Question about RCA Televison & Video
HOW DO I FIX THE PICTURE SETTINGS ON MY NEW RCA 55" TV MODEL LED55G55120Q
Picture settings from factory are horrible
  • 1,249 Answers
Everything u need to know is in the manual. If u lost it, here is an eternal supply. Please find me helpful. http://download.oncorpus.com/LED55G55R120Q_UM.pdf
Posted on Dec 07, 2014
C-Dog
  • 84 Answers
SOURCE: rca projection tv has sound,no picture or OSD
Check for horizontal drive waveform. It sounds like could be missing.
C-Dog
Posted on Feb 10, 2008
  • 77 Answers
SOURCE: rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Posted on Oct 21, 2008
  • 1779 Answers
SOURCE: need best picture settings for tv, films and video games
Those are pre-sets. I would adjust your set the way you like to watch it. Don't use the pre-sets. Some sets will let you change the pre-set controls and others not. If your can, then adjust it the way you like it then save it as personal settings.
Posted on Apr 15, 2009
Slinteriors
  • 8617 Answers
SOURCE: Philips HD Projection TV just too dark (No Luminance)
sounds like the coolant needs to be replaced in the CRts as that will give you a very dark and dull colored picture. The phillips CRT coolant replacement kit at the following link contains the coolant and the CD with instructions.
http://www.tvrepairworld.com/
Posted on Jul 23, 2009
SOURCE: convergance circuit board
TRY LOCATING THE COLOR CONVERGANCE IC CHIP ON THE BOARD , IT WILL BE MOUNTED TO AN ALUMINUM HEATSINK PLATE ON THE BOARD. LOOK FOR IT TO BE ATTACHED WITH A SELF TAPPING SCREW AND SPRING CLIP. THIS CHIP IS RECTANGULAR AND HAS 11 CONTACT LEGS SOLDERED INTO THE BOARD . ORIGINAL EQUIPMENT CHIP IS STK730-130 , AVAILABLE THROUGH SUBURBAN ELECTRONICS WHOLSALE FOR $4.59 +SHIPPIMG AND HANDELING. A TV REPAIR SHOP SHOULD BE ABLE TO SOLDER YOUR NEW CHIP IN FOR YOU,AND IF YOU HAVE SOLDERING EXPERIENCE REPLACE IT YOURSELF THAT IS WHAT I DID AND THE TV WORKS GREAT!
Posted on Sep 12, 2009
What is the best way to calibrate my rca led29b30rq picture settings?
Set the picture setting to its factory reset. With factory reset, the color intensity might be somewhat more than normal. Just reduce the color intensity, according to your viewing taste. Gopakumar Gopalan Google
Jun 30, 2014 | RCA LED29B30RQ 29" LED TV 1366x768, 60 Hz,...
How do i adjust picture quality settings TV
Find your owners manual that came with the television, it should have all this information in it.
May 15, 2014 | RCA 19LB30RQD 19-Inch LCD 720p 60Hz TV
How to reset factory preset picture emerson le391em4
To do this, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 24, 2014 | Philips 55PFL7705D 55" LCD TV
I am having issues with my RCA Scenium D52W135D (playstation 3 connection). Recently, I have been having a very specific problem with this combo. I have it connected using HDMI to a Pioneer receiver...
Had the same problem. With mine the other day you probably moved your Playstation 3 too another tv and set your 1080i,720,480 to high deaf on settings in Playstation. You have to change them back to automatic that TV says HDTV but it only plays Playstation 3 on 480 checked in settings of Playstation. Played mine for 4 years on that TV moved and got a 3d wifi then dad got him one And was going to trash that RCA but I told him I would take it for now too keep from buying another TV at this time got it in my new home wouldn't play video but it. would sound tried different cables but still now change. But remembered i changed all of my settings over when I got 3D TV. Playstation 3 hadn't been on know other TV. Since I owned it but that RCA now won't work then came to me last night and playing it on both TVs but you have to change the settings on it before moving it or you cant see the screen to fix it do that guarantee it will fix it. Like you said everything else works PS 1,PS 2,DVD, cable,but PS 3 won't its the settings in theme,and audio.
Nov 10, 2012 | RCA D52W135D 52 in. TV/DVD Combo
RCA serial 137651043, model P52939, 55 inch tv.
Half black? top/bottom or left right?
The set is rather old--a old trick to use is to connect a fan to the rear of set with the back off--it may extend the life of the set and give you some more use out of it.
I have seen a lot of these sets and never one with the problem you describe. If only a picture top or bottom is missing it may be vertical or if you are seeing what looks like a full picture with top or bottom black it is a Blanking problem--may not be easy to find...........
Apr 25, 2012 | RCA P55000 55" Rear Projection Television
No sound but picture on an RCA L32HD31R
Check all ur tv inputs cables connections from the back of the tv,for like AV components and or HDMI cables for losed connections or damages cables wires.If u have cable boxes,satalite boxes or telicom compannies boxes and it plug in 24/7?Yes?Unplugs,replugs those boxes and the tv also back about an hour later.For those boxes to reboot and upgraded it softwares and the tv to do a resetting itself back to the tv factory settings.Than goes into the tv menu,go to the tv Audio Settings,to do a whole resetting to all the audio settings back to the tv factory Audio Settings.These steps,will help for ur tv to have and to get it audio sound back again.
Nov 29, 2011 | Televison & Video
How to take the tv back to original factory settings
Unplug,replug the tv back about an hours later.All the tv settings,will return back to the tv original factory settings.
Jun 10, 2011 | Sony KDS-55A2020 55" Television
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
Tv turns on but no picture but has sound and menu
55" rca projection tv turns on has sound but no picture
Feb 11, 2010 | RCA Televison & Video
Televison & Video Logo
71 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
