Question about Acer Aspire Computers & Internet
When I try to log on with password, I get the following message: The user profile service failed login. User profile cannot be loaded. What is the problem?
Took battery out and put back in.
    Top Expert:
  • Acer Master
  • 25,695 Answers
Repair the SID.
See here;
http://support.microsoft.com/kb/947215
Posted on Dec 06, 2014
  • 300 Answers
SOURCE: Dell Inspiron 1420 - says user profile cannot be loaded
Try this, it should work and it really is quite easy to follow -
1. Boot up in Safe Mode. To do this, hit the F8 key while the computer is
booting, and then scroll down to the "Safe Mode" option and press enter. On
my computer the user account icon appeared, but bigger than normal, and I
clicked it and it loaded my desktop in safe mode. It came up with an error
bubble saying that my user account hadn't loaded properly, but I just ignored
this.
2. Click the Start Button and in the white "Start Search" space at the
bottom type "regedit" (without the quotation marks). This will open the
registry editor.
3. In the left-hand pane, navigate by clicking the little triangles next to
the following folders:
HKEY_LOCAL_MACHINE
SOFTWARE
Microsoft
Windows NT
CurrentVersion
ProfileList
You should now have a list of folders all starting with S-1-5- and then a
number.
(You might need to drag the divider between the 2 panes of the window across
so you can read the whole folder name)
Look at the end of each name and you should see one with .bak at the end of
it, and there will be another one above it with exactly the same name but
without .bak at the end.
The one that's got .bak at the end is your old User Profile that Vista has
now made into a backup, and the one without .bak after it is the new empty
User Profile that Vista has created.
Just to check that this is the case, have a look in the right-hand pane for
each of the 2 folders and look at what's written after "ProfileImagePath".
For the folder with .bak at the end it should say C:\Users\ and then your
usual User Account name, and for the one that doesn't have .bak at the end it
should say C:\Users\TEMP.
What you need to do now is to rename the folders in the left-hand pane so
that the one with .bak at the end changes back to being the one containing
your proper User Profile and the new one without .bak at the end becomes the
backup. Do do this follow the next step:
4. Right click on the folder with .bak at the end and then click "rename",
and just change the ".bak" part to ".bk" - i.e. just remove the "a" from the
middle - (this is just to allow you to change the other one to have .bak at
the end). Press enter or click on some blank part of the screen for the
change to take effect.
Then, right click the one that doesn't have .bak at the end and click
"rename". Remove the .bak from the end and press enter or click anywhere on
some blank part of the screen to accept the change.
Then, right click on the one that now has .bk at the end, choose "rename"
and add the "a" back into the middle, so it now has .bak at the end. Press
enter or click on blank park of screen to accept the change.
Close the regedit window.
5. Click the Start Button and then "Restart".
It should work now, otherwise see link below -
http://support.microsoft.com/kb/947242
Posted on May 21, 2008
SOURCE: dell inspiron 1525 notebook
Posted on Oct 06, 2008
motaro
  • 449 Answers
SOURCE: I am unable to log
This issue may occur if the user profile was manually deleted by using the command prompt or Windows Explorer by a user or by some program. A profile that is manually deleted does not remove the security identifier (SID) from the user profile list in the registry. Since the SID is still present, Vista will still try to load the profile by using the ProfileImagePath that points to a nonexistent path. Therefore, the profile cannot be loaded.
This can also be a issue with the user profile entering into a backup state.
Manually renaming the C:\Users\(User Name) folder.
to solve this issue, you will need to visit the microsoft support website below and read the help available: http://support.microsoft.com/kb/947215/en-us
Posted on Dec 22, 2010
  • 99 Answers
SOURCE: When I type in my password it says user profile
Log on computer in safe Mode by pressing F8 Key when computer start and logon to administrator account after then create a new account and make him administrator and now restart your computer then logon by new account
After then copy your old account data from user folder/old username/desktop and my documents etc. to your new account.
Posted on Jan 01, 2011
SOURCE: my Acer Aspire 5630 laptop
It seems that your profile got corrupt, simply login from the administrator account of your computer,
You can solve the issue by procedure below go to my computer>users>your profile> and copy all of your required data including outlook data if you are using to external drive or other partition (e.g D Drive) then delete the profile folder from your laptop from c:\users\your profile
restart your laptop and try to login again from your username/password, if it stills give the problem, Login via administrator account, go to Start>run> and type control userpasswords2 and press enter, here you will see your profile, simply delete your profile and restart again, when the computer boots up again it should show you your profile if not again login via administrator account and recreate your profile and restart your laptop
after you login to your account, simply copy your data back to its location
if you require more assistance feel free to reply to this post
Regards, Bilal
Posted on Jan 12, 2011
How can I fix my service failed to log on?
You will need to download EBCD software and follow the instructions.
Aug 27, 2014 | Computers & Internet
Won't log in, says "the User Profile Service service failed the logon. User Profile cannot be loaded."
This is a simple fix that can be done in a few minutes or less. It is a problem with either an update from MSFT that had gone awry or an attack from a virus... Anyhow the steps to take are relatively simple just follow along.
1 - go to this site and it will walk you through step by step
You receive The User Profile Service failed the logon error message *make sure to choose option 1
Apr 12, 2014 | Computers & Internet
I try to sign in and the it will not let me it says the user profile service failed the log on,user profile cannot be loaded,
Depending on which router and brand you have the login info will be different.
  1. Press the pin hole in the back side of the router.
  2. Next try these logins
    User: admin
    Pass: admin
    User: admin
    Pass: password
    User: admin
    Pass: (blank)
    User: linksys
    Pass: admin
    IF VERIZON ROUTER/MODEL COMBO:
    The username/password will be on the sticker.
Oct 21, 2013 | Computers & Internet
Dell Vostro 3500 running Windows 7. Trying to log into the admin (only) account and get the message: The User Profile Service service failed the logon. User profile cannot be loaded. No Recovery Media was...
Please check following link from Mocrosoft knowledge base:
Error message: "The User Profile Service failed the logon. User profile cannot be loaded", when logging on to Windows 7 or Windows Vista
PS: If it helps then please click on thumbs up.If you need more help then please let me know.
Sep 20, 2011 | Computers & Internet
When i sign in with my password I get a message saying - The User Profile Service service failed logon - User profile cannot be loaded. I wonder what I can do
Login in as an administrator. There is a problem on the user profile that you are logging in. In order to correct that, just login as administrator. Then create another profile. Afterwards, back up the files that you store in the profile that has a problem. You can access it in C:\Documents and Settings\User Folder (user folder is the profile that has a problem).
Jul 19, 2010 | HP Computers & Internet
My laptop wont let me log on user profile service service failed to log on
U can try login in to the same user account in safe mode or try login in a different profile from there see if u can make any chages in the account of if the data there is intact. For further resolution u can visit this website.
Apr 25, 2010 | Sony Computers & Internet
I cannot log on. i type in my password which is correct i get the following message 'the user profile service failed the log on' also 'user profile cannot be loaded' is there a way round this as i cannot...
Hi! with respect to your words, we can clear two concepts those are, you can't login since "user profile failed" and you are no more since "user profile cannot be loaded", so we need to think about new account. please consider to enter the system in general way and later try to have new account with out error and have fine
Dec 18, 2009 | Computers & Internet
The computer won't log me on.
Make a backup copy of all your data, including passwords, emails, settings, etc
Find another windows xp computer whether its a friends or another computer you have and get a memory stick or external hard drive ( which you will need ) on the working computer go into
c:\documents and settings
make a copy of the default user folder and copy that over the one on your laptop and try again.
I rebooted my system in 'safe mode' (which allowed me to login as
administrator), moved my files to the public area, and then deleted my
profile (using the Users option in Control Panel).
When I rebooted again, in normal mode, I could login as administrator, and
then moved my files back and rebuilt my profile manually.
The only problem was my forgetting about e-mail messages, which I did not
backup and have been lost permanently. Ug!!!
http://cherrybyte.blogspot.com/2007/07/fixing-user-profiles-in-vista.html
May 24, 2009 | HP Compaq Presario V2000 Notebook
CAN'T LOGON ....SAYING .....THE USER PROFILE SERVICE service failed the logon .user profile cannot be loaded ...never had problem before ...normally type in password and it loads ..
this may be a corrupted file for taht particular user thats causing the problem why cant you try opening the other user profiles or if you cant access that too then try turning on your pc and when the list of user profiles appear press ctrl+alt+delete key in and order but you should keep allthree keys down like how you would keep the shift button down while typing an upper case....now when you press all three down a small dialogue box will appear requesting username and password in the username box type administrator and click login no password required after it logs in create a new profile from the control panel but don't use this user profile again because if this gets corrupted then you would have to format your computer.....formating it will delete all the data stored on your pc.....
May 16, 2009 | Acer Aspire 5735 Notebook
Computers & Internet Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
