Question about Whirlpool Ovens
My electric Whirlpool oven won't heat after doing a self-cleaning.
Checked the fusebox.
    Sergeant:
    Champion:
  • 253 Answers
It's possible the heating element burned in half while doing the self clean, it has to stay on a long time for the self clean cycle, try unplugging and plug it back in, might do it
Posted on Dec 07, 2014
  • dawghouse007 Dec 07, 2014
    That was my first thought, but both the baking element and broiling element won't heat up, so maybe it's the thermostat?? Any thoughts?
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
My oven stopped heating, and the range element won't turn red when you turn it on but it does have some heat coming from it. What's wrong with it?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 [
Aug 08, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
After self cleaning the oven, now the oven won't heat up
Usually this is caused by either a bad temperature sensor, a shorted wiring harness, or commonly a faulty controller. The temperature sensor and wiring can be checked with an ohm meter.
When you program the oven for a high temperature what does the display read after ten minutes or so?
- www.fixyourboard.com
Jul 29, 2009 | Whirlpool RBS275PD Electric Single Oven
Whirlpool 27" wall oven. no heat after self clean
Self cleaning features are not recommended by most appliance technicians. The ovens are not constructed satisfactorily to expel the 1000 degree heat, Therefore the thermal fuses blow as well as other parts failures.
Remove the oven. Remove the rear panel. Replace the thermal fuse in the back of the oven. Use Easy Off next time.
May 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
WHIRLPOOL OVEN
have you checked your in coming power the clock will work on 110 but it takes 220 for full function zzsbolt yours does sounds like a thermal fuse
Jan 18, 2008 | Whirlpool RBS305PD Electric Single Oven
Whirlpool RBS305PDQ11. After self-clean, oven won't heat up.
This seems to be a common problem with these ovens. The oven got too hot and the tco (Thermo cut off)tripped. This will have to be replaced. It is located behind the control board.
Aug 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
88 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
