Question about Cameras
Unable to access photos on computer using usb cable.I plug in usb,select computer the screen freezes with Access showing.Can you help?
Tried on computer and also USB port on tv same result.Couldnt find anything in manual to match up with problem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi
You don't mention models or OSs details so I will have to be general. Some possibilities:
Firstly. Make sure that you wait a reasonable time after plugging the camera into USB, before you try and do anything on the computer. It could be that you are interrupting the connection procedures.
Secondly. Can you remove the memory card from the camera and put it into a card reader connected to the computer. This is normally the simplest and quickest method.
Thirdly. Is all the software that came with the camera still installed properly ? Re-installing this software may solve your problem.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Dec 06, 2014
Download from lg800g to computer
Is your Micro USB cable a "B" or "A"?Micro USB "B" is for data/charging.
Micro USB "A" is for charging only and will not work for any kind of data transfer (pins not connected).
The connector will be labeled at the micro usb end.
When you plug the cable into your phone a popup will ask you if you want to connect to mass storage. Once you answer yes, you can connect to the phone just like a usb drive.
Dec 13, 2011 | LG Cell Phones
Unable to display imges when connected to computer.
Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Jun 09, 2009 | Canon PowerShot A460 Digital Camera
My computer does not recognize WD Passport WD2500XMS-00
I use a USB extender cable so I do not have to get down on the ground and plug stuff into my USB ports behind my computer. Everything that I own works through this cable except the WD passport drive. (It is a 2.0 USB cable at that so that is not the issue, plus 1.0 should theoretically still work, just not at 2.0 speeds)
SO...I tried to plug it directly into the USB port on the back of my computer and it worked instantly.
Other people have reported a fix after finding that their cable was loose. This USB cable that comes with the drive seems to be picky for some reason. Perhaps these are faulty cables somehow. Hopefully this will help some people.
lefteris from greece
Mar 26, 2009 | Computers & Internet
Can not connect using usb cable from computer to i9
I think i may have had a similar problem getting error around the lines of "Unable to access application data". What worked for me was, restarting my computer and opening the IDEN loader program on my computer first, then i plugged the cable into my phone this seemed to stop the error. i also had to make sure the USB connection was set to Application Access
Mar 23, 2009 | Motorola Cell Phones
Frozen SanDisk M240 MP3
It will turn on but freezes at the opening screen. Cannot access the menu whatsoever. I've tried plugging it into USB in the back, removing the battery, sliding the Hold button to the right as advised in forum suggestions but nothing budges it from the opening screen. Also: it does not show up as being attached to any computer I plug it into. Got a fix?
Nov 01, 2008 | SanDisk Sansa m240 MP3 Player
MP3 will not stop charging
It could be the usb cable,so shop around for another usb cable for it, if that doesn't work take it (The mp3 player) back to best buy and tell/show them what happened.
Jun 18, 2008 | Samsung Yepp YP-P2 Digital Media Player
DMC-FZ18...unable to download photos off card....have loaded software . taken out other photo software , still unable to download .. Do everything right up to where it says prepare for aquisition...
Have you tried Picasa? Free from Google. Does your PC see it as a drive? Are there proprietary drivers for the camera? Try using a USB hub instead of the USB ports on the PC.
May 27, 2008 | Cameras
Won't upload pics to PC via USB
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 15, 2007 | Olympus Camedia C-770 Digital Camera
Unable to access new hard drive
Try looking for the drive in the "Disk Management". Right click on "My Computer" or "Computer" and select "Manage" then select the "Disk Management" item.
If you can see the drive, but there is no drive letter assigned, you may need to format it for your operating system or create an accessible partition on the drive. You can access all these options by right clicking on the drive from the "disk management" screen that you should be on.
Good Luck!
Nov 13, 2007 | Computers & Internet
Cameras Logo
29 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
