Question about Blackmore BIM-4750 Dash Deck 7" Inch DVD/CD/MP3 Audio Player Car
Blackmore CD/DVD player it play but the DVD won't come on
Blackmore bim-4750 dvd not workig message when parkig brake supplied what do i do
Send me or post a clear picture showing the wire harness (connector with all the wires that plug into the back) fully top and bottom views and I'll tell you how to fix this really easily!
Mar 08, 2012 | SNK Blackmore Mobile Electronics Blackmore...
Cd won't play
Use a DVD authoring software package to burn it - most DVD players need the information in DVD Format, so "VIDEO_TS" and "AUDIO_TS" folders need to be there with video in VOB Format. I recommend IMTOO DVD Creator 6 or above. Drag video in, and click burn. Taaah Daahhh a working dvd pops out. Use DVD-R discs for best compatibility and you should be fine :)
Jan 04, 2012 | Audio Players & Recorders
No subtitles on data cd
maybe is the problem of format not matched.
you can use a avi to DVD video converter,that must be played on the DVD player.
i have used a DVD creator for long,you may have a try of this one.
Dec 11, 2011 | Philips DVP5990 DVD Player
We have two Pioneer DVD V7400s that won't play DVDs. They can, however, play CDs. Bad laser?
Hi, My guess is that the DVDs are not compatible with the DVD player. They must be windows compatible. WMA or WMV (MP4 format) or (avi) Make sure the your DVD player is indeed a DVD player and not a CD player. Good luck.
Jul 26, 2011 | Televison & Video
Says no disc when i put in a dvd. dvd is new and clean, still won't work.
Hello
Put a video CD and see whether it reads and plays. If it also does not plays, or if video CD only plays and not DVD; in both cases; the Laser Pickup Unit is faulty and should be replaced with same type and number. OK.
Jun 10, 2011 | Coby TF-DVD7107 Portable DVD Player
I have just purchased an HP Desktop computer and when I burn a Cd for music, everyting seems to work ok but when I try to play that CD on another player in my home, it won't play. Is there a setting...
Check the type of the blank CD/DVD you are using. Certain players won't be able to play CD-RW for instance.
If that doesn't solve the problem you might try to slow down your burn speed for a better quality CD/DVD. Sometimes a faster burn speed will lower the quality and other devices can have trouble reading these.
May 10, 2011 | HP Computers & Internet
Drive won,t play discs and sometime won,t reconize that a disc is
If the "bad" disks work fine in some other DVD-player, then it's time to spend $40 and buy a new DVD-writer.
Or, if your current DVD-player is under the manufacturer's warranty, exercise the warranty, to get it repaired/replaced.
Dec 28, 2009 | Fantom Drives DVD-RAM Burner
Won,t play region 2 dvds it comes from america
America is region 1, thats why it will not play. The best luck I have had with region free dvd players is the cheapest you can find will play almost anything but they dont last
Jul 15, 2009 | Samsung BD-UP5000 Blu-ray and HD-DVD...
Blackmore BIM-4750 Dash Deck 7" Inch DVD/CD/MP3 Audio Player Car Logo
71 people viewed this question
Top Blackmore Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Blackmore Toy Expert? Answer questions, earn points and help others
