Question about Intel Motherboard
Motherboard or cpu.
I My motherboard is with 81845-GV chipset
. When I boot up the system light powers on but no display nor any beep. . I have no idea whether it is a board or a processor .
please advise.
Re: motherboard or cpu.
I have a motherboard model 62YVH that has just gone on me. The motherboard is in a GX 150. I would like to replace it with the least cost. Is there a motherboard out there that is capable
thanks for all your help
Posted on Feb 28, 2008
  • 46 Answers
Does it include onboard video? If it's not beeping you may need to just reset the CMOS. To do that, look for a jumper, near the battery, that's probably labeled JP5. It will have two of three pins jumpered. Move the jumper to the other side and turn the power on, just for a moment, then turn the power off. Move the jumper back to it's original position and turn the power back on. That's all you need to do to reset the motherboard's BIOS to it's factory defaults. You'll hit the <del> key to enter the BIOS setup so that you can set the system time and enable peripheral settings.
One other thing, double check your RAM. It needs to be DDR2 RAM (PC2700 or PC3200, probably) in order for it to work. If you're running Windows, I recommend, at least, 512MB.
One note, if you're able to power the system on and off with the front power button it means the motherboard is probably working. The only way to determine if it's the processor is to try another one.
Posted on Nov 11, 2007
  • 306 Answers
Reseat the proccesor, check that hard drives have proper jumper settings and the memory stick and cmos battery are seated proper.
let me know
0 characters
3 Points
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
Maximus motherboard with intel x38 chipset won't boot
There's a chance of overclocking, ram failure, bios failure, cpu overheat, power supply problem,etc.. But in the first step, remove everything which are inserted on the board, like power cables, processor, rams, bios battery, Pci cards, sound cards, etc.. and clean them using soft brush, also clean the mother board, there might be dust clogging the chipsets like resistors, transistors and capacitors, and reinsert everything after cleaning... I hope this will help if there's only a small problem except circuit short... Good luck...
May 06, 2010 | ASUS Maximus Formula Motherboard - 45nm...
Cant get computer to
Disconnect everything from the motherboard except the power supply, CPU and power switch.
Turn on the computer. You should hear 3 beeps because you removed the memory.
If you don't hear any beeps, check the power supply. Check all the connections. Did you connect the 4 pin power? Did you skimp on it? A common mistake is to get a cheap, high-power supply. Just because the box says it's 1000 WATTs doesn't mean that will carry a steady load.
Still nothing...
It's either a bad motherboard or processor. If you have another processor that is supported on that board and you know it works, try it. If it boots return your CPU for a good one.
Unfortunatly, if it doesn't boot with a known-good processor that just proves the board is bad; it doesn't prove your CPU is good. You may have more issues.
Mar 08, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus k8s mx not boots but fan rotates and without
Long beeps are saying 'no RAM'. Any beeps with RAM in place? Remove BIOS battery (silver) for 10 mins to return to factory defaults.
Sep 12, 2009 | VIA Asus K8V-MX K8M800 Chipset 800MHz FSB...
I have a emachine PC. PowerSupply blew up. changed it still down
1. check power supply watt 400/450 and same another power supply install and check it. if power supply change and system is working ok so problem in your power supply.
2. check CMOS cell on motherboard,(3 volt)
3. Bfore power supply changing check on mother board any capasitor is like as damaged or not.
OR check main chipset ic is marked as intel.whenpower on it is very hitting or
normal)if very hitting require to repair your motherboard.(intel chipset ic near cmos cell or pci slot,)
4. checking of ram on other pc (working or not)(one beeps coming or not,if one beep coming ram is working ok)
Feb 27, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
My ECS 915 G-A elite group motherboard doesnot display anymore on the monitor..
have you tried to isolate what the cause of the problem? first check the video card if is properly inserted into the slot, and check the memory, and cable from CPU to monitor if it is connected properly. then boot your system. And try to observe this beep error code this might help you locate where the problem is.
short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
thnk you.
Nov 29, 2008 | Motherboards
CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Sep 27, 2008 | Asrock 775VM800 Motherboard
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Intel Motherboard Logo
141 people viewed this question
Top Intel Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an Intel Motherboard Expert? Answer questions, earn points and help others
