Well two things have to happen to make tape move in a cassette deck. One is the Capstan shaft has to rotate and that is usually a belt link to a motor through a pulley. The second thing is you must have take-up torque. If the tape moves but the take-up reel does not pull it onto the take-up reel then you either have a eaten tape or the deck will shut off. in your complaint it could be any of these items- maybe a bad Idler from the reel motor or the capstan belt is old and stretched.
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Remove the cover to see if any belts under the cassette player is cut. Or to see if there are any obstructions.Remove the front cover.which will remove the tape housing of the cassette player. you can check for any broken plastic compoments that might be keeping the housing from opening.Or any belts that may have been cut.
Suggest having a good clean and replace belts. If it stops around halfway on a C90 or near the end then there's a load problem on the take up reel, before halfway the supply reel.
