Question about Makita Saws
Bought new Makita Jigsaw 4329 and the two screws at the back of the roller, where the blade inserts keep coming loose. I've tightened them a number of times, still come loose? Do I need Loctite or is there a problem with this model?
3 Suggested Answers
  • 3 Answers
SOURCE: blade wont stay in Bosch 1882VS jig saw
From your description I cannot say for certain, but it sounds as though you are not locking the blade correctly, or the blade lock mechanism is broken. You can tell if the blade-lock is working by clicking it. It should make an audible "click" that you can feel. Also, you can pull on the blade ( with the saw UN-plugged of course!) and feel if it is properly seated. If you are operating the blade-lock according to the instructions and it still doesn't lock positively, see a service center before you use the tool again. A broken blade-lock could be dangerous.
Posted on Apr 10, 2009
RonPark
  • 855 Answers
SOURCE: I need a replacement roller part for my Makita 4320 jigsaw
You can go to ToolPartsDirect.com or eReplacementParts.com
Both sites have a listing and a blow up diagram of your saw. So check there if the part is not on the diagram you may be able to call them and there may be a universal one or the right one available. They were the two most promising sites I could find.
Posted on Oct 23, 2009
Testimonial: "Thanks for the advice The only problem is they don't ship outside the US I'm in Australia"
HOW do I Insert a blade into a Task Force jigsaw #231603
hi Jeanne.
this is all i could find out from other fixya members.
depending on how new the saw is there are only 2 ways to change out the blade. the older saws have a allin head screw that you must loosen or remove to take the blade off. this screw is located on the shaft at the top of the blade. shed some light on it and look for a slot above the guide.the screw will be either on the right side or the left side. Newer models will have a quick release on one side or the other,it will look like a little lever,you just flip it out with your thumb the old blade drops out then you install the new blade flip it back and your back in.
They all either have a screw at the side of the blade holder, or some have a hole in the top of the machine where a screwdriver is inserted and a screw loosened to release the blade, and re tightened once the new blade is inserted.
In the handle directly over the blade is a deep hole. You insert a long thin bladed screw driver into this hole all the way down. Twist slowly and it will locate with a screw. Undo the screw and then twist the remaining piece of blade 90 deg and pull. Replace new blade in the opposite way. Twist it so that the cut is to the front and then tighten up the screw. Do not tip up the unit while doing this as the screw might drop out and you might loose it .
The fixya members are.(john weaver.)(sava mihai.)(daniel skuy.)(freddyyesme)thanks to them for this info.
hope this helps you out.
Dec 14, 2017 | Blade Saws
Ks656pe how do i change the blade? i don't have any instruction. Please
Quick-Change Blade Mechanism
Higher-end models, such as the Linefinder Orbital Jigsaw, feature a clamping lever to hold the saw blade. To change a blade, switch off the jigsaw, unplug it, and let the used blade cool down. Pull up the saw-blade locking lever and let the used blade fall out with a slight shake. Turn the jigsaw upside down. Hold the fresh blade with its teeth forward; insert the blade shank into the blade holder as deeply as it will go. Release the lever and wiggle the blade to confirm that it's snugly in place. For models with rollers, such as the Accu-Trak, nestle the blade against the rollers.
Clamp or Hex Screws
Loosen the pair of screws -- on the front of the mechanism of models such as the single-speed jigsaw -- a full turn counterclockwise with a flathead screwdriver, but do not remove them. The used blade will fall out. Insert the new blade fully into the clamp. Lightly tighten each screw alternately and then fully. On older models, you may find a single hex screw on the side of the blade. Loosen this enough to remove the blade, and then insert a new blade carefully so the teeth face forward. Retighten the screw.
Oct 03, 2017 | Saws
How to remove blade wont budge with allen key
Hallo Ingrid
Pl send a picture Of allen bolt , if possible make a flate cut with hacksaw and open with screw driver.
Jayesh Desai
Jul 16, 2014 | Makita Jigsaw Blade
I need to use my late husband's jigsaw but can't get the old, bent blade out. How do I do it and which blade do I replace it with? I need to cut a few cms off the width of a kitchen worktop. I...
Hi Jen,
It depends on whether you have an older or newer model jigsaw. Bosch makes the newer ones with a button you push that will release the blade.
On an older jigsaw, look at the handle from above the jigsaw directly in line with the blade. You should see a screw in the top of the handle. Use a screwdriver and loosen this screw, don't remove it, and when the screw is loose enough, you'll be able to pull the blade out. When you put the new one in, slide it in the slot until it seats.
A rule of thumb is to use the blade with the wider gap and larger teeth on wood, the smaller teeth on metal. Most blades will say bimetal on the metal cutting blades.
Now, the courser the teeth the rougher cut you'll get. So, if you want a nice cut, don't use the blade with the largest teeth. Move down to the next largest.
I don't have a Bosch, so am not sure which codes are for which blades, but you can't go wrong if you go by the size of the teeth.
You didn't say what material the worktop is made of. If it's wood, the second largest toothed blade should be fine.
If you've never used a jigsaw before, I could suggest a couple tips that would help you get a nice job done.
First, put a piece of painters tape or masking tape over where you will cut, draw your line and go easy. The tape will keep the blade from giving you a roughed up top edge.
When you get near the end of the cut, hold a piece of scrap wood flat against the back edge to prevent tearout.
Also, let the saw do the work, don't push it.
Hope this helps, If it does, I'd appreciate a 4 thumbs up, Thanks,
Handie Andie, "woodworker by night"
May 24, 2011 | Bosch Garden
Makita 2012nb planer. The drive (top) sprocket keeps stripping out the flats on its arbor hole and the allen bolt loosens and backs out. Not sure which happens first. I've tried high strength loctite...
I think your screw is broken you should change the screw which attach the rollers and the blade. If you start a machine, screw turn out and let the roller stop rolling that means your screw and the ring are broken, you have to change them.
May 08, 2011 | Makita 2012NB Electric Planers
Cannot remove blade as do not hve manual 4350FCT makita jig saw
Hello Aiden,
This Makita jigsaw does not use any set screw fasteners to secure the blade in the saw. It has a "tool-less" blade retainer, so all you need to do to remove (or install) the blades, is to twist the small knurled ring nearest the blade shank.
Be sure to unplug the jigsaw first and with the blade shaft fully away extended from the saw, (you can just pull it out by hand if needed) and then simply twist the round locking ring and then with your other hand, pull the blade out of the jigsaw.
I would suggest that you use a glove on the hand you're going to pull the blade out of the jigsaw with, as those blades can be very sharp with the jagged cutting edges, etc.
Here's a parts breakdown of the jigsaw, for your reference and for obtaining any replacement parts you might need in the future.
http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_4350FCT.pdf
Makita doesn't have an owner's manual listed on their web site for this product. You will need to contact Makita directly to obtain a free replacement manual for your product. You can contact them at
1-800- 4MAKITA (462-5482) Hours: Monday through Friday 8am - 6pm (EST)
I hope you find this Very Helpful and best regards!
Dec 23, 2009 | Makita 4350FCT Top Handle Jig Saw w/...
Makita 4304T. jigsaw blade Do not know how to fasten it?
On the top of the Makita 4304T is a knob, (Top/Front)
This is the blade Installing Lever.
Viewing the jigsaw in the direction you would use it, the Installing Lever is turned towards the Right. Keeping it turned, you then install the jigsaw blade. Once you have the blade up in the Blade Holder, gently release the Installing Lever.
This is a PDF file of the Owners Manual for the Makita 4304T Jigsaw,
(From Makita - Products - Support)
http://www.makita.com/en-us/Assets/images/Products/4304T/owners_manuals/4304T.pdf
[Should the above direct link not work for you, this is Makita - Products -Support, and the download page,
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=248
Left-click on Owners Manual next to the PDF file Icon]
Nov 04, 2009 | Makita Jigsaw Blade
Jigsaw dc330 blades keep poping out when used
Hi Paul,
When inserting the blade, turn the saw upside down to prevent the blade from moving while tightening.
Before inserting a new blade, check the receiver for obstruction or debris that may prevent the blade from properly registering with the tightening screw.
Make sure the blade is fully seated in the receiver before tightening.
The tightening screws that secure blades on any type of reciprocating saws (Jig, Scroll, Sawzall, etc.) are constantly under stress and do wear out. If the problem continues, it may need to be replaced.
Best regards
Mike
Oct 29, 2009 | Dewalt Saws
Bought a jigsaw a bosch pst 54e how do i change the blade.thanks
Sep 24, 2009 | Bosch Saws
Change a blade on a jigsaw
They all either have a screw at the side of the blade holder, or some have a hole in the top of the machine where a screwdriver is inserted and a screw loosened to release the blade, and retightened once the new blade is inserted.
Jul 05, 2009 | Makita Jigsaw Blade
Saws Logo
240 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
