Question about Refrigerators
How to stop ice building up in freezer
Ice builds up in no time and the ice covers the food in thick ice
    Problem Solver:
  • 7 Answers
Ice buildup is generally caused when you have a leaky door seal. Make sure that the door seal is intact and the door is properly closed. Another cause could be that the tube to the ice maker has detached. Hope this helps
Posted on Dec 07, 2014
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
Food not getting cold in the fridge
There are many reasons for that to happen.
Check your refrigerator for a thick build up of ice in the freezer, you need to defrost the fridge.
A poor circulation of cold air will happen if thick build up of ice is not defrost.
Do not block cold circulation with so much food inside, you need to organize it.
Check temp control to lower degrees or high number.
A door gasket leak will cause cold air to flow outside the fridge.
A system tubing clogged dirt inside the copper tubing will also cause it, but this one need to be check by a service technician.
I hope I give you idea for your refrigerator problem.
Jun 26, 2011 | Dometic NDR 1292 Refrigerator
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
Ice build up on bottom freezer
Ice build up on the freezer floor alone, with no ice on shelves or food above the floor, usually indicates a clogged defrost drain problem. when your unit goes into defrost, the melt water is intended to go down a drain tube from the freezer to a pan on the outside bottom of the unit, usually near the compressor. Sometimes these drains are clogged with food debris, other times some of the melt water does not completely drain, and freezes - this build up of ice can then clog the drain. You can unplug the fridge, with both doors open and a fan blowing for 24 hours to temporarily remove the ice and water, but it will return most likely, in which case you would need to have the drain cleared out and / or have a drain heater installed by a qualified refrigerator repair service.
Apr 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Freezer vents are building up ice.
A couple of things can cause this problem. One is that your defrost temp sensor is ot functioning correctly and terminating the defrost cycle early allowing ice build up to occur over time. The other thing could be that you have a torrn or loose door seal on either your freezer or your food section door. The thrird possibility is that you deftost timer is intermittent and only working part of the time or is clocking forward at a very slow rate. You can unplug the unit again and place a fan blowing into the freezer section for about 2 hours but we both know this is only a temporary situation and that you should have your unit serviced. I would call for that service either before you defrost it or 2 weeks after you defrost it.
Jan 06, 2010 | Hotpoint HTS18BCPWW Refrigerator
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
Ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Feb 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice build up in freezer
Sounds like a defrost problem... need to pull back panel off in freezer and see if u have thick frost build up indicating... heaters, or defrost themostate bad.. could not bring up your model # SO dont know if maybe bad defrost timmer or if you have adaptive defrost control which could also be bad.
Aug 19, 2007 | Frigidaire PHSC39EESS Stainless Steel Side...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
