What are the jumper settings for Newtronics D509V? Circuit board gives the options 0, 1, 2, and 3 on a 4x2 jumper block with the letters DS underneath the zeroeth pair of jumpers. I am used to seeing CS for Cable Select, but DS? Device Select?
  • 2 more comments
  • Scott Bale Dec 06, 2014
    Newtronics D509V = 1.2M 5 1/4" FDD
  • solver2010 Apr 18, 2017
    Here is a link for you!
    If it does not work as a link, copy and paste the entire text block into a NEW TAB in your computer's browser.
  • solver2010 Apr 19, 2017
    Here is a much better link than I gave you before. Sorry about that ... but better late than never!
    If the above is not an active link, just copy the text of it and paste it into a new tab, then hit the enter key!
    DS means DRIVE SELECT!
  • Computers & ... Master
  • 923 Answers
Posted on Dec 14, 2014
Testimonial: "url didn't work in Chrome, had to use Explorer. Been there, looked at that, doesn't show v0 jumpers, only v2. But, thanks for trying."
Kevin Amandy
  • 37 Answers
SOURCE: Pin settings
There are four Jumper settings on a Maxtor:
(got it from
posted by by mr.smit:
"The 2nd row, is for DS(Master): only 1 drive in PC, or the drive that you want to boot up from.
The 3rd row, is CS Enabled: Cable select, the computer desides wich harddisk is master and wich one is slave
The 4th is cap limit: windows cannot run on harddisks that are to big, like 300gb, so putting jumper on cap limit (capacity limit) makes it smaller for windows to use it.
The 5th row has no use, or i don't know what it does, either of that 2."
I would like to add about the DS (Slave) setting. It is used if there is another drive present on the system which you want to boot from. It will become a spare Hard Disk.
Here is a picture of a maxtor drive indicating where to find model number and jumper settings.
Posted on Nov 19, 2007
  • 86 Answers
SOURCE: maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
Posted on May 07, 2008
  • 1865 Answers
SOURCE: When installing a Maxtor Quantum Fireball Plus AS
put the jumper on CS, and use the connector on the end of the ribbon cable
Posted on Jun 11, 2009
  • 6 Answers
If this is a new drive, you will need to format it before it will show up in My Computer. To do so, start by right-clicking on My Computer, then choose Manage from the menu. Click on Disk Management, you should see a list of drives in your system. Your new drive will show up as unallocated space, right-click on that and choose New Partition, choose the size of the partition you want, and choose to format it. Once the partitioning and format process is complete, the drive should show up in My Computer under a new drive letter.
Posted on Jun 12, 2009
  • 196 Answers
SOURCE: Looking for the jumper pin settings to designate
on the right hand side put the jumper to make primary master
Posted on Sep 01, 2009
I have an insignia 46" tv I replaced the main board, the tv works except the picture is upside down, what will correct this problem
Flip the TV over! Just kidding!! When you installed the main board was it identical to the old main board? If so, you might want to look at the old board and ensure there are no jumpers that needed to be set on the new board. Some companies make generic control boards for tvs but have different jumper settings for different models. The jumpers are just little black blocks that connect different pins to each other on top of the circuit board.
Dec 03, 2014 | Insignia Televison & Video
Jumpers Serttings on Quantum HD
CS = Cable Select
DS = Master
SP = Spare (Slave)
Nov 10, 2013 | Maxtor Computers & Internet
dear mugkifa ,
the above error indicates , a non maskable interrupt occurred in your server , there may be a change of malfunction of a hardware ,like add on cards
one more solution in ibm server is disablig the NMI interrupt by using jumper settings (inside motherboard)
see the below mentioned details , may differ with your server series please refer with series on
System-board jumpers
The following illustration shows the switches and jumpers on the system board:
migr-5069937_2.gif Note: Any jumper blocks on the system board that are not shown in the illustration are reserved. The following table describes the function of each jumper block:
Jumper Settings CMOS jumper (JP3) Pins 1 and 2: Keep CMOS data (default)
Pins 2 and 3: Clear the CMOS data, which clears the power-on password and administrator password Boot block jumper (JP4) Pins 1 and 2: Normal (default)
Pins 2 and 3: Recover boot block NMI (non-maskable interrupt) switch (SW1) Normal (default): No NMI issued
The NMI button that is on the rear of server, connected to this switch, has been pressed: NMI issued
May 07, 2010 | IBM eserver xSeries 360 8686
Need jumper settings for both hard drives. PCb board has been replaced. Cannot rememebr the orgional settings.
Master (M) on the harddrive that came with the computer, Slave, (S, or SL), on the 2nd harddrive.
Don't see M, S, and CS, on the label of the harddrive? (CS is Cable Select)
Sometimes it's right on the edge, where the 40 pin flat ribbon cable plugs in. It will be letters raised in the plastic, of the harddrive body.
To find where to set the jumpers for these harddrives, I suggest you look at the label. Since you had the Printed Circuit board replaced, I'm guessing you know who made it, and what the model number is.
Some harddrive manufacturers,
1.Western Digital
2.Maxtor, (Maxtor is owned by Seagate now)
5.NEC (No longer in business)
6.Quantum, (sold out to Maxtor)
Here are three links that are videos, and may help with setting jumpers, and setting up those IDE harddrives. (IDE is also referred to as EIDE, ATA, and PATA)
(If you have SATA harddrives, do not touch the jumpers, if any are present! These are for the factory. With a SATA harddrive, you can plug it/them, into ANY available SATA header, {Connector}, on the motherboard. Doesn't matter!)
May 22, 2009 | Computers & Internet
Goodman Furnace
Could be that the fan on you new furnace is more powerful than your old one and is forcefully blowing the cold duct air out causing a temporary chill or it could be that you need to adjust the fan delay.
I'm not familar with this unit so I wouldn't have aclue on how to do this or even if you can.
Jan 27, 2009 | Goodman GMS90703BXA Heater
Toshiba 50H81 Power but no picture or audio
its possible that flood leaked on board from a tube leaking.
clean the area and scrape the burnt area really good so that it won't conduct. then make a jumper from some small wire to the areas you need. check tubes on the bottoms of the metel areas not the crt for something wet... if this fixes your problem then cover your board with a plastic or foam sheet so that it drains forward away from the board. also when you find what tube it is, you may want to ask ways to fix it or how to keep it from leaking.
but if its not a leaky tube then you may have had lightning or power surge. may want to go ahead and check all parts connected to that area for a short. just to make sure there isn't another problem before you start it up.
good luck let me know.
Apr 16, 2008 | Toshiba 50H81 50" Rear Projection...
Cracked circuit board
Try, they have an "A" board (p/n A-1299-243-A) for this model for about $170.
Other than that it is pretty strait forward to jumper across the crack with a little wire on every broken trace. Look close, don't let all the white lettering on the PCB fool you.
Done this many times, rarely any component failures.
Dec 31, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Jumper Settings
another place to look is on the circuit board where the jumpers are connected you'll see : MS, CS, CAB, a space and TXD.
Oct 13, 2007 | Maxtor DiamondMax Plus 6800 (91366U4) 13.6...
Open Questions:
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
