Question about Refrigerators
How do i get ice to start - Refrigerators
    Sergeant:
  • 230 Answers
Ice makers have a control lever, it is usually a thick wire, pull lever down after opening water supply.
Posted on Dec 06, 2014
Stopped making ice. Display says "ice off." How do I get it start making ice again?
This would suggest that the ice has been manually turned off. Try using the ice selection button to see if it returns to either cubed or crushed ice again and it should start working.
Mar 06, 2015 | Samsung Refrigerators
Taylor ice cream machine
might have to adjust the cycle timers on the logic boards
Sep 08, 2014 | Taylor Temporarily Out Of Stock-339-27 Air...
Kenmore 106.55242400 ice maker knocking noise
most likely you need a new ice maker,one thing that could do this is the white arms that spin around when dumping the ice,sometimes one of the arms bend and jam the ice maker and you'll hear that knocking soundthe arm gets bent,the ice cube gets stuck because the arm can't push it out,,it stops the motor from spinning through it's full cycle and damages it but this is just a guess from something i've seen happen but most likely you need a new ice maker,one other i've seen is the metal arm that you can lift up to shut off the ice maker gets knocked out of the hole it slides into.if you pop off the white cover and get a jumper wire and stick it into the h and t holes you can jump start the ice maker.http://appliantology.org/gallery/image/659-manual-harvest-on-a-whirlpool-modular-ice-maker/
Jan 02, 2014 | Whirlpool Refrigerators
How do i get the ice maker to to start making ice
inside the freezer there is a lever that is in the ice container. It is there to stop the machine from overflowing the ice tray. Push the lever up and then pull down. the ice maker should start then
Dec 23, 2012 | Refrigerators
Ice maker did not produce ice, then it started to
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 24, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Hoshizaki KM-900MAH Ice Maker it sounds like it is making ice and is freezing it but its not dropping ice any solutions?
when the machine first starts, it begins it's cycle in the harvest mode. If the float switch is stuck, it stays in the fill/ harvest mode. Compressor runs and water circulates but no ice is being made. I'd start looking there. Turn the machine on, let it run for about 3 minutes, they very lightly tap the float switch. If it starts making ice, bingo, theres your problem. Let me know if I can be of any more help.
May 12, 2010 | Hoshizaki Freezer Commercial Ice Machines...
I HAVE A ICE O MATIC 0250HA4 which start making ice in 2 minute cut off and havest engine start working it keep doing this over and over
the thickness sensor is too close to the where the ice is being made. you will need to either bend it out a bit or use the adjustment screw. the latter is more preferred.
Jan 12, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice machine growles; crushed or cubes
Remove the ice bin and throw out the ice. Run water through the ice bin to clear out the frozen ice in the bottom. Dry the bin really well. Re-install the bin and start over.
Sep 23, 2009 | Fisher and Paykel Refrigerators
Ice maker not making ice. red light on control panel blinking twice.
Remove the ice bucket and inspect the ice maker for an ice cube stuck in the ejector. Hit it with a little heat of a hair dryer till it gets loose and the ice maker starts rotating. Replace the ice bucket. See if it starts making ice again amigo.
Jan 31, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
