Question about Peavey XR 1220 Powered Mixer 20-Ch Powered Mixer w/FX
How do i record using the 1220 peavey mixer
Nothing
  • 189 Answers
Hi, look here http://www.manualslib.com/manual/121133/Peavey-Xr-1220.html
Posted on Dec 15, 2014
On my peavey xr1220, when I turn on the power switch the board does not power up. What could be the problem?
Probably a fuse ? I have been servicing a lot of Peavey equipment lately and they have some poor circuit designs, a lot of internal un accessible fuses, I might be able to get more info ?
Feb 22, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
I want to record using Tascam with my peavey xr1220 mixer
What Tascam recorder are you using? If you are multitracking you will be unlikely to be able to use this mixer. Otherwise get a phono lead to fit the tape out and suitable connections for the Tascam recorder at the other end. This will allow you to record the main mix but unless you are a solo act or putting everything through the PA this will probably be pretty useless to you.
Jan 07, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
Sound cuts out
check the free air circulation in the power amp module, also check your speaker's impedance, let me know further, sorry for the late answer.
Sep 01, 2012 | Peavey XR 1220 Powered Mixer Mixer Powered
I have a xr 1220. How do I get the phantom power switch to work? I have overhead condenser mics for drums on 11 and 12 but the switch seems recessed and not responsive. Thanks, Steve
The48 volt supply is a simple rectifier/filter from the power transformer. The schematics don't even show the switch anyplace that one can find it. It appears they don't even regulate the 48 volts... Some Peavey switches are just in a hole that you have to poke something into with an alternate action button. They use these on some equipment for instance for selecting a powered mixer into L/R or Main/monitor setup. Push in with a match stick... From the manual it lloks like this is supposed to be a tiny square button... these are EASILY broken off but usually you can still actuate the switch with a little stick.
Sep 13, 2011 | Peavey XR 1220 Powered Mixer Mixer Powered
I have 110v XR 1220 power mixer and friend of mine plug into 240v power point, blown the two transistors ou. I do not know what short of transistors are they?
There are dozens of transistors in the unit... we can't guess which you might be refering to. The power supply of the 1200 series mixers have fuse before each part of the supply for the preamp sections.
Jul 13, 2011 | Peavey XR 1220 Powered Mixer Mixer Powered
I have a peavey 1220 powered mixer and I'm trying to hook up to two sp15's top's and 2 18; peavey subs for my band and I can't get the bass seperated so it's out of my tops
Hi. The mixer puts out a full range mix, the solution is in your speaker setup.
Many subs have a built in crossover that splits the signal for the tops. Check your sub specs or manual. If your subs have this, run your output signal to them first and then link them to the tops from the special daisychain socket.
If they don't have one, you can install a passive crossover to your subs or buy an external crossover unit.
The last (and not very good) option is to fake a crossover with the desk's stereo EQ. Connect the subs to the left or right channel and the tops to the other and use the EQ to remove the bass from the tops and vice versa, pan everything dead center. Obviously this sacrifices your stereo sound and isn't brilliant.
Jun 29, 2011 | Peavey XR 1220 Powered Mixer Mixer Powered
Peavey XR 1220 Powered Mixer 20-Ch Powered Mixer w/FX Logo
Top Peavey Computers & Internet Experts
JonSnell Electronic
JonSnell Electronic
Lesley Cameron
Lesley Cameron
Are you a Peavey Computer and Internet Expert? Answer questions, earn points and help others
