Question about Health & Beauty
What is Code 35
Left hand motor seems to be cutting out, the Joy stick throttle pot has to be in the 3:00 clock position to go straight
    Problem Solver:
  • 18 Answers
Assuming this is a Pride Q600 or simular powerchair.with the q600 what usually happens is grease leaks into motor .the motor current
draw then goes up and chair tries to go in circle.first check the outer motor brush & spring for burning.if you have a dc clampmeter check current draw with joystick forward aprox 3 amps.if over replace motor.if no clampmeter run chair for 10 mins wheels off ground Then feel both motors if left one red hot .replace it.hope this helps
Posted on Dec 16, 2014
2 Suggested Answers
gewiz
  • 1271 Answers
SOURCE: pride mobility legend XL throttle/speed fault
what about the overall connection , start at the handlebars from the speed pot,
Take off the rear cover , first remove the seat, pull the connector one by one and plug back in,
chec kthe connectors around the speed pot , in particualar if there is a circuit board.
Posted on Jun 13, 2009
I have a cosco 57-410 4 wheel electric scooter, seems that the electric brake is not functioning right. Scooter wont free will or run with power on. give an electric break code. Swtich on electric...
The brake is controlled by the position of the fwd/reverse throttle paddles.
There is a pot inside that the paddles attach to..if the pot is not
centred the brake doesn't work properly when the paddles are
released. I had the same problem on my Pride Legend XL..
had to order the throttle pot from MonsterScooter,com.
Installed it myself and that cleared my electric brake problem.
Apr 08, 2014 | Pride Mobility Products Go Go Ultra X 3...
How to change a travelmate 3 to left handed control
i think you mean forward using left hand, reverse using right hand, if so there should be 1 red and 1 black wire from the motor going to the motor controller if you switch these wires then your throttle should work the way you want but unless there is a speed control pot on the throttle enclosure you may also now run faster in reverse than forward
Mar 29, 2014 | Amigo TRAVELMATE Mobility Scooter ()
Mercury M48 scooter cuts out while driving
check the throttle pot. it is just a variable resistor, look online for a video, could have corrosion or carbon buildup on pot. also test the speed pot same issues
Apr 10, 2017 | Drive Medical Health & Beauty
I have a gogo three wheeler and some times when i turn on the switch the scooter will not move, but when i turn the switch off and on two or three times it will work and some times the horn will start...
The go go controller has a controller which will give you a specific beep code to indicate the problem with your scooter. From what you are describing, it seems that the throttle potentiometer is out of neutral at start-up. The controller needs to electrically sense the throttle pot is in neutral (center of left and right) to start. By turning the scooter on and off you are jiggling the pot enough to get it to zero out(go to neutral).
Please get back to me with the exact model of the go go and with the exact number of beeps in the error code and I will be able to diagnose the problem in a more definitive way.
The most common error codes involve the throttle pot out of neutral at start-up and the brake freewheel lever is in freewheel.
You can see if the throttle pot is out of neutral by moving it slightly in either direction with one hand and turning the scooter off and on with the other hand. If the scooter works by this slight adjustment of the pot, then this part needs to be replaced. Hope this helps.
Jan 30, 2011 | Electric Mobility 3 Wheel Motorized...
How to change my security code but i didnt know my old password to chage it
Sony Ericsson Secret Menu:
> * > means press joystick or arrow keys to right
1. push joy stick to RIGHT once
2. press *
3. push joy stick to LEFT twice
4. press *
5. push joy stick to LEFT once
6. press *
The Service Menu will appears containing following information !
1. Service Info
a. Software Version
b. SIMlock
c. Configuration
2. Service Setting
a. Contrast
3. Service Test
a. Display
b. LED/Illumination - *This test is very cool
c. Keyboard
d. Buzzer
e. ********
f. Earphone
g. Microphone
h. Real Time Clock
i. Joystick Counter*
Lockstatus:
Shortcut to last dialed numbers: 0#
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 26, 2011 | Sony Ericsson K550i Cellular Phone
Pot speed and throttle speed beep code is happening. how to get it going again.?
This is a very typical error code when the throttle potentiometer is out of neutral at start up. This is caused by wear or hitting or bending the throttle lever.
In my experience the best way to adjust the throttle pot is to clean it. I usually replace both the throttle potentiometer and speed potentiometer when they fail, cause an error beep, or they have dead spots. You can carefully remove these components by removing the covers and following the service procedures in the service manual. Very carefully take them apart to clean the wiper on the potentiometer with electronic spray contact cleaner (this is not in the service manual; use extreme care and do it delicately).
You can adjust the spring tension on the throttle potentiometer with careful bending.
You can first try to zero out the throttle pot by hand (even it out) and start the scooter to clear the error code. With your left hand adjust the lever left or right and with your right hand turn the scooter on. By trial and error you may be able to get this to work.
In both circumstances you will wind up replacing both components anyway and the fixes I have described are only temporary. Hope this helps.
Jan 01, 2011 | Pride Health & Beauty
How do you slow the unit down?
use the speed pot on the from control panel, if it still too fast take off the control panel,
look for the three throttle wires, pick the left hand , now get a 5k pot from maplins or rs depending on your location, wire the central locator and the left or right side locator as a straight connection so one wire from the left let and one wire to the central leg now take a wire off the throttle and connect to one piece of wire and the other to the other end of the wire, hope that makes sense, now you increase the resistance from the pot and now when turn fully on for boths pots will slow down the scooter
Regads
GeWiz.
Sep 30, 2009 | Pride Mobility Victory 3 Wheel Electric...
M1V R11 Joy stick blinks 5 times
I believe this fault code indicates a left parking brake fault. Check all the connections from the motor/gear/brake assembly on BOTH motors (sometimes the controller gets confused). Follow the wires from the motor to the controller and reconnect them all. Make sure the free-wheel lever is in gear by taking out of gear, and placing back into gear firmly.
Good luck.
Jul 11, 2009 | Invacare Supply Group Health & Beauty
Anniversary train clock; clock does not work
It's not the motor it's the unit in the middel that works the clock it self. I have the same problem. When the clock passes the hour it is supose to send a signal to start the motor. There are two tiny pices metal that are supose to contact each other on the hour and they break off easy.
You have to replace the clock unit and reconect the two black wires.
Try by passing it. The two black wires that come from the clock unit. Cut them and touch them together. Make sure the light sencer on the front is not covered.
Good Luck
Jan 16, 2009 | Toys
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
Health & Beauty Logo
81 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
