Question about Music
My ensoniq ks32 window indicate unexpected event id=138
3 Suggested Answers
  • 5603 Answers
SOURCE: when you switch on my ensoniq sq1 the panel says.
You might see if this service bulletin pertains to your unit:
http://thoralt.ehecht.com/download/Bulletin12.pdf
Posted on May 18, 2010
  • 10 Answers
SOURCE: When i turn on my
I'm guessing this is a main board problem. You can get the SQ-1 Service Manual (parts as well) here:
www.syntaur.com/ensoniq_manuals.html
The Service Manual is for the 61-note SQ-1, but that uses the same boards as the SQ-1, just a different keybed. I don't think this is a keybed problem. You can try unplugging the ribbon cable to the keybed from the main board, boot up, and see if you get the same crash. You may get a KEYBOARD CALIBRATION ERROR message, but you can ignore it; if it boots, the keys won't work, but at least you'll be able to see if you get that error message. If you still do, you know it's a main board problem and not anything to do with the keybed. And at that point, your only hope is to replace the main board.
Posted on Mar 03, 2011
How do I change MIDI Channels to coincide with my MIDI controller
Your best bet would be to ask Roland. Here is their link-
https://www.roland.com/us/company/contact_us/ Roland Company Contact Us Contact Us
Feb 27, 2016 | Roland Music
When i turn on my Ensoniq SQ2 it either says Unexpected Event ID 144 or it boots up and plays random notes or when i play notes only a handfull work I looked at the service Bulliten about the problem but...
Jan 28, 2011 | Music
I have an Ensoniq kt-76 that hangs on bootup. the display lights up and when a button is pressed the display returns "Button #: XX" Any help is greatly appreciated!!!
It sounds like it is locked in a diagnostic program for testing. Try to find a factory reset sequence and do that.
Jan 03, 2011 | Music
I have a pair of Behringer B2031A Active Studio Monitor. All is functioning perfectly and automatic power is set to off. . After 5 minutes on, one monitor shut off unexpectly, which is not to be suppose...
This sounds like an internal failure, probably something overheating since it takes time to recover. Behringer OFTEN puts thermistors to sense temp on heatsinks that shut down in the event of overtemp.
If you are not electronically adept, best to take this in for repair. If you are able to work on electronics, try using circuit cooler to isolate the failure. First a good visual inspection followed by the finger test searching for hot components... Do use care where high voltages are involved, mainly in power supplies and input power leads, etc..
Nov 29, 2010 | Behringer B3031A 2-Way Active Studio...
Ensoniq zr-76 no output signal on main and aux, but have output on headphone jacks?
Read around page 33 of your user manual about routing of sounds to the busses. The headphone jack is kind of an automatic thing compared to sending sounds to the aux and mains which require some setup.
Jan 17, 2010 | Music
How to replace os ensoniq ts 10?
Well, today it's almost impossible (Unless you find something on eBay or have this kit somehow available at your local former-Ensoniq lab.)
As I remember, the OS Came on 2 chips that should be installed on the TS-10 digital board instead of the current ones. I also remember that the ones that are currently on the board are marked with stamps on them so they shouldn't be so hard to trace. Please don't mix between them. And remember to do it only after you've unplugged the TS from the power/electricity and discharged any static charges from your body !!! Good luck !
Jan 16, 2010 | Yamaha Music
Ensoniq KT-88 - sustain pedal works opposite the way it should
Usually that indicates that the polarity of the jack for the sustain pedal has been switched or someone has substituted another pedal with the wrong polarity. Try looking in the manual to see if that is an editable parameter for people who might not be able to obtain an original pedal. You may have to initialize the keyboard which is on page viii of the manual. The jacks on the back for footswitches are on page 1 and 2. The footswitch settings are on page 9. I found the manual here:http://soundprogramming.net/manuals/Ensoniq_KT-76_KT-88_Manual.pdf I don't know if you have the single footswitch or the optional stereo footswitch. If it is the single footswitch, the default setting should work correctly if it is the original SW-2 or SW-6 pedal switches. If it is the optional SW-10, the FTswL setting should be Unused. Hope this helps.
Aug 16, 2009 | Music
On the ZR-76 keyboard, no output on main or aux output jacks ok on headphone
Ensoniq zr-76 no output signal on the main and aux, but i have output on headphone jack?
Oct 15, 2008 | Music
Music Logo
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
