Question about Winter Sports
I need to know how to change the brake pads on my snowmobile yamaha apex rtx 998cc 2006
  • 3,506 Answers
Buy a service manual is the best way to get ALL your answers.
Posted on Dec 11, 2014
  • 3 Answers
SOURCE: front brake pads
Just did this tonight... 7/21/08
You need a torx head T-55 Star Socket to remove the caliper bolt(s) and a large 3/4 in preferably with a 1/2 dr and large breaker bar or torque wrench with a 1/2 in dr. to remove the knuckle bolts. I should've taken pictures, but I did not. After studying this exact issue for an hour or so, I finally got everything to click. Steps as I proceeded. Loosen the top caliper nut using the T-55 torx bit, this will take some doing, if possible, use a breaker bar or something comparable, I used a standard 3/8 in. socket wrench and about a foot long hollow metal tube on the end as the breaker and after some muscle work (ouch!!) got it loose. Now there are 2 bolts that hold the caliper in place that need to come out. I used a 3/4 in socket on a 1/2 breaker bar to get these to break. I don't have the exact torque specs to put these back on, but I went about 40lbs on the knuckle bolts and closer to 80lbs on the caliper torx head screw. Once you have the caliper torx head bolt loose and the other 2 nuts off, you can rotate the caliper. Using a C-Clamp, compress the caliper so that it is completely compressed. Now, remove the torx head bolt and the pad assembly will swing out, at this point, you can remove the old pads and clips if you are replacing them as well. Reverse the order for installation using Lock-tite and the caliper grease you get from the parts store. I hope I don't have to mention removing the tires, using jack stands and being completely safe under there. Good Luck. The first side took me about 3 hours considering time and studying, the second side took about half an hour after already knowing what to do.. It gets easier each time you do it.
So far, I have replaced 2 fuel pumps (at home) first one took about 7 hours, second time around, only took about 2 hours. Front and Rear brake jobs. numerous small items, now I'm looking at a blinker switch (problem with left turn signal... rapid click, no light).. Also, the dash panel either needs repaired or replaced as the fuel gage is constantly up and down. If you or someone else has a suggestion here, I would appreciate it.
Thanks and remember... Practice Safe "Do it yourself"..!
Posted on Jul 22, 2008
  • 6982 Answers
SOURCE: changing brake pads
There is no "easiest way" to remove the pads. You need to unbolt the calipers, (bolts are on the inboard side surrounded by small rubber boots) retract the caliper pistons and remove/replace pads,(make note if any pads are marked R&L) put it back together. Make sure that slides that caliper bolts pass through move freely. Don't use calipers with torn rubber dust boots and don't pinch boot between pad and piston when you reassemble. Unless you open the hydraulic system you do not need to bleed. Before attempting to drive, depress pedal a few times to restore proper caliper adjustment.
Posted on Mar 30, 2009
greg_margo
  • 1959 Answers
SOURCE: Jeep Commander Rear Brake Pad Installation
Per Chilton Auto repair manual:
Removal & Installation
  1. Raise and safely support the vehicle.
  2. Remove the rear wheel.
  3. Siphon a small amount of brake fluid from the master cylinder reservoir.
  4. Insert a small prybar through the caliper opening and pry the caliper cover (using the outboard brake pad) to bottom the piston in the caliper bore.
  5. Remove the caliper slide bolts.
  6. Remove the caliper from the anchor.
    WARNING Support the brake caliper with mechanics wire. Do not let the caliper hang by the brake hose.
  7. Remove the brake pads from the caliper.
To install:
  1. Install the brake pads onto the caliper.
  2. Lubricate the slide pin bolts with grease provided with the brake pads, or suitable silicon grease equivalent.
  3. Install the caliper on the anchor and tighten the slide pin bolts to 18 ft. lbs. (25 Nm).
  4. Install the rear wheel.
  5. Lower the vehicle.
  6. Pump the brake pedal several times until a firm pedal is obtained in order to properly seat the pads.
  7. Refill the brake fluid reservoir to the proper level.
Posted on May 17, 2009
  • 57 Answers
SOURCE: How To Change Rear Brake Pads on Audi A6 2006
Remove the tires, Remove the calaper bolts, (small heads on them 12mm or so) Remove calaper, Pads are setting in a holder. Lube new pads with litheum grease and place in holder. (look at old pads, one or both may have small metel tab on one end) If the new pads have the tab, put that pad where the old pad with the tab was. (ie. tab to the inside) Press pistion in with a 'C' clamp. If it won't go in easly, it may screw in. If the parking brake cable is hooked to the calaper, it probly screws in. Use large pliers to screw in calaper piston. Place calaper over pads and install bolts (lube bolts) Rember to pump brakes befor driving . to get a solid peddle.
Posted on May 20, 2009
  • 66 Answers
SOURCE: 2006 dodge ram 2500 4x4 diesel replace brake pads front and back
Straight forward job. Remove wheels, remove 2 caliper bolts per wheel, check bolts,and bushings for wear/corrosion and lubricate, remove calipers, remove brake pads, push caliper pistons into calipers, replace anti-rattle clips, put new pads in, put caliper and bolts in, put wheels on. Start truck and press brake pedal several times to take up slack and you're done.
Posted on Jun 02, 2009
How do I change handle bars on a 2009 Apex Snow Mobile
The bolts underneath need to be unscrew first
Feb 13, 2015 | Yamaha 2009 Apex LTX
Yamaha apex rtx
Refer your inquiry to Yamaha.
Dec 22, 2013 | Winter Sports
Ttr250 changing front disc brake pads
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Front brake pads
How To Replace Front Brake Pads On YAMAHA YZ85 Part 2
http://doc.razorscript.com/moto/yamaha_ttr250_service_manual.pdf
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2006/lit-11626-19-30_1198.pdf
May 02, 2013 | 2002 Yamaha TT-R 250
Yamaha 2006 Road Star Midnight Silverado replace brake pads
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Replace Front Brake Pads On Yamaha Star 1100 Custom
Replace Rear Brake Pads On Yamaha Star 1100
Yamaha XV1700PCRC Service Manual
Yamaha XV17AWZ Owner Manual
Jun 06, 2012 | 2006 Yamaha Road Star Midnight Silverado
How to change front brake pads on a 2006 yamaha roadliner
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://meiguohosting.com/How-to-Replace-2006-Yamaha-Roadliner-Brake-Pads
How to Change Front Motorcycle Brake Pads from SportbikeTrackGear com
Yamaha XV19SX Service Manual
Yamaha ROADLINER XV19SW Owner Manual
May 15, 2012 | 2006 Yamaha Roadliner
I am trying to remove jackshaft from sled chaincase removed clutchside ? 2006 yam apex rtx
I know that some of the bearing have a set screw in them. I have worked on many older sleds but not a apex. try this link there alot of guys there that can help.
I go buy DoubleClutch there.
http://www.snowmobileforum.com/
Dec 07, 2009 | 2008 Yamaha XT 660 Z Tenere
Winter Sports Logo
49 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
