Zeiss auto refractor keeps displaying motor/board/cable/chip failed. when machine is started
  • Washing Mach... Master
  • 1,249 Answers
If you are no good at chasing wires and signals or deciphering trouble codes, call your favorite local appliance repairman. Otherwise, google searching your model number along with another keyword such as:
failure
code
error
manual
you will find solutions
Posted on Dec 07, 2014
"Y motor failed to home" error message on auto refractor/keratometer model 599
This means that there is a sensor in the unit that cannot detect the Y axis stepping motor location at startup. This unit is very delicate and needs to be serviced and recalibrated. It wont be cheap to have done.
Feb 03, 2017 | Office Equipment & Supplies
Washing machine EWT704S keeps displaying error code EA.
Found this
Re: Samsung B1113J "error code EA" A Tech I called said auto sensor was the tach on the motor.
Check for proper resistance across pins 3&4 at the motor plug (2 red wires). Should be 150 ohms.
If proper resistance, could check connections at board and board itself.
Though I wonder what the error would be if the motor wasn't turning and this looked like an error with the tach. Would this this be an EA error too?
Jan 06, 2016 | Washing Machines
Where are the ports on a zeiss 599 refractor
In the opposite side of the instrument. Why you need the ports?. Or what port do you need
May 09, 2014 | Zeiss Auto Refractor - Keratometer Carl...
Humphrey 599 auto refractor need to replace printer
The printer is termic, if it does not print well, vlean witj an alcohol and brushteeth and try again
Jan 20, 2014 | Zeiss Auto Refractor - Keratometer Carl...
Printer does not work
Clean it with brushtooth and alcohol and try again. The printer is termic, it needs termic paper, not bond paper
Jan 02, 2014 | Zeiss Auto Refractor - Keratometer Carl...
Fix zeiss 5015
Sounds like it is trying to boot from the disk?
If you have a floppy disk in the drive take it out and restart
If still not wiorking it probably needs a new floppy drive.
Jul 19, 2013 | Optics
Screen difficult to view on autorefractor
Is because is similar to old tv's. You have to take it out the screw exavtly below the monitor, there is a hole you should introduce a allen key 3 mm .after you take it out the screw uou are able to take the monitor out and move the tv controls on the board, brightness and contrast until you have better image.
Jan 31, 2013 | Zeiss Auto Refractor - Keratometer Carl...
My Vostro 1000 dell Laptop monitor keeps on having a blackscreen, It is on but I cannot see it on my screen
First connect to an external monitor, is there a picture?
If yes, Us the Fn keys to switch to the on board display. Have you got your display back.?
If no to both, your graphics chip/card has probably failed. If no to just the laptop display, then possibly the inverter has failed or the connection has been broken.
FIrst, Its easier to check the connections to *********** board, unclip the plate between the keyboard and screen, carefully. Then remove the keyboard retaining screws. Make sure all ribbon connections are good. If already good, then its down to checking at the screen end of the cables.
You should find some help here:-
http://support.ap.dell.com/support/edocs/systems/vos1000/en/sm_en/display.htm#wp1022270
Nov 15, 2011 | Dell Vostro 1000 Notebook
My Lamar L1400 treadmill stopped working. The display functions properly, but after it countdowns to start, the belt does not move; then the message "lose speed" scrolls across the display. I...
Hi, please open the cover where is motor and controller board motor, and see if there are some loose cable. And if NOT tight very well all connector, and wires with a plier.
and turn ON again. If the machine after that present the same problem, you must replac the Controller board motor.
cuadra2016@yandex.com
Nov 03, 2017 | Startrac Fitness Products Lamar L1400...
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
