Question about Haier RWT360BW 3.0 Cu. Ft. Capacity Top-Load Washer 6 Wash Cycles 5
My new haier washer won't fill with water, hot or cold. All brand new water lines and yes the valves are open too. It humms and clicks like it is trying to but won't. I just tried to put on spin only and it won't do that either? Help anyone?
  • Haier Master
  • 3,368 Answers
Turn off the water, take off the hoses and clean the screens therein. Put hoses back on and it should work. You may want to flush the hoses before connecting back to the washer just to be sure water is flowing.
Posted on Dec 06, 2014
4 Suggested Answers
dutchman05
  • 487 Answers
SOURCE: Brand new washer, E4 Error
OK this should not happen. It might be that the connectors to the watervalve is lose. E4 is a sign that the watervalves are closed. You should contact the store you bought it from and have them give you a replacement. Do not open it for now as it will void your warranty. You know it is not the pressure as the other never had this problem
This however is the link for all the parts you need. or might need.
LINK
Have a good one and good luck changing this one out and please dont take no for an answer
Posted on May 01, 2008
SOURCE: Haier Genesis HLT364XXQ CAN'T GET HOT WATER WASH
hey Paul, you don't have to wash anything in hot water. Hot water only wastes money and does nothing, in my opinion, to get anything cleaner. It does ,however set the stains. To kill any thing the water has to be 212 degrees [ boiling ]I have not used hot water for over 40 years and our clothes are coming out clean. Just set the machine on cold. I put a twoway spigot on my cold tap and put the hot water and cold water together incase someone breaks in and does my laundry. Barry
Posted on Oct 14, 2009
SOURCE: My Haier HWD 1000
Had a leakage and motor problem up until an hour ago.
Repairman advised me not to twist the screw in, but to first push in the screw as you would a regular plug. Once all the way in, turn it shut like a screw. I tried it and it worked! ...I'm still getting a washing machine pan.
Posted on Jan 22, 2011
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Only get cold water entering washer ... no warm or hot
1. Close hot water valve behind washer.
2. Remove hot water line from washer side and place it in the drain.
3. Open hot water valve to ensure pressure and hotwater is ok in your drain.
4. If not, problem is home related.
5. If pressure and hotwater are ok, then see if your fill valve filter is clogged where you disconnected the hotwater hose attached to the machine.. Its called a fill valve. Sometimes they get clogged.
6. If the hot water side of fill valve looks ok with no blockage, then you might be looking at a new fill valve.
Feb 11, 2010 | Washing Machines
Cold water will not fill, yes my hoses are right, yes the screens are clean. I switched the hoses and it will fill with cold if the cold hose is on the hot side
The solenoid valve for the cold water has failed. Even though they operate separately, the cold and hot solenoids are usually in the same unit so the entire part that the hoses connect to will have to be replaced.
Dec 30, 2009 | Kenmore 26882 Top Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
My kemore 80 series washer will not fill up
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
May 03, 2009 | Kenmore 24032\24036 Top Load Washer
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
Mar 03, 2009 | Washing Machines
Haier RWT360BW 3.0 Cu. Ft. Capacity Top-Load Washer 6 Wash Cycles 5 Logo
99 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
