is bad. that will cause the breaker to trip as the motor strains to turn the drum on the bad bearing.
Sep 09, 2009 | Dryers
I turn the dryer on and the drum will not turn.
It sounds like the belt that turns the drum is loose or worn out and needs to be replaced. Another problem is that the motor is on the way out. Check the belt first.
Aug 02, 2009 | GE Profile Harmony DPGT750EC Electric...
PS3 guitar hero world tour not recognizing drums
GOT IT!!!!
beebe623 was right. with some extra steps. Simple steps here:
1. Unplug the drum receiver.
2. Turn off the PS3.
3. Remove batteries from the Drum Controller.
4. Plug in the Drum Receiver.
5. Put batteries back in drum revceiver.
6. Turn on PS3.
7. Hit the PS button on the Drums once. (all 4 lights should flash)
8. Push and hold down the button on the Drum Receiver for about 5 seconds, then release.
9. Push the PS button again on the Drum Controller. At this point the drums should be assigned a port and synced up.
All this is in the instructions that came with the game.
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Dryer Motor won't always start Model FSE747GES
Too much drag on the Drum. Try lubricating the rollers that the drum turns on. Check the belt tensioner pully...lubricate that as necessary. If Drum still turns very hard after this then take belt off of motor and try turning drum. If drum turns easily then replace motor.
Nov 24, 2008 | Frigidaire FDE336RE Dryer
Noise from dryer
drum has worn drum bearing dryer top AND rear panel must be removed to acess the rear of drum to replace drum
Sep 24, 2007 | Zanussi TC7102W Electric Dryer
Hoover Optima 7 OPH716DF White 600 mm Washer Front Loading, 7kg, A Energy Rating Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
