Question about Electrolux Vacuums
Where can I find some parts for an Electrolux carpet cleaner model B-50.
The plastic gears on the 2 flywheels have disentegrated into million bits of pieces, need to know if the parts are still available. Thank you.
Replacing belts
there is two of them, one for each side, two screws hold on a clear plastic cover on both sides, the belts are serpentine, one on the plactic gear, one on the metal drivegear, see shiny parts where the belts have been traveling, good luck, pretty easy
Aug 15, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
Precision model blockage
No solution but we seem to have the same problem it is as if the valve isn't working. Please don't tell me to check for blockages.
Feb 24, 2014 | Electrolux EL8807A Precision BrushRoll...
Floor scrubber
You can often find them on Ebay. Just look for Electrolux or Aerus Floor Pro brushes. You can probably also find them under Electrolux shampooer brushes.
You can purchase them from the Aerus site and they will ship to you: https://www3.aerusonline.com/Electrolux/index.asp
Or go to http://www.aerushome.com/storelocator/ and follow the directions for the dealer nearest you. If close enough you can pick them up at the store, they can deliver to your door, or they can ship if you live several miles away..
Jun 08, 2013 | Electrolux Vacuums
I have a Lux Floor Pro Heavy Duty carpet cleaner. Whis attachments (scrubbers) do I attach to the bottom to wash a non-plush carpet. I have three attachments that have hard bristles and three that have...
NEVER USE THE HARD BRUSHES ON CARPET ! You can burn up your motor, break the drive belt,or strip the drive gears The black bristle brushes are for all carpet types.
The hard bristle brushes are made for hardwood and other smooth surfaces.
Oct 24, 2009 | Electrolux UltraLux 2000 Bagged Canister...
My electrolux O3 carpet power head keeps shorting
If your unit is like ours, there is a electrical short in the wand to Hose connection.. dont use it.. ours unit shorted out and sparks were everywhere.. burned thru the wand to the inside of it and the outside. Good thing my lovely wife wasn't touching that part. electrocution risk was Extreme. PESTER ELECTROLUX, they drag their heels when it comes to admitting and making it right.
Oct 18, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
9 month old electrolux oxygen vacuum just quit
my electrolux oxygen canister just quit- i think it's the sumo board and the whole fuse problem why does this keep happening over and over (my 4th time w/ this model) and where can I buy a replacement sumo board myself?
Jun 19, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
F7452900 the brushes won't rotate during floor cleaning
Solution for Hoover SteamVac (F7452-900) brushes not spinning
Uses the turbine model and same solution would be similar. Root cause is simply the main gear attached to turbine becomes stuck. This problem should not happen as often as I see other people also having this problem. Must be a poor design on Hoover’s part. It takes about 30 minutes and a Phillips screw driver and wrench. Pretty easy, just have to remember what screws went where.
Remove brushes, and front suction cover
On the bottom of the machine:
Remove the 4 screws behind brushes which attach the top faceplate
Remove the 2 screws from base in the sunken holes
Remove the two long silver screws from base which connect all the way to turbine assembly
Stand machine upright
Remove the floor select switch handle
Remove 1 screw near the center beside the intake hole
Remove the 2 screws over the rear wheels
Remove faceplate cover, the front will need to be gently pried over the clear plastic part, be careful about the upright disengaging lever under faceplate, move it under the metal wire
Remove the 2 screws in the front of the turbine assembly
Remove the 2 hoses on either side
Disengage the bar on the floor selector switch
Pull out the turbine assembly
Remove the 4 screws and 3 clips to separate the assembly
Remove the filter (which is most likely clean since, cleaning this is the manufactures only solution)
Remove the large white gear and with a wrench remove ball bearing
Remove other large white gear
Note that the metal gear attached to turbine will not move (this was my problem), with a wrench gently grab metal gear and twist free. Spin turbine to make sure it moves freely.
Put everything back together again and you should be good to go.
Apr 09, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Power Head for Electrlux Oxygen Ultra
I work for Aerus Electrolux. My office # 570-326-1731 Call me and I will help you order the part. Liz
Feb 26, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
