Question about Singer Sewing Machines
How do i install the bobbin case for a 974 singer machine
  • Singer Master
  • 1,860 Answers
Try this link for a free manual. it should have the information in it you need
Posted on Dec 08, 2014
How to thread bobbin on Singer Serenade 30
The owner's manual should have instructions. Otherwise, search the internet for videos/tutorials for using your machine, ie:
Inserting the bobbin on Singer sewing machine
How to set up singer sewing machine MP4
Machines vary on how the bobbin is installed. A lot of Singers have a drop-in bobbin, but others actually have a removable bobbin case. Just search until you find one that is similar to yours.
Feb 14, 2016 | Singer Sewing Machines
Why won't bobbin case in singer 974 machine spin?
It's not SUPPOSED to spin! The thread is supposed to unwind from it while it's stationary.
Jul 13, 2014 | Singer Sewing Machines
Missing parts on singer sewing machine model 974 serial no. SH30010021
take it back to place purchased .have them correct the problem
Mar 15, 2017 | Singer Sewing Machines
My 974 is not stitching and wont pick up the bobbin thread
First check that the needle isn't bent. (The simplest thing is to try a new needle.) Next check that you have a correctly wound and installed bobbin. The hole should be facing up and the bobbin thread comes off the bobbin to the left. Make sure that you threaded the bobbin correctly (notch A at the center and then to slot B to the left. (About 7 if you have the center front of the bobbin area at 6 on an analog 12-hour clock.) Pull the thread diagonally across the bobbin and then close the faceplate with the thread going through the opening of the slideplate. Hold onto the top thread while trying to bring up the bobbin thread.
If the bobbin thread still will not come up, remove the bobbin and clean the bobbin case. You may want to clean under the case as well, see page 81 of the manual. This is page 83 of the PDF: .) Do all of the oiling of your machine while you do this maintenance if you haven't done it in a while.
The bobbin case has several parts that combine to provide good bobbin thread behavior. First there is a tension set screw that keeps the bobbin thread at the desired tension. If it is too loose or too tight the thread can't be pulled from the bobbin. (It's easy to strip the threads of the case, so be very careful.)
This is easiest to check on other types of sewing machines with a vertical bobbin case. For those, you remove the bobbin case and thread the bobbin through it correctly. Dangle the bobbin case from the thread (carefully). The bobbin case shouldn't slide on the thread but you should be able to pull out more thread if you hold the center of the bobbin and bobbin case. (Hold gently so that the bobbin turns.)
Next the bobbin race and hook need to grab the bobbin thread and twist it with the top thread. If these are damaged (perhaps by a bent needle), they won't work properly. These are at the back of the bobbin case.
Try replacing the bobbin case or parts of the bobbin case as needed. The Singer 947 is in the same line as the 244 and should use those parts. has the parts list. Try contacting a Singer dealer to get the parts. Unfortunately, my usual vendors only seem to list the manual as an available part for this line.
I hope this helps.
Apr 08, 2012 | Singer Sewing Machines
Singer 974 disc-o matic bobbin bunching problem
try a new needle
clean under the needle plate & in the bobbin area for lint or loose threads
make sure the bobbin is inserted correctly
make sure the bobbin is not warped
Mar 20, 2012 | Singer Sewing Machines
Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Jan 27, 2010 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
158 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
